10 Months in waiting...
10 Months in waiting... Rebuild done
Got the car started finally. Only ran for few mins cause of the hour that it was (2am). Sounded pretty good, like no tapping and that, but sounded mean too. im going to go out later today n get some vids of driving if i remember the video camera.
The build was a long vigorous one and finally done!
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/car-f-cked-pics-141579/
^^thread for long build^^
lots of pics. pages 1, 3, 7, 8 (18 posts per page setting)
soon off to the dyno and track
EDIT: WONT IDLE... HELP
so... so far:
Maf and Map sensors - Brand new, installed right
Vacuum Lines - Checked, no leaks
Spark Plugs - New stockers, getting a good spark @ .36 gap (i think)
Injectors - Brand new
TB - Brand new from dealer
Gas/Filter - Sittin in tank since Oct. (needs checked)
Compression/Leak Down Test - Gettin done this week
ANY OTHER SUGGESTIONS???
__________________
so... so far:
__________________
lol well last time i got the cops called on me cuz i woke up the neighbors 1/4 mile down the road runnin it to 8 grand lol, not to mention all the neighbors in between. but ill get some vids after i go out. i just woke up, was up til 5 tryin to get some **** done but later i will post vids when i come back
I personally saw this car, and Nick I have to give u credit you know your **** and got it done finally. Unfortunately I saw the car when it had a huge gapping hole under the hood. The motor was stolen haha for 10 months. But I will see it soon.
eventually I am going turbo but i wanna rock the n/a for a while. just gettin ready to go out with it now, got the tires changed n on... shes ready to go. so ill go grab the camera now n later tonite will post vids
ok well ive had the car running and drove around a little, it is knocking some so i am a little paranoid. i will get a video of the idle sound. but the sound doesnt sound like it did last time when it was tapping valves and it doesnt sound like everyone elses car with normal cam lobing. every now n then it makes a really weird noise and im gettin worried that somethings wrong. checked timing, its still in time so idk why it would smack valves (if it is, its in time so it better not be). my oil level is good so im not low or overfilled with that, im gettin ready to go check spark plugs gap (im runnin a step colder... that bad?)
has anyone with neutral balance shafts had problems with getting the knock sensor to go off?
no i didnt do a check but i threw a thicker than stock head gasket on, not worried bout higher compression. but i could freely spin the motor by hand. im pulling cover and rechecking the timing for a 3rd time and im switching out with new 32# injectors and stock plugs then try it again. maybe im paranoid from blowin it up twice? but were gonna check it all again
subscribed for mike lol. going back to my house now with some new parts. 2-4 are really rich, 1 is running good (according to spark plugs). unplugged knock sensor and car was still having problems with idle so im gonna change out for new plugs and injectors then check timing and if there is a problem itll prob be in the tune, hopefully
haha yea i did that cuz you said you never seen the thread yet. im watchin my niece rite now so i will be home in like an hour to get some data logs of it and get in touch with vince then if he says its still knockin then im gonna pull the timing cover... AGAIN! so if its in time again like the last times then im guessin its balance shafts and then idk what im gonna do with the tune
i wasnt plannin to remove them completely but if in the end thats what ill have to do then well see but til then maybe just tryin to desensitize the knock sensor? idk whats goin on yet, well see later when i get it apart n if a new tune will work out better for stable idle
Last edited by NWAE Cobalt; May 16, 2009 at 08:05 PM. Reason: Automerged Doublepost
Ah knocking like real knock ? i thought you were speaking of a tapping noise...
It is normal you have some knock events if you still have the same ignition advance as stock with your higher compression, you'll now need less advance than on a stock map (personally I only have about 23° advance at full load / high rpm with my 12:1 CR, which is pretty low)
idk if it is real or not, but changing out from the 1 step colder plugs for the lsj (2 steps colder and 6mm shorter than L61 plugs) the knock noise went down considerably but now im having issues with gettin codes for high and low voltages to different sensors plus tuning is goin skitty cuz my ecm isnt staying connected to the program.... gettin pissed n tired of this car
i know that. that is why i am using them. but i was wondering if anyone else that uses them got the knock sensor to go off some cuz of them
Last edited by o3nisoaso3; May 19, 2009 at 05:24 PM. Reason: Automerged Doublepost
