How to tune the LSJ or any car for that matter.
Old Jun 26, 2006 | 06:40 AM
JerseyJay's Avatar
Originally Posted by Doc
here is a link to a .bin repository
www.horist.com/hptuner
red line forums.com has some useful info about hptuners,
on this forum, its mixed in and a little difficult to find.
which is why i'm saying maybe someone should have a stick on that
Old Jun 26, 2006 | 08:42 AM
Doc's Avatar
Doc
go figure, this is a stickied thread
Old Jun 28, 2006 | 01:58 AM
JerseyJay's Avatar
lol you know what i meant
Old Jul 27, 2006 | 12:44 AM
sunfirejoe's Avatar
any one got a bin thyed liek to send me other than stock, id love to see a stage 2 gm bin its okay if you dont i guess
lol
Old Jul 30, 2006 | 02:23 PM
REDSSCOUPE's Avatar
First thing is first. You need to know what a STOCK car's ECU wants to see.
You need to datalog all the sensors of the stock car under different operating conditions. I use an OBDII scanner for my laptop and datalog all of the sensors and ignition timing. I scan it under normal cruising, idle, WOT, Decell, partial throttle accell. You need to pay attention to MAF sensor peaks, MAP sensor peaks, and ignition timing peaks.
Now you want to go fast but your ECU doesn't. What to do what to do? Well for one is to trick the ECU. Put the ECU in it's happy place. Make it think that everything is OK when the truth is you are boosting the hell out of it. YOu need to reproduce it normal operating conditions by emmulating it's normal sensor outputs. Go no higher than the normal MAF sensor fequencey. No more voltage than what the MAP sensor would normally produce. You need to cap or clamp these sensors off. You need to do it to all of the sensors.
Add boost add fuel. Do not attempt to do anyting to your car with out being able to monitor whats going on. YOU NEED A WIDEBAND O2 before you change boost or attempt to tune anything.
Larger injectors. You want to run larger injectors and pull back on the MAF frequency to make it idle and run right. Well in this situataion you can take the MAF out of it's normal operating scope and result in changes of normal engine operation. (more ignition timing). You can get away with this if it is a narrow margin. Tune in the air fuel ratio that you are looking for then compair the MAF readings with your stock reading. Try and compromise with the tune and meet in the middle. I really don't recommend this method and in the end on the LSJ YOU CAN"T ADD ENOUGH FUEL to make up for the the last few 100 RPMs of the map where the ECU pulls boost.
The best way to tune is to be able to manipulate all sensors that the ECU reads. Tune your so that you do not exceed the peak Grams per second reading on the MAF and KPA on the MAP sensor. By doing this your car thinks that everything is normal. Well how do you get more fuel for the boost? You need to add extra injectors. These injectors are going to tie into your current fuel system and need to be driven off a piggyback that has Pulse Width Injection. You can inject the fuel totally seperate of the factory ECU.
You see the ECU has no idea what is going on. You can get away with Murder this way
WHICH IS THE BEST ECU PIGGYBACK TO GO WITH. I THOUGHT ABOUT THE THE GREDDY ULTIMATE E-MANAGE BUT I HAVE NOT HEARD HOW THEY DO ON THE S/C SS
Old Jul 30, 2006 | 02:27 PM
REDSSCOUPE's Avatar
How Many Horses Can The Stock Lsj Motor Hold And Also How Many Can The Stock F35 Trany Hold.
Old Aug 7, 2007 | 09:38 PM
Boosted07SSSC's Avatar
i miss my 91 obdI was so basic and worthless you could get away with anything. plus scanners for them are cheap
Old Aug 8, 2007 | 11:46 PM
Jmc007's Avatar
HPTuner is now the way to go.
Old Sep 10, 2007 | 06:03 PM
Garrettsi's Avatar
the URL don't work for me
what AFR are you tuning you Cobalt SC?
Old Aug 9, 2008 | 11:27 AM
Pully Police's Avatar
This thread should be taken down - has very bad info.
Old Dec 25, 2008 | 12:31 AM
cobaltaddict05's Avatar
were the heck is the pcm i got a stage vto one bt cant ind were the stock one is any one no please help
Old Jul 25, 2009 | 12:50 AM
my penis is big's Avatar
i have a neo and i set everything to 100% and was like **** it, my car is fast but i only like 3mpg
Old Mar 10, 2010 | 05:56 PM
dustinlee28's Avatar
just wondering if there was such a program as hptuners that is used on the Cobalt SS/SC cuz this guy is wanting to tune my car Sat. and i just wanted to make sure it was a legit tuning program??? Cuz i'm trading him my factory SS wheels for that and racing stripes for my car. So if anybody has ever heard of such a thing let me know...just wanna make sure it's legit. Thanks!!!
Old Mar 10, 2010 | 06:05 PM
Gabi's Avatar
hptuner is the best one to tune your car and yes it is legit
oh btw you will be doing the worst trade ever
Old Mar 10, 2010 | 07:04 PM
why do u say it's a bad trade???
Old Mar 31, 2010 | 06:30 PM
Smokester's Avatar
CAN SOMEONE POST THE FOLLOWING FOR ME FOR A THREAD NEED TO KNO THE ANSWER THANK YOU I APPRECIATE IT:
I have a question about the ZZP PCMS.....I recently got a new engine because my prev engine got hydrolocked.....the prev engine had injectors smaller pulley and a ZZP PCM...The new engine they put in is completely stock but still has the zzp pcm.....GM is going to put the Stage 1 kit in for me but my question is can they flash the ZZP PCM to the GM stage 1 calib for the injectors? or am i SOL and if i am what should i do?
Old Mar 31, 2010 | 07:01 PM
  #42
ebristol's Avatar
Yes. The ZZP tunes PCMs are not locked. The dealer should be able flash over the ZZP PCM.
Old Mar 31, 2010 | 07:10 PM
  #43
Smokester's Avatar
perfect thank you i was wicked nervous they were gna havta need a new pcm
Old Jun 9, 2010 | 01:27 AM
  #44
blackss/sc07's Avatar
well i got zzp tuned i like it
Old Sep 16, 2011 | 12:14 PM
  #45
Jmc007's Avatar
Yes HPTuners is now the way to go IMO.
Old May 1, 2012 | 12:46 AM
  #46
Tony Pshenichnykh's Avatar
How much does it cost to tune yourself and how much if you pay someone?
Turbo Johnny
Feb 21, 2019 09:41 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
vjoel2011
Oct 2, 2015 12:11 PM
NoBalt123
Sep 4, 2015 07:10 AM
