Forum Jump Gallery Social Groups VBgarage Videos Chat Link To Us Decals Site Map Contact Us
Cobalt SS Network Forums
The Cobalt SS Network is the leading resource for all Chevy Cobalts and related Delta
platform cars. Registered users do not see the above ads. Please Register - It's Free!
Supporting Vendor Index | Vendor Forums | Site Apparel
Go Back   Cobalt SS Network > Engine Technical Discussion > 2.0L LNF Performance Tech
Technical Discussions ONLY!
Thread Tools Display Modes
Old 07-03-2008, 12:10 AM   #1
EcoBoost
Supporting Vendor
EcoBoost's Avatar
Member #: 8612
Check out my gallery  Check out my vbgarage
Hahn Debuts the SS/TC at the track
Cobalt SS/TC Product Development Testing, 7-01-08
Elevation: 660 feet
Conditions: 77-84 degrees, high humidity, 2500 feet adjusted altitude
Modifications:
• Hahn RaceCraft 3” SS CatBack Exhaust
• Hahn/BSR PPC Tuner
Weight with driver: 3165 lbs.
Boost Level: 21-23 PSI
Fuel: Shell 93 Octane
Video Links (dig the SRT-4 and Civic being ownt!)
http://videos.streetfire.net/video/H...1-4_169448.htm
http://videos.streetfire.net/video/H...2-4_169449.htm
http://videos.streetfire.net/video/H...3-4_169451.htm
http://videos.streetfire.net/video/H...4-4_169452.htm
Time Slip
Driving Impressions:
Overall, the Cobalt’s driving dynamics are impressive. On the road, its suspension is super-poised, with .90G cornering capability, and a taut but smooth and supple ride. There’s no harshness for such a competent car. Cornering is the best I’ve experienced in a FWD car, and I am seriously considering autocrossing it as well. Braking is also superb, with front Brembo brakes and well-balanced ABS.
Tuned at the Nurburgring, it’s apparent that GM’s Performance Division put extensive effort into the handling dynamics of the car, also setting a world record with it at The Ring. This immensely capable package is not quite as well-suited to dragstrip use, for the low-profile tires and significant low-end torque of the car make it challenging to launch hard. However, this is not unusual, for no one wheel/tire combination can do it all, and great handling, low-profile tires just can’t create the footprint needed for strong dragstrip launch performance.
The direct-injected (DI) engine is almost eerily smooth! At lower RPM, where port-injected engines can be a bit rough, causing you to downshift, this DI engine is just as content as can be. It begs to be shifted early in regular commuting, which can only help fuel economy. I also find myself not remembering to upshift in cruising mode, as the engine is not buzzy when revved. Overall, this is one smooth operator!
On to the Track!
The car does really fun 2nd gear burnouts, as the videos will show. Fact is, I was overdoing the burnouts, but it was hard not to...the car just boils the tires once they get moving! Next time I will take it easier, but tonight was time to have some fun with the new toy.
I first tried the stock launch control, and quickly moved past it. I don’t doubt that with more track time, one could optimize it more, but I was on a mission, and I needed to get right to the best launches I was capable of. It seemed that the aggressiveness of the launch control system was more targeted for street-style traction, not the much harder bite of the dragstrip.
Launching conventionally, with a few whips of the throttle to spool the turbo, netted me much better results. I got to the 2.3 and 2.2 range of 60-foot times immediately. But tirespin was still evident, and I knew I’d have to really tiptoe through first gear to get the results I craved.
13.60’s came quickly as I continued to refine my launch technique. I also experimented with conventional shifting, then with ‘no-lift’ shifting. While the ‘no-lift’ shift seemed quite foreign to me, after a few passes trying both methods, I realized it was the way to go. Standard shifting, while effective on the street, was less effective at the track, especially once I got comfortable with ‘no-lift’. My experience with drag racing my 11.9 second Solstice has taught me that these ETC (Electronic Throttle) cars are just not the same as manual throttles for fast upshifts. Data shows no matter how quick you are, there is a lag from throttle closing to re-opening. Sure, it’s fractions of a second, but in drag-style upshifts of 0.3 seconds, a tenth is 33% longer, 2 tenths almost twice as long. These longer throttle closed times diminish turbo response as the throttle opens in the next gear. So, no-lift shift was the way to go if I wanted the best possible Elapsed Time (ET).
Fortunately, my PPC Tuner also extended the redline in 1st and 2nd to 7000 RPM. This is effective to keep the driver from hitting the rev limiter with the faster revving additional power enables. The 3rd – 4th upshift came a bit earlier, at 6200. Very little time spent in 4th, but running out 3rd with no upshift is not a possibility with 105+ MPH trap speeds.
