lowest iat2 you've seen
I just came back from Tennessee/North Carolina. Even in 24 deg temps and cruising on the highway I never could get the iat2 temps below 60deg. Normally when cruising for long distances i south Florida the iat2 will get to 18-20 deg above the outside temp. So I should of seen iat2 temps in the 40's according to how I run in Fl. I have no cooling mods and a stg2 pulley but the temps are fine in florida.
Is the intercooler pump set to only allow the iat2 to get to 60?
normal driving my IAT2s are always 30 over IAT1
at WOT it is always around 135, whether it is 80 degrees out or 35. I cant get over 135 though. Even if i run it to 150 mph.
Before the H/E it was always at 160ish after WOT run and 40-50 over IAT1
If you have hptuners, when you log your car, it comes up to reading...
Or you can by a interceptor.
which is an electronic gauge.
I just got my interceptor last week and I see iat2's are usually 5-12 degrees above outside temp when city driving and are lower when on the highway, usually 3-8 degrees above outside temp haha gotta love the hahn intake manifold
damn turbo people with low iat2's lol.
If you have an interceptor and it gets really cold out, when you start your car the iat2 can be really low like 20 or 30 give or take. However once the car reaches operating temp my iat2's generally sit around 55-60 in the winter. With a hard back to back to back pull its hard to reach 100. You gotta love methanol lol.
In the summer my peak is about 130ish with the 2.8 and cruise is about 20-30 over iat1.
Don't forget that its bad to beat on these cars in the winter!! They will lean out!!
my high of the week was just set.
42deg AIT2 after 1st/2nd pull.
36deg out side
my summer high was 103 after a solid 1-2 and 3/4 3rd gear pull
it was high 70's out.
36deg out side
