Cobalt Parts Interchangeability
Old Jul 22, 2007 | 01:50 AM
  #51
kingg5's Avatar
Originally Posted by YellowLT
Here a List of all The SS Parts that fit on the Base LS LT Models
Suspension:
FE 3,5 Shocks
FE 3,5 Struts
FE 3,5 Springs
FE 3,5 Front Sway bar
FE 3,5 Control Arms
Wheel hubs
Strut tower mounts
Rear axle
FE 5 Steering rack
Engine:
Exhaust Manifold
Downpipe
Exhaust
Intake Manifold (Will Physically fit but TB will not bolt up)
#32 Injectors Fit Leak free, Tuning is needed.
Interior:
All of It
Exterior
Front Fascia
Rear Fascia
Rocker Panels
Deck Lid w or w/o Wing
Rims (07 only if you have factory alloys wheels.)
Headlights (SS are slightly tinted. I believe 07 has no orange reflector over DRL)
If you have anything else, I'll be glad to add it.
does this mean that i can buy the wheel hubs from a GT or an SS and put them on my base model G5 thus giving me 5x110 ?
Old Jul 22, 2007 | 01:49 PM
  #52
alexo06's Avatar
what about transmissions, would a ss/sc lsd trans work in a ls, or would it just be easier to put in an aftermarket lsd in my ls.
Old Jul 22, 2007 | 03:42 PM
  #53
montecarloman's Avatar
It would require the new Hub which would mean you would need new rims in the back. You would have to change to the 5 lug. Stainless steel brake company makes a kit to do rear Disc in our car.
Actually I figured a way around that. Our rotors/drums are hubcentric in design. All you need to do is get the 5 lug rotors, mark the stud location and drill the 4 bolt pattern.
Old Jul 23, 2007 | 09:50 AM
  #54
YellowLT's Avatar
Technically Yes, do i think it's worth it? No.
PICS?????????
The SS S/c uses a different tranny so i would assume that their LSD wont work in our tranny. I know one guyh on here did the tranny swap. but thats alot of work. If your gonna swap a tranny go for the SAAB 6 Speed
Old Jul 23, 2007 | 09:51 AM
  #55
sick06cobalt's Avatar
some company makes a drum to disc conversion kit for our car guys and you dont need to do any drilling or anything to make them work..
Old Jul 23, 2007 | 09:53 AM
  #56
YellowLT's Avatar
Yup Stainless Steel Brake Company
Old Jul 23, 2007 | 09:55 AM
  #57
So why go through all that work and get a 5 x110 when you could get a 4x110 or whatever and keep your wheels if you have any..and you dont have to do any serious mods for it,
Old Jul 23, 2007 | 11:32 AM
  #58
YellowLT's Avatar
The other thing being that the rim selection for 4x100 is huge. 5x110 isn't.
Old Jul 23, 2007 | 12:51 PM
  #59
How much is that kit though? I priced everything new and if I remember correctly it was only $1100.
Old Jul 23, 2007 | 01:11 PM
  #60
i could be wrong but i think its ~1100 +or -
and I would rather have something that is professionally done
Last edited by sick06cobalt; Jul 23, 2007 at 01:11 PM. Reason: Automerged Doublepost
Old Jul 23, 2007 | 01:37 PM
  #61
YellowLT's Avatar
http://www.stainlesssteelbrakes.com/...balt&year=2006
Old Aug 8, 2007 | 06:47 PM
  #62
Novajoe's Avatar
I don't really see what the main problem is with swapping the fuel injectors. I'm looking to put the ss s/c on my l61. So just sitting here thinking about it...
Main problems-
air/fuel ratio-- swap the injectors and regulate fuel pressure to a good ratio
swapping the stock injectors out for higher volume injectors would make the pressure run lower than normal at WOT and such. So all you would have to do is regulate your pressure to run it. A supercharger provides constant boost so it requires alot less tuning than say a turbocharger so a rising rate regulator isn't needed. I dunno if there's a fuel pressure sensor on these cars, but even if there is the sensors generally work through resistance so it wouldn't be hard to wire the resistance to stock specs.
Another problem is the MAF/MAP sensor. I'm not too familiar with this engine style but just going out and taking a quick look under the hood, I don't see EITHER ONE. Just an air temp sensor. I know the BCM has to have some way of reading how much air is intering the engine so if someone could point me in the right direction on this one it would be appreciated.
