Dyno Results Dyno pictures, videos and dyno results.
w00t, hit the dyno ;)
Old Mar 22, 2009 | 11:49 AM
GTPprix's Avatar
Well I finally got to hit the dyno to finish up my tuning, AF and boost were perfect (as perfect as you can get with the stock turbo DOH!) just was waiting to dial in some timing. This was on 93 octane winter blend (blah) in 68 degree ambients and hot. I think cold this car would be good for 340WHP or so but thats for another day Anyhow this thing loves timing up top! That said, i'm out of turbo up top as well
Old Mar 22, 2009 | 11:50 AM
JsavageSS/TC's Avatar
Hell yeah man.....Good numbers......
Old Mar 22, 2009 | 11:53 AM
CptTheAlex's Avatar
What color is your car, where are your normally driving around at?
ColeJJones's Avatar
Bannned
post this in the dyno section....
Old Mar 22, 2009 | 11:55 AM
CobaltSS 16's Avatar
Damn, nice numbers. Mods?
1badBlueberrySC's Avatar
Those are some good numbers man!
Old Mar 22, 2009 | 12:25 PM
GTPprix's Avatar
Dark Red, with the low spoiler (I'm east side and west side just depends on the day ) and yes I guess I'm a tard and didnt realize there was a dyno section ROFL I'll post that in a minute. Mods are Hahn coolram/catless dp/intercooler/charge pipes/exhaust and alot of tuning. Of note here is that again these were ALL hot pulls, once hot the power is damn near DEAD ON every pull due to the intercooler keeping charge temps controlled. Everyone was VERY impressed with this thing.
Old Mar 22, 2009 | 07:50 PM
radtasticniKKi's Avatar
Awesome numbers Chris!! I was excited (and jealous) when I heard the voicemail you left me
Let me know when you're available to tune mine
Old Mar 22, 2009 | 09:15 PM
GTPprix's Avatar
Sure thing, whenever you want
Old Mar 22, 2009 | 09:20 PM
INDColtsFan18's Avatar
Wow these cars are tourque machines.
Old Mar 22, 2009 | 10:36 PM
Matt M's Avatar
Nice numbers, Chris. How must boost are you running these days? 3rd or 4th gear pulls?
Old Mar 22, 2009 | 11:42 PM
cobaltssoverbooster's Avatar
pulls are in 4th its 1:1
my graph looks like this too even though turbo falls to 18lbs im flowin 33.5 lbs/min haha thats pretty sweet on stock turbo.
Old Mar 23, 2009 | 06:40 AM
GTPprix's Avatar
Well that little spike you see at the bottom where it makes peak torque is about 24-25 PSI I was going to tune it out but its not knocking there and it comes down pretty quickly so at the bottom of the pull its making about 20-22PSI down there slowly dropping to about 18ish as I run out of turbo on the top and start cranking in a bit of timing. The pulls were done in third as third is 1.18:1 and fourth is .89:1 so without a true 1:1 I figured why beat the thing any harder than it needs to be third is close enough
Old Mar 23, 2009 | 09:59 AM
Matt M's Avatar
Ok, cool. I was just wondering. We have been using 3rd gear as well. How much timing are you running up top? These LNFs sure don't respond to timing the same way LSJs do. Or most motors for that matter.
Old Mar 23, 2009 | 11:34 AM
GTPprix's Avatar
Yeah no kidding! down low I dont have much timing in it I believe about 7-9 degrees until the pressure starts to fall off then I'm to about 14ish at the top it seems to be ok with that (no knock).
Old Mar 23, 2009 | 02:00 PM
Terminator2's Avatar
My car is also at 7-10* down low and 14-15* up high. DI pistons are very similar to diesel pistons except for the compression ratio. I believe given the motors VE more timing is not necessary as the mixture takes very little time to burn. I would definately take your 68* ambiant temps over my 80*+ temps in florida.
biniecki
Oct 25, 2015 02:23 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