The last two passes of the night saw me really figure it out. I skipped right past the 13.50’s with a 13.45, and while there was still a lot of tirespin in 1st, I knew I was closer than ever to the sweet spot. I was right! Next I skipped right past the 13.30’s (and almost the 13.20’s!) with a solid 13.20 @ 104.33 pass. The 2.09 60-foot time was far and away the best of the night, and the rest of the pass was spot-on, with perfect shift points. I tend to save the best for last on these nighttime tuning sessions!
What could stand improvement?
Well, even though these are excellent numbers for a car with just an exhaust and a tune, the current package is not optimized…yet. Weather was poor for high power.
The tire combination can be improved dramatically. As a skilled FWD racer, it took me a number of passes to coax out that 2.09 60 foot. I’ve been as quick as 1.79 on small drag radials with my SRT-4. That alone would take this car into the 12.80’s easily, even in the same weather. The still relatively new engine may also develop a bit more power as the piston rings seat in fully.
Intake air temperature data was collected and analyzed. The temperatures, especially deep into the run, can be improved with a more efficient intercooler. The stock piece, while fairly good-sized, uses the typical tube-and-fin type core common to OEM applications. It heats up more quickly with the additional airflow and boost we’re making now. We’ll apply an intercooler very similar to what we currently build for this LNF turbo engine in Solstice and Sky. These intercooler units are massive, and not only improve peak power and reduce heat intake to the engine, they also improve low-speed turbo response.
And that’s what we will do next. First improve traction, and then upgrade the intercooler. We should have more results later this month!
What else are we working on for SS/TC?
• Performance Intercooler
• Air Intake Upgrade
• Intercooler Tube Upgrade
• Blow-Off Valve Upgrade
• Downpipe / Cat Con Upgrade
• Turbocharger Upgrades (a couple of flavors TBA)
All of these items will be complimentary to one another, as well as to our SS 3” Cat-Back Exhaust and PPC Tuner. Using them as a system will allow one to avoid the problems we’ve seen with mixing up items from different vendors on Solstice GXP and Sky Redline (other cars we’re noted for that feature the turbo LNF engine).
What should I get first for my SS/TC?
Hahn/BSR PPC Tuner and Hahn 3” SS exhaust. Without a doubt, as we’ve proved in other turbo LNF applications, this is the best bang for your buck.
What are the goals of our SS/TC development program?
We intend to meet, and then surpass, the performance of our SRT-4 program, which resulted in 11.8 second, 122 MPH runs with true bolt-ons and street tires. In doing so, the car must retain 100% daily driveability and fuel economy, with no tradeoffs to the new power level save for excessive tire wear!
__________________
Bill Hahn Jr.
Hahn RaceCraft Product Information: for questions prior to purchase
Hahn RaceCraft Order Information: to place an order, or to inquire about an existing order
Hahn RaceCraft Technical Support: for technical support with Hahn products or Hahn-equipped cars
EcoBoost is offline   Reply With Quote
Old 07-03-2008, 12:15 AM   #2
diablo9287
Member #: 22815
respectable cant wait to get a ss/tc as well as ur catback and tune
diablo9287 is offline   Reply With Quote
Old 07-03-2008, 12:15 AM   #3
Sizzle06
Sizzle06's Avatar
Member #: 12641
Images: 94
Awesome!
__________________
07 SS/SC G85,PERFORMANCETVS,OTTP 3" Intake,P&P TB,CA V2Header,ZZP DP,Tsudo Exhaust,HPTUNED,ZZP H/E,79's,JET MAF Sensor,NGK V-power,Hurst STS,Option B W/OTTP Brackets/ EXTERIOR:Victory Red Headlights with HID's,Modern Performance LED Tails,SS Lower Grille,Wingless,18"Motegi SP5's /INTERIOR:ZZP 3 Pod Pillar,Aeroforce Interceptor,GMPP Pedals/Armrest,GM SS FloormatsSUSPENSION,STEERING:SCC Springs,SS/TC Shocks,OTTP Rack Spacers,OTTP Stage1 Mount,OTTP 1" Rear Sway bar
New#'s 340whp/276tq
Sizzle06 is online now   Reply With Quote
Old 07-03-2008, 12:16 AM   #4
pimpnwink
Member #: 7362
Images: 2
oh no look what you are going to make me do... I have to fight it despite the gas costs I need to get the new camaro ss LOL great times very nice to hear.