The only other potential problem I can see is the O2 sensors, but with the right tuning that shouldn't be a problem
Now before anyone chimes in and tells me "there's no tuning for our cars", I'm not talking about piggybacking or ecu tuning. I'm talking about old-schoolin it with a 1:1 fuel pressure regulator and possibly a missing link or something.
Old Aug 8, 2007 | 06:57 PM
  #63
en0onmai's Avatar
The MAF is located inside the tube sticking out of the air filter box. There is a plug and harness there. the MAP sensor is under the fuel rail and throttle body mounted in the top of the intake manifold. Its hard to see but it is there.
Wouldnt the computer "tune out" the SS/SC injectors since the voltage or pulsewidth isn't the same?
I was thinking along the same lines as you are. A missing link setup. Using the MAP sensor from the SC setup to fool the computer with the voltage. Then use a MAF Translator to keep the fuel rich...? Who knows?
Old Aug 8, 2007 | 07:20 PM
  #64
Novajoe's Avatar
injectors recieve info from the computer. they don't send any out. Swapping injectors out is the simplest thing in the world it's just getting around the other stuff that gets complicated. The pulswidth is regulated by the ecu, not the injectors and the voltage isn't really going to make a difference since the solinoids are relatively the same.
Upon looking at the map sensor I'm probly going to go with a voltage based map clamp. Hooking up a missing link looks like it'd be more trouble than it's worth the way our MAPs are hooked up to the manifold.
As far as the MAF goes, I'm gonna try to just route it somewhere with less air flow to see if I can trick it. If that doesn't work then I might spring for a translator.
I'm gonna try to see if I can't find some specs on the ss MAP/MAF just for reference
then again I still need to find a supercharger/manifold setup from an ss...
Old Aug 23, 2007 | 05:29 AM
  #65
Tundraboarder666's Avatar
intakes
quick question, can i put a intake on my '07 cobalt ls with the 2.2 ecotec engine if it says it is for the 2.0L ss engine? are the 2 not the same? Because I don't want to have to spend over 200 on just the intake for it.
Old Aug 23, 2007 | 09:35 AM
  #66
shawn672's Avatar
No Tundra, the intakes are totally different, the 2.0 is even on the wrong side of the car to fit a 2.2...
Old Aug 23, 2007 | 02:44 PM
  #67
damn, any recommendations on what would be the best thing to get me the most hp but also not too expensive
Old Aug 23, 2007 | 03:06 PM
  #68
shawn672's Avatar
if you have a late model 06 or 07..that has SAI, you are limited to a K&N intake. Otherwise check out Injen's models. Unfortunetly CAI/SRI's are all overpriced if you ask me. I had one custom made for 1/2 the price from a local steel shop
Old Aug 23, 2007 | 03:20 PM
  #69
yeah the cheapest i could find was a $215 one. but yeah i was thinking about just going down to autozone and them customize me one for like 100 bucks probably
Old Aug 23, 2007 | 03:40 PM
  #70
shawn672's Avatar
the only problem with those custom ones from places like autozone is it looks ugly imo
its a bunch of pieces all fit together, you'll end up having like 6 pieces of metal all screwed toghether.
you can go my route, go down to a local metal shop with a picture of a CAI and ask them roughly how much it would be to make something like that.
Old Aug 23, 2007 | 03:49 PM
  #71
true but i mean i dont really care what the thing looks like under the hood. i care more about the performance it will give me and maybe giving a little bit meaner of a sound
Old Aug 23, 2007 | 04:12 PM
  #72
shawn672's Avatar
gotcha. im all about performance and looking clean, especially under the hood. this thing looks messy, but it does a decent job im sure
Old Aug 23, 2007 | 04:35 PM
  #73
Those autozone custom jobs dont give you like any more power... if anything you can go injen... oh and they have figured out how to delete the SAI code so you can use anything
Old Aug 23, 2007 | 06:41 PM
  #74
shawn672's Avatar
ya but we've only found one guy who will delete SAI...whats the chance you're willing to drive to Maine? lol
Old Aug 23, 2007 | 07:38 PM
  #75
lol thats why i have an 06
