good time at the track
Me and a friend went out to san antonio raceway tonight.... nice weather around 68f, hardly any wind, and hardly any people. So it was a good night to see what the car would do with the 2.8in pulley.
Well first run was bad lol.... kinda underestimated the power and peeled out almost half the way down the track.
next 3 or 4 runs I launched at 2k rpm and got some wheel spin and got 14.2 passes with 2.3 60ft times.
then I let my friend do a couple of passes and well he weighs about 100lbs less than me(250lbs) and he made a 14.09 run witha 2.25 60ft.
Then I made one final run and got a 14.18 witha 2.27 60ft
Now my question, since my tires are pretty old.... when my new ones come in, and I get some traction mods(solid motor, and tranny mounts, traction bars) Can I see high 13's
here are three runs from last night
1st run: is a 14.2 run vs. a RX7, I barely beat him by .2
http://www.youtube.com/watch?v=2phIoP0kp_8
another run: 14.09 run, fastest of the night
http://www.youtube.com/watch?v=Akbet...eature=channel
and the first run of the night: 15.4, couldn't get traction at all lol...forgot to lower tire pressure
http://www.youtube.com/watch?v=DAd6y...eature=channel
here is a parts list of whats on the car lol
2.8in pulley
k&N cai
vibrant header/dp
borla exhaust
I had a zzp s3 h.e. but I screwed it up >.< lol so I'm just running the stock lsj h.e.
2.8in pulley
k&N cai
vibrant header/dp
borla exhaust
Yea man, 13's def possible. You are auto tranny correct? My first pass ever at the track was in my 2.4sc 5 spd, went 13.80/2.16 60 in the heat of summer on 3.0 pulley. 2.8 should def make up for any of your AT losses. Just take it EASY on the throttle coming out!
tuned by trifecta
yeah I'm automatic.... I guess I need to play with my launches some more. I'm revving it up to 2k rpm, then when its time to go, I let off the gas and let it go, and then put the pedal all the way down.
Last edited by Dragonsfire12345; Nov 14, 2009 at 01:48 AM. Reason: Automerged Doublepost
When you get new tires, make sure to go 225 or wider. Def helps with the traction...