__________________
TTR=the shit
pimpnwink is offline   Reply With Quote
Old 07-03-2008, 12:18 AM   #5
JRelly
Member #: 12266
Images: 5
Great numbers
__________________
JRelly is offline   Reply With Quote
Old 07-03-2008, 12:20 AM   #6
ColeJJones
Bannned
ColeJJones's Avatar
Member #: 19837
Images: 60
holy shit! you are almost in the 12s with less than nothing mods.... its takes alot money to get our cars that low. i am wrong about the TC, there is serious potential. this is fuckin sick! epic
__________________
2009 Cobalt SS/TC. BlackBlackBlack
Fight ME!!! http://colejjones.mybrute.com/
Quote:
Originally Posted by robertwhamm View Post
I am selling these front bumber carbon fiber side wings...
ColeJJones is offline   Reply With Quote
Old 07-03-2008, 12:28 AM   #7
04redline0124
Member #: 18112
Quote:
x2 man amazingt job...u wnna drive my car then? lol...i can trap 116 soo you tell me what you can run haha
__________________
I haz a vehikle that spinz all fourz
04redline0124 is offline   Reply With Quote
Old 07-03-2008, 12:30 AM   #8
Deathscythe
Deathscythe's Avatar
Member #: 9149
Images: 12
those runs in the videos are awesome. Maybe all of us could have taken advantage of this had the car come out three years earlier. Still love my ss/sc though.
__________________
Prepare for the rebirth of the Phantom...
I'll still smash your face.
320whp/ 250 wtq
Deathscythe is offline   Reply With Quote
Old 07-03-2008, 12:30 AM   #9
elecblue06
Member #: 14949
Images: 3
damn man .. fucking sexy great job.. great job... you guys are going to make a shit load of people happy..
but now there are going to be alot of turbo balts out there now.. i think lol
__________________
mods: go fast zzp header and DP, 3" CTI catback,trifecta t00n, who procharges a saturn 252 whp 209 wtrq at 7 psi LAWLZold number.. now at 10-11 psi more to come MUAHHAHA NE trifecta
SMP R&D ion prochaged car
elecblue06 is offline   Reply With Quote
Old 07-03-2008, 12:31 AM   #10
Mss26
Member #: 23351
Images: 21
Wow.. nice runs! Stage 2 say what?
Mss26 is offline   Reply With Quote
Old 07-03-2008, 12:32 AM   #11
chris88z24
Member #: 17140
Very impressive. Nice job. And 2.09 60', damn!
__________________
chris88z24 is offline   Reply With Quote
Old 07-03-2008, 12:37 AM   #12
choko
Member #: 27064
Bill - I and someone else already broke our shift linkage for up/2nd,4th and reverse gear on the tranny end. I know your at the track alot also, so keep that in mind, they are very cheasy carbon plastic.
So maybe an upgrade for that to? im sure youll see more broken as more cars hit consumers hands.
choko is offline   Reply With Quote
Old 07-03-2008, 12:42 AM   #13
Deathscythe
Member #: 9149
Images: 12
already?
__________________
320whp/ 250 wtq
Old 07-03-2008, 12:42 AM   #14
firemanfrank
Member #: 16876
Quote:
We say "Bring it on sucka!"
__________________
Stage 2 + 0
227whp/203tq
(Dynapack Dyno)
"Evolution" Without God?
firemanfrank is offline   Reply With Quote
Old 07-03-2008, 12:43 AM   #15
Zven
Member #: 7054
subscribe
__________________
2008 SS/TC: HPT Tune Stock 1st gear. 22-23lbs boost everywhere else.
68' Toronado: Stock 455 cid. Rocket 400HP/ 500lbs tq.
Zven is offline   Reply With Quote
Old 07-03-2008, 12:43 AM   #16
ColeJJones
Bannned
ColeJJones's Avatar
Member #: 19837
Images: 60
so what can the stock engine hold as far as power when you guys upgrade to the super 20g?
__________________
Old 07-03-2008, 12:44 AM   #17
sherm420
Member #: 16686
Images: 1
bill u r the man!
__________________
hp tuned + Hahn Exhaust +CIA D/P + 10k 3rd gen halo= mods
sherm420 is offline   Reply With Quote
Old 07-03-2008, 12:47 AM   #18
Mss26
Member #: 23351
Images: 21
So was this on drag radials since you were doing burnouts?
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©Cobalt SS Network - All posts are the opinions and copyright of the original authors and must be referenced with a link.
This site is not affiliated nor endorsed by General Motors. Chevy Cobalt and related trademarks are the property of GM.
