| Forum Jump | Gallery | Social Groups | VBgarage | Videos | Chat | Link To Us | Decals | Site Map | Contact Us |
| 2.0L LNF Performance Tech 260hp and 260 lb-ft of torque Turbocharged tuner version. Technical Discussions ONLY! |
Thread Tools | Display Modes |
#56 |
i took the premi leap.
Member #: 29926
does this delete the turbo lag in the g28 turbos then?
__________________
Victory Red 09 SS/TC l Hahn Charge Pipes l Hahn Cool Ram Intake l Greddy Turbo Timer l HKS BOV l Custom 3" Catless DP l Stock Exhaust l Dejon Spring l TTR Engine Mount l TTR Tranny Mount l Swift Motorsport Hide A Plate l LED Tails l Custom Headlights l Pioneer 4x 1000 Watt Amp l Infinity Type R 10" Sub
On the list. R1Concepts Drilled Slotted Rotors l Rear Brembo Kit l 18" Wheels l Drag Radials |
#57 |
Member #: 36317
Really? Sell your car and buy a bicycle.
__________________
#58 |
Member #: 47948
Nice work! Someone already pointed out this development to the hptuner board, but i'm sure that will be fruitless.
Guys if the high pressure side of the fuel system had a leak, it would not maintain pressure for more than a split second - i'm sure it would go into limp faster than you can say, well, anything. With all the smack downs this ECU has laid on us, i'm sure GM thought of high pressure side leaks...
__________________
Solstice GXP - hp tuned to 21PSI, AIS stage 1 meth injection, Hahn racecraft IC - 30lbs/min peak VE airflow
#59 | |
Quote:
I assume Vince tells you certain things that he also tells me?
__________________
Black '06 Cobalt LS Auto Supercharged 265 bHP
| GMPP Exhaust | Smoked Taillights | 5% rear, 15% front | Black Gen1 Projectors | 18x8 Black Kyowa rims | Nexen P3000 tires | DC Sport Strut Bar | Auto Transmission Mounts | Koni Front/Rear Struts | Eibach Sportlines | 10k low/6k high beams | ZZP Mid-Length Header/DP combo | Hayden Transmission Cooler | AEM Fuel/Ignition Controller | AEM UEGO | Black/Red Insert SS Seats, Door Panels, and Trim Pieces | High Rise Spoiler | M62 Blower | ZZP Heat Exchanger | Option B | Red Mech. Boost Gauge | Dual Red Interceptors | TTR Rear Sway Bar | |
#60 |
Member #: 42415
So you make 426 hp at 7000 rpm with a k04...
__________________
#61 | |
Quote:
idk if you remember long long ago I posted a "teaser" shot of the program but i see now he's using it for himself i didn't know he was doing that
__________________
![]() mods: go fast zzp header and DP, 3" CTI catback,trifecta t00n, who procharges a saturn NE trifecta SMP R&D ion prochaged car |
#63 |
Member #: 40080
I would ASSume hes using some internet trap speed / weight calculator.
#66 |
Member #: 26404
I trap at 112-113 in third on the 26's with a 6700 rpm limit. Every car is a little different.
__________________
09 Cobalt ss/tc vic. red, Stock airbox with ZZP airbox mod, muffler delete, CIA catless downpipe, TWM short throw, Trifecta tune. 12.287 @ 111.40
#68 |
Member #: 26574
I won't lie... I'm getting sick of HP Tuners not unlocking stuff. I may soon switch to Trifecta.
Also, I'm only trapping 110
__________________
CHECK OUT MY FOR SALE THREAD!
http://cobaltss.net/forums/showthread.php?t=191048 |
#72 | |
Sunday Driver
Quote:
Common knowledge that hp = tq * rpm/5252, so 320 * 7000/5252 = 426 Don't piss on me, I'm just saying he got it from your own words.
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
