Upgrade from GM coming soon!
Old Oct 26, 2008 | 02:15 AM
  #176
MARIN007's Avatar
Was the number 19212670?
Old Nov 22, 2008 | 01:43 AM
  #177
Gyrocon's Avatar
So is this thing dead or what? and I don't mean general motors! although that's possible too I guess
Old Nov 22, 2008 | 09:31 AM
  #178
peachpuff's Avatar
One of the gm engineers has this kit on his solstice gxp, he talks about it here.
2007 & 2008 Solstice/Sky Manual Trans: 290 HP@5200 rpm \ 340 lb-fts@3600 rpm
2007 & 2008 Solstice/Sky Auto Trans: 290 HP@5200 rpm \ 325 lb-fts@3600 rpm
Not sure if the cobalt gets the same torque output.
Old Nov 22, 2008 | 01:27 PM
  #179
08CobaltSSTC's Avatar
Good find! Very Interesting! Thanks
Old Nov 22, 2008 | 02:06 PM
  #180
SS4EVER's Avatar
if that's the same one from solsticeforum.com then I heard that the Cobalt SS/TC is actually going to make at least 10hp more...
They were talking about it a little on there about the drivetrain loss on RWD being a little greater than FWD...
Old Nov 22, 2008 | 05:55 PM
  #181
rat's Avatar
rat
Drivetrain loss doesn't matter. It is rated at the flywheel.
Old Dec 1, 2008 | 01:45 PM
  #182
08BlackSS/TC's Avatar
Here is an update from the Solstice forum
http://www.solsticeforum.com/forum/f...-review-52407/
pls read the entire thread before asking questions
Old Dec 1, 2008 | 03:58 PM
  #183
cobaltssoverbooster's Avatar
i noticed talk of a wastegate mod on that thread, does that work for us as well and which direction do you move the nuts?
Old Dec 1, 2008 | 04:11 PM
  #184
not sure...you will find PLENTY of good info on that forum, I recommend searching on there
Old Dec 1, 2008 | 05:01 PM
  #185
peachpuff's Avatar
Don't bother, the ecm just adjusts the boost back to the original spec.
Old Dec 1, 2008 | 05:06 PM
  #186
umrdyldo's Avatar
I think that's why we are talking about Stage kits to adjust ECM outputs
Old Dec 1, 2008 | 05:15 PM
  #187
leahciM's Avatar
bah. gm is dying. don't even bother mentioning stage kits.
Old Dec 1, 2008 | 05:31 PM
  #188
yea i honestly wish the camaro would come back but i feel very safe saying its not. with all the attention the stuff they are pushed to produce are high mileage cars. 8(
Old Dec 1, 2008 | 06:33 PM
  #189
Aaron R.'s Avatar
the pricing came out the other day, I dont have it in front of me but I know it retails for $800. I also had my parts guy call and he was told it will be able for shippment on Dec 2.
SO, call you local Dealer and ORDER.....
Aaron
Old Dec 1, 2008 | 06:55 PM
  #190
Aaron
What part #s? The dealers say they still can't pull anything up yet.
Old Dec 1, 2008 | 06:59 PM
  #191
Grich171's Avatar
Aaron
i got the hookup at the dealer i got my car at i will be getting it at cost if it ever comes out that is....
Old Dec 1, 2008 | 08:08 PM
  #192
Aaron R.'s Avatar
Cost is $560 retail $800 and Part # 19212670.
Aaron
Old Dec 1, 2008 | 08:22 PM
  #193
Scythe_Snake's Avatar
Grats LNF guys.
This has officially marked the extinction of the LSJ performance wise. We're second class citizens now.
Old Dec 1, 2008 | 08:24 PM
  #194
agent007kimball's Avatar
Aaron
I am thrilled to hear this. Explain how one would go about ordering it though. Does this need to be done through a dealer or can it be purchased elsewhere? Also does the dealer have to install this to keep the warranty valid?
Old Dec 1, 2008 | 08:41 PM
  #195
yobrigidey's Avatar
Very interesting info here:
Originally Posted by Flash's owner
Regarding what the GMPP Exhaust and other improvements, in general they should be quite effective.
Here's why:
The stock production calibration is a sophisticated torque-based control system. It is constantly looking at all of the inputs - air temperature and pressure, charge air cooler efficiency, estimating density of intake air, and where the settings are for all the systems relative to a spark map to ensure the engine is protected for knock and detonation. It also estimates turbine speed with some very accurate modeling for given output to protect the turbo unit from overstress.
The goal of all of this control is to provide very consistent 260 ft lb/260 hp for all cars. If you make a change to the system such as improving the exhaust efficiency, then the control system will relearn with each key cycle that it is overproducing torque, and will "learn down" the torque back to stock level. If you do a back-to-back change that a dynomometer shows a gain of 15 ft-lbs, in a handful of key cylcles, long after you have left your dyno shop, the engine will learn back down to 260 ft-lbs. If you encounter a situation, such as a very hot day or you use 87 octane fuel, which requires an immediate spark retard to protect the motor, the good news is that the engine will "learn up" back to stock torque. But only back up to stock torque.
That is how the production system works.
In simple terms, the Performance Upgrade Kit turns off the learn down portion. You still have all of the protection features for the engine, such asg spark knock protection, turbine overspeed, or if you play with the wastegate link (which will, incidentally, probably set a boost fault).
So, essentially the PUpgrade you can think of as limited by turbine speed to protect the turbo from overstress and failure. At max turbine speed, whatever you can do to increase torque will be effective at producing more torque and power at a given RPM. This boils down to getting more molecules of air into and out of the engine. You can improve intake system efficiency by trying to make it less restrictive, including all of the flow path from fresh air intack to the turbo compressor intake, through the compressor outlet, through the charge air cooler (which also can be improved both through flow efficiency and cooling efficiency), into the intake manifold and through the cylinder head port and even intake valve openings. The easiest place to start is the air cleaner/intake pipes up to the turbo, BUT you must be careful when you start changing these things, as it is easy to create small areas of turbulence in the intake system which cause erratic readings on the MAP and MAF sensors and will set intake rationality codes.
The same thing applies to the exhaust side, from the exhaust valves. Legally, the catalytic converter must stay in place for the compliance to be legally valid. Improvements and lower restrictive exhaust in the cat-back section, such as what is available through GM Performance Parts should also be effective.
With the PUpgrade, these gains will not "learn out" like they do in the production calibration.
Old Dec 1, 2008 | 09:10 PM
  #196
i want this for the upgraded fuel tables and sensors but its supposed to be locked down pretty good well have to see what hpt says it will be soon great info
Old Dec 1, 2008 | 09:52 PM
  #197
orbalt08's Avatar
i can't wait for this. crossing my fingers!
Old Dec 2, 2008 | 10:04 AM
  #198
boostking's Avatar
tried to order today. was told its in the system but still unaval.
Old Dec 2, 2008 | 10:44 AM
  #199
just got off the phone with the dealer part # IS 19212670 and it is available to order and Aaron was right on with the price!! I get 10% above cost whooo hooo
Old Dec 2, 2008 | 11:05 AM
  #200
malachii's Avatar
So just to confirm, this isn't available yet for the 09s, right, due to certification requirements, etc?
