Power Steering Problem
Old Oct 28, 2008 | 04:10 PM
matt05sc's Avatar
If your having a Power Steering Problem file a complaint at this website. http://www-odi.nhtsa.dot.gov/ivoq/index.cfm If you don't report it GM will never fix it. Also file a complaint with GM's national customer service.
Old Oct 28, 2008 | 05:21 PM
Halfcent's Avatar
I'm old school
Perhaps you could tell us what the exact problem is?
Old Oct 28, 2008 | 05:30 PM
06blackg85ss's Avatar
or is it the same problem as the ss/sc.... bad connection in the fuse box... easy fix... push the connector back in.
Old Oct 29, 2008 | 09:09 AM
matt05sc's Avatar
Powersteering flashes on the speedometer display and then the car loses powersteering. Let the car rest for a while and it comes back.
Old Oct 29, 2008 | 09:19 AM
distillion's Avatar
something similar happened to me.
loose fuse, pushed it in, issue fixed.
Old Jan 4, 2009 | 08:59 AM
JasonLives88's Avatar
i'm having the same problem right now.
Old Jun 10, 2009 | 05:55 PM
tanelk's Avatar
i been driving my car without powersteering for 1 year now, im not about to pay $1000 to get it fix. its no big deal to me anyways, only makes you a better driver
Old Jun 19, 2009 | 04:12 PM
player_1's Avatar
I lost my power steering already once to, and it wasn't a fuse issue.
the motor went on it. I drove for a while without it to but the wife was having trouble, so I bought one from a scrap yard, it's been working fine ever since, had to replace the hole column, the motor cannot be removed
Old Jun 19, 2009 | 04:21 PM
tony2toness/sc's Avatar
Loose fuse ??? Wtf where I've been driving around for almost a year and a half now with no power steering were would the bad connection be located at or fuse I gave up trying to fix it without wasting money lol
Old Jul 12, 2009 | 05:51 PM
tanelk's Avatar
are you sure you cant remove the motor, i thought it was the one located under the steering wheel that is black. i found a used column for $250 at a junkyard also but im iffy on buing something used.
Old Jul 19, 2009 | 06:36 PM
cobalt123's Avatar
i had problems with my pscm, when i had my wreck, the shop thought it was due to the wreck, which it wasnt, so they replaced it brand new
Old Jul 19, 2009 | 06:37 PM
cobalt123's Avatar
Solaris99
28
Mar 15, 2017 01:22 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Stuff
Oct 1, 2015 05:47 PM
Sep 26, 2015 06:44 PM
