2.4 mani
Old Nov 11, 2009 | 05:44 PM
  #51
shawn672's Avatar
http://www.crateenginedepot.com/stor...P1817C137.aspx
is the link to the manifold kit, but PM or email CED, they used to sell just the kit itself (minus the IM)
Old Nov 11, 2009 | 06:00 PM
  #52
john_boy1987's Avatar
sweet thanks
Old Nov 12, 2009 | 12:54 AM
  #53
boltedbalt's Avatar
okay i drive a modded 2.2 CAI 2.4 intake header down pipe and exhaust and tune on the wayy...the mani was the last thing done and I loooooove it...what nitrous set up you running?
Old Nov 12, 2009 | 04:40 PM
  #54
weiss27md's Avatar
Anyone know if the 2.4 throttle body is worth it? Or is it better to just get the tune?
The bigger throttle body would help throttle response right?
Old Nov 12, 2009 | 06:55 PM
  #55
*S!CC_R@c!NG_TURTL3*'s Avatar
i think u should get the 2.4 t/b itll help you in lower rpm band but if u get the 2.4 t/b u will need a tune
im running a dyno tune nitrous set up with a 90 shot
Last edited by *S!CC_R@c!NG_TURTL3*; Nov 12, 2009 at 06:55 PM. Reason: Automerged Doublepost
Old Nov 12, 2009 | 07:36 PM
  #56
Mr.N00bLaR's Avatar
Do you really need a larger throttlebody? <---click me and read me
Old Nov 13, 2009 | 08:18 PM
  #57
Originally Posted by Mr.N00bLaR
ok. maybe since i been drinking but the 2.4 intake is not all what its supposed to do? cause i already got it and the gasket all i need it the hose.
Old Nov 13, 2009 | 09:07 PM
  #58
Mr.N00bLaR's Avatar
I'm sorry but I don't understand that post..Sober up ftw?
Old Nov 13, 2009 | 10:05 PM
  #59
yo how does ur ttr swa bar feel ? cuz i jsut ordered one
Old Nov 17, 2009 | 08:10 PM
  #60
so the 2.4 mani and throttle body is a good i dea but it wont make a differemce is what the info thread said. so i am wondering if i should put it on.
Old Nov 17, 2009 | 08:55 PM
  #61
2007victoryred's Avatar
It sounded like it is beneficial if you tune for it. But I might have read that wrong. I was getting a little confused with all the math. lol
Old Nov 17, 2009 | 09:08 PM
  #62
me too! well heres whatim going to do, ported polished head, oversized valves, stage two cams upgraded valve springs retainers whole nine yards, milled head, 2.4 mani, 2.4 throttle body, obviously a tune. so i am wondering if it is worth my while or should i go with a different mani an tb.
Old Nov 17, 2009 | 10:23 PM
  #63
Mr.N00bLaR's Avatar
Hmm..
2.2l = 134 Cubic inch
Street Strip-RPM x cubic inch/ 3456 x .85= CFM requirements of the motor
My red line is 6500 for example..
(6500x134)=871000
871000 diveded by 3456 = 252.02
Now multiply that by your estimated volumetric efficiency, assuming mine is 85%..
252.05x.85=214.22
According to the guide, you take this and multiply it by 1.5 for street and strip applications
1.5x214.22=321
Originally Posted by Old Man - EF
Now will look at some other numbers.
50mm bore at 25 inches of vacuum flows 380 CFM.
For ever 1 mm bigger is 25 CFM of flow.
These numbers are for non obstructed flows. Since we have a throttle plate, shaft, screws and what not the bore size listed for the throttle body by 70%.
I believe my 2.2 has a 57 mm throttle body as factory.
Thats 555 CFM total flow x .70 (70%)= 388.5 CFM
So unless you go all out NA you probably won't gain anything but keep reading..
Originally Posted by Old man - EF
Now we see some posts that will say NAH to this.
I FELT A BIG DIFFERENCE!!!!!!!!
Oh, I wont argue because you did feel a difference!
Now will tell you why.
You got so use to the pedal movement, its stuck in your brain even if your not a gear head.
By having a bigger bored diameter, your letting more CFM in at the same throttle position. It wants to go, it feels like it wants to go, so you believe its so much better because it wants to go. But your ECM doesnt know its suppose to. Its seeing the same input voltage it had before at the same point and is holding the same timing, which impedes it from going. Makes it surgy feeling at times when the throttle is steadily held.
In a nut shell all you've done is make it need less pedal to do the same thing. Guess what, less pedal, less timing.
If you do a serious NA build / higher rpm applications, you definately could utilize this, remember! 6500RPM is my redline in my 2.2l. You might choose 7000 or 7200k or more after your built up.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
Stuff
Oct 1, 2015 05:47 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
