Whos got a crankshaft they can look at for the J-community?
on
Either a LSJ or LE5 crank applies to the following. If you remove the crank trigger, underneath there is said to be the same crank trigger the j-body eco's have casted into the crank. Someone on the HPT forums claimed there is, and we would like to confirm this.
Thanks
Bryan
Thanks
Bryan
Bump - this is a possibly huge development.
On a related topic, what keeps LSJ guys from swapping an entire LE5 bottom end? I heard the clutch/flywheel combos are different (weaker on the LE5), but other than that you get 20% more displacement and a strong bottom end.
::sigh:: There is a ring on the end of your crankshaft that, together with a sensor, tells your ecu how fast your engine is spinning. This ring is different on jbody ecos vs the LE5/LSJ. Recently on hptuners.com/forum, somone made the claim that you can unbolt the ring on the LE5/LSJ wheel from the crank, revealing underneath the cast on ring that the Jbodies use.
No one can confrim this yet.
If in fact the ring that the jbody uses is underneath, it would make bottom end swaps much easier, and most imporantly, it would make them play nice with the jbody ecu.
on
Pyros777
12-29-2013 02:59 PM
