WHP limits
Old Mar 20, 2009 | 12:34 AM
Redefined1's Avatar
WHP limits
wondering what the whp limit for the internals/block are on our cars(2006 ss/sc). Also how much can our axels withstand? thx for any help. please dont post if you dont have any facts to add.
Old Mar 20, 2009 | 12:37 AM
XM15's Avatar
There is no set answer. The tune will have alot to say about the limit. There are guys that have run 300-400 whp and been fine, and then there are guys whose #4 piston went at 250whp.
Old Mar 20, 2009 | 12:45 AM
Redefined1's Avatar
well i have the mods listend below and seem to be running just great. i have not dynoed yet but i assume i have atleast 275whp and about 250-260ft lbs of torque. im wanting to drop down to the 2.5 add my dual pass, port the blower and TB. hopefully i will be within my limits
Old Mar 20, 2009 | 12:47 AM
XM15's Avatar
With a 2.5 heat will be the killer, but you know that. You seem to have the right cooling mods. Good luck.
Old Mar 20, 2009 | 12:56 AM
lsjwannabe's Avatar
The limits of most parts depend on two things the user and the tuner. If you constantly beat on your car you could have problems, if your tune is off you will have problems.
That being said people have an over 400 whp on stock internals. My car spent the majority of its time on the 2.5" ring and the mods you have listed plus some.
Old Mar 20, 2009 | 01:02 AM
Redefined1's Avatar
well, suggest those mods to me(the ones i dont have). my tuner will never be the problem. hes one of the best ive seen. he watches out for me and my little yellow balt lol
Old Mar 20, 2009 | 04:05 PM
StevesBlack06's Avatar
i have herd of 400+ as well on stock internals but i wouldnt hessitate to tell those ppl they are out of their minds. its all about how safe you want to be. if you plan on pushing 400+ whp i would replace EVERYTHING because you already have it torn apart, in my opinion if your not going to do it right then its not worth doing at all... as for axles you can get away with about 300 give or take but if you get a set of stickies you shear them for sure. ppl have broken them with less...
Old Mar 20, 2009 | 04:10 PM
Area47's Avatar
Rent me! per hour
350+whp on mine. 400+ at the crank. stock head. stock bottom end
67k miles.
you HAVE to know what you're doing. period. end of story.
Old Mar 20, 2009 | 04:24 PM
i agree if you start cutting corners or half assing stuff thats what will kill you. thats why im in the boat im in. i rushed to put mine back together and i ended up shearing a rod bolt because i overtorqued them.
Old Mar 20, 2009 | 04:29 PM
06blackg85ss's Avatar
440whp 400wtq. original stock motor, 44,000 miles, beat on it every time I take it out.
was at 296whp on a 2.55 pulley and all bolt ons for over a year with about 100 track passes, have about 200 highway pulls on this turbo setup, and maybe 30 track passes on this turbo setup (all easy launch though for tuning purposes).
Old Mar 20, 2009 | 04:30 PM
Maxim_X's Avatar
67k miles.
^^IDK about that, I have no idea what I'm doing and it's working alright for me.
But in all honesty, the motors can handle quite a thrashing for stock units. My car has been beat up since new and it has had some horrible setups on it back in the day. I would say with any sort of safe tune 300- 325WHP is definitely within it's bounds. After that you have to be a bit more careful with what you do.
Old Mar 20, 2009 | 05:12 PM
kwest's Avatar
67k miles.
yup yup. you can break your axles with stock power if you dont drive it right. and as for dropping down to pulley size and being safe...anything below a 2.8incher is over spinning the blower. Thats what Eaton said themselves...
Old Mar 25, 2009 | 01:42 PM
Rodimus_Prime's Avatar
I think some of your definitions of a "stock" motor are also not correct. Adding valve springs or changing cams does not mean your running a "stock" motor its internally modified.
Old Mar 25, 2009 | 02:15 PM
ok well my motor is 100% stock down to all the orignal everything in it that came from the factory.
Old Mar 25, 2009 | 02:24 PM
well thats pretty impressive its holding 400+ with nothing done internally
Oct 27, 2015 01:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
