SynapseTurbo's Initial testing 365whp 359wtq
Old Nov 16, 2008 | 02:50 AM
  #351
Cougar's Avatar
lol do all of you guys realize that is argument slinging back and fourth is all over a car? ****, I would really hate to be even near any of you. It's over a car, not life. Give it up.
Old Nov 16, 2008 | 10:26 AM
  #352
psychophyr's Avatar
They can fight all they want, we all know what it's really about. I have a bigger *****.
Old Nov 16, 2008 | 11:18 AM
  #353
Dr_Jekyll's Avatar
Synapse, is there any chance of this kit working with the HHR SS?
Old Nov 16, 2008 | 11:49 AM
  #354
40rty's Avatar
No^^^^ go away!!!!!! j/k that would be once badass HRR with this kit.
Old Nov 16, 2008 | 04:28 PM
  #355
SynapseTurbo's Avatar
We just need a car to test it on to be sure!
For those who want to save some money we are now taking pre-orders on our kit
https://www.cobaltss.net/forums/show...35#post3104935
Last edited by SynapseTurbo; Nov 16, 2008 at 04:30 PM. Reason: Automerged Doublepost
Old Nov 16, 2008 | 04:32 PM
  #356
TorontoSS's Avatar
Question
quick question,
I dont know if this has been mentioned before.
How is the transmission holding up to this kind of torque throughput. Is it able to hold up to the increased power? did you guys modify the transmission or axles/ breaks or other supporting areas to handle this power upgrade?
gj btw on the kit
Old Nov 16, 2008 | 04:45 PM
  #357
Originally Posted by TorontoSS
quick question,
gj btw on the kit
The stock tranny, axles have been no problem at all for us. The true test will be at the track with slicks on it, but on the street we have had 0 issues.
Old Nov 16, 2008 | 07:11 PM
  #358
fuente27hpv's Avatar
are you gonna offer a turbo with a little less lag, like maybe a 50 trim? a 50 trim should hit full boost around 3500 RPM, great product though. I know it might be hard since you guys have to tune the computers for the different turbos
Old Nov 16, 2008 | 07:18 PM
  #359
TorontoSS's Avatar
Thanks
Old Nov 16, 2008 | 07:29 PM
  #360
This will be offered only in a BB config, if someone wants something with a little quicker spool we can put a smaller housing on it, but if you see our new graph your really not loosing much useable power on the low end.
Old Nov 16, 2008 | 07:30 PM
  #361
ralliartist's Avatar
50 trims are old school, they need a ball bearing turbo with instant response. I figured the VVT, direct injection, and that crazy manifold would prevent lag like that, but unfortunately not. It seems as though the 2.0ltrs is what is killing it. Maybe if it was a 2.4ltr. lol.
Garrett GT3076R would have been a much better choice. About the same amount of lag and much more power.
Old Nov 16, 2008 | 07:35 PM
  #362
We have a 3076r that can also be put in this package for those looking for more power, but their will be some added lag.
Old Nov 16, 2008 | 07:37 PM
  #363
I'm confused on what you mean. You just said that you aren't loosing much useable power on the low end. You do know that on the stock turbo, your car made over 50wtq MORE and about 40whp MORE on the low end. Which would be useable power that you drive with everyday.
To everyone else, imagine how slow the car would feel driving it everyday in traffic. I'm looking at it kind of like a honda. It's slow down low, and then vtec kicks in about 4k and the car starts making a butt load of power. Only problem is you only got about 2000-2500 of useable power.
These are just my observations. Don't take it personally please.
have you tested this manifold on the stock manifold? I think something HAS to be up with it. Your new manifold design just doesn't seem like it's doing what it should be doing. I know Paul said he gets way quicker spool with his new manifold, and it's very similar to yours, just not top mounted.
Last edited by ralliartist; Nov 16, 2008 at 07:37 PM. Reason: Automerged Doublepost
Old Nov 16, 2008 | 07:39 PM
  #364
No need to argue, but a loss of 1500rpms down low to get the gains the rest of the time is a trade-off well worth it. Unfortunately, if your going to add 130whp your going to have to give-up something, give a little to get alot. A manifold with longer runners will add a little lag, but will perform on the top-end better.
