LNF cams
Old Mar 1, 2009 | 09:05 PM
riko540's Avatar
LNF cams
I found a post I thought was interesting and might help the people who are running turbo setups on their LE5.
Originally Posted by JBP
LSJ and L61 cams are interchangeable up until 2006.
The only difference is the timing;
'06 L61 116 Intake, -103 Exhaust
'06 LSJ 100 Intake, -115 Exhaust
2007 L61 intake cams are not interchangeable with any other ecotec cams.
2007 L61 exhaust cams are interchangeable backwards to a previous model year L61 or LSJ
LNF and LE5 exhaust cams are interchangeable with each other but not with any other ecotec cams.
All LSJ cams are interchangeable.
Thanks,
JBP
If the cams are interchangeable, this might be an alternative from doing a custom regrind. Also does this mean that any aftermarket cams for the LNF will work too?
Thoughts on this?
Old Mar 1, 2009 | 09:54 PM
mmcgee123's Avatar
Itd be sweet to kno this for sure
slowswap's Avatar
Exhaust cam's are interchangeable, that does not mean the intake one's are.
Old Mar 1, 2009 | 09:55 PM
PRND3L's Avatar
i dont know, the LNF is going to have a gear on one of the cams to run the injection pump.
Old Mar 1, 2009 | 09:58 PM
slowswap's Avatar
Which will be the intake most likely.
Old Mar 1, 2009 | 09:59 PM
PRND3L's Avatar
i think you are right.
Old Mar 1, 2009 | 11:52 PM
celicacobalt's Avatar
would be nice to see some results from someone doing this.
Old Mar 2, 2009 | 04:24 PM
riko540's Avatar
thats the down side I don't think the intake cam is interchangeable. But if it is the guys with turbo might see some decent gains.
Old Mar 2, 2009 | 06:29 PM
slowswap's Avatar
The intake cam on the LE5 is more agressive then the LNF intake cam, but is not swappable.
The exhaust cam on the LNF is more aggressive then the LE5 exhaust cam and IS swappable.
So the LE5 guys can use the LE5 intake cam with the exhaust LNF cam and have most aggressive factory cam setup possible, but this will only work in the LE5.
Old Mar 5, 2009 | 01:03 PM
Turbo06Sedan's Avatar
I've got one on order, will let you guys know how it works out when i get it in and running.
Old Mar 5, 2009 | 03:07 PM
slowswap's Avatar
If you can find adjustable cam gears that fit the cams, you could greatly increase your numbers by changing the amount of overlap the cams see.
Old Mar 5, 2009 | 08:23 PM
riko540's Avatar
I do have a question though, is it safe to just swap one cam? I wouldn't want anyone to damage their engine now.
Old Mar 5, 2009 | 08:32 PM
slowswap's Avatar
Won't do any damage unless you can't time it properly.
Old Mar 6, 2009 | 08:19 PM
riko540's Avatar
I never heard of anyone just swapping one cam on a DOHC engine so I wasn't sure.
Old Mar 9, 2009 | 09:48 AM
justypontiacg5gt's Avatar
can this cam go in a NA 2.4 or does it have to be turbo'd?
Old Mar 9, 2009 | 12:17 PM
slowswap's Avatar
This is a DOHC motor. You can adjust cam overlap with adjustable cam gears.
Old Mar 9, 2009 | 10:12 PM
sooo thats a yes? lol
Old Mar 9, 2009 | 10:13 PM
Old Mar 17, 2009 | 09:02 PM
yay you for a triple post!
Old Mar 18, 2009 | 05:38 PM
riko540's Avatar
wow never seen a triple post before
Old May 16, 2009 | 10:47 AM
riko540's Avatar
Did you ever get this done?
Old May 16, 2009 | 11:09 AM
rockstar014's Avatar
wat about 2.4 sc??
Old May 16, 2009 | 11:36 AM
riko540's Avatar
Originally Posted by rockstar014
wat about 2.4 sc??
It might work but I really don't know.
Old May 16, 2009 | 11:44 AM
elecblue06's Avatar
it's swappable for any 2.4 however.. it wont be a good grind if you're sc'ed will it work? yes.. will it give some gains.. probably... but it wouldn't be optimal