Old Nov 16, 2008 | 07:40 PM
  #365
06blackg85ss's Avatar
It spools up faster under load, and builds more boost in 1st gear now, but still just on a rolling 3rd gear punch it's still @4k rpm for full boost, but I'm also running a much larger turbo.
I've had some nice success with a 3071 on my friends cobalt... very very fast spool (on a log mani no lesS) and made 340whp on 15.5psi
Old Nov 16, 2008 | 07:42 PM
  #366
I just don't understand why it lost so much down low. It's not even a big turbo. Just a 2871, it's ball bearing, and you designed a new manifold that should have in theory helped spool. I'm stumped.
Old Nov 16, 2008 | 07:43 PM
  #367
large A/R (even though it's a smaller housing)
and side note, this is my car with the new mani in it.
60-1 HiFi
http://videos.streetfire.net/video/t...lls_199181.htm
Old Nov 16, 2008 | 07:48 PM
  #368
We switched from a turbo that made 275whp on our dyno at the same boost level to 375whp, your going to give somethign up plain and simple. This car has spooled up a turbo of this size faster than any 4 cylinder I have seen. I have hundreds of dyno graphs of 4 cylinders and they are much lagger than this. FYI, a tubular manifold will spool later not faster than a log, but will create more velocity to the turbine for better top end.
60-1 HiFi
Nice vid, ill have to get some incar, because our setup is no were near that laggy ont he street, but a 60-1 is deff. larger
Last edited by SynapseTurbo; Nov 16, 2008 at 07:48 PM. Reason: Automerged Doublepost
Old Nov 16, 2008 | 07:51 PM
  #369
ahhh, I see. I thought the tubular manifold decreased lag. I had it backwards. That explains it then.
Old Nov 16, 2008 | 07:52 PM
  #370
oh I can imagine the spool on the 28, my friends srt runs a 2876 and that thing you to boost up as fast as my s/c setup did... If my ultimate goal wasn't over 500whp I'd be running a smaller turbo
Old Nov 16, 2008 | 07:53 PM
  #371
Absolutely, a 60-1 is perfect choice for around 500whp.
Old Nov 16, 2008 | 08:16 PM
  #372
boostking's Avatar
being this car does not have much top end ability would it be better to run the stock manifold with the the stock head/ balance shafts?
Old Nov 16, 2008 | 08:42 PM
  #373
08BlackSS/TC's Avatar
I'm using the stock manifold for my GT3076R, the manifold is good to 600hp
Old Nov 16, 2008 | 08:52 PM
  #374
peachpuff's Avatar
This power loss is at wide open throttle, not partial throttle during cruising/traffic. Im sure the bigger turbo is a bit less responsive than the stock one during 25-50% throttle but you cant really measure this unless you drive the car.
Unless you start getting into 500+ whp turbo's you probably wont notice this.
Old Nov 16, 2008 | 09:31 PM
  #375
frankc5r's Avatar
[/URL][/IMG]
One of the main advances of the LNF motor is the separation of the exhaust blowdown
pules in the exhaust manifold all the way thru the system and thru the dual scroll turbine
inlet housing. There is a good SAE paper describing the LNF motor in detail.[/IMG]
This image is from the paper and shows the improvement from the dual scroll. There is also a graph show difference in pressure in manifold.[IMG][/IMG]
Plus the pistons ARE different. Here is a picture. Notice the combustion area on top of
piston similar to a diesel.
[/URL][/IMG]
For your info, my HHR SS with Westers tune makes about 70 more ft# at 3250 rpm,
then crosses over at 3750rpm, the the Synapse makes more- about 100 at 5000 rpm.
I like the setup. Too bad you can not get a split hsn for the bigger turbo so you
could gain the benefits of the dual scroll.
frankc5r
retired enginner various GM racing programs
