rust on rotors..
Old Jul 29, 2009 | 03:24 PM
Caligula's Avatar
rust on rotors..
what do i use to get it off? It has taken over the front two rotors.
This is on a dry day.
After rain.
Old Jul 29, 2009 | 03:26 PM
SSsteve's Avatar
GO drive then hit the brakes. It goes away it's nothing to worry about
Old Jul 29, 2009 | 03:37 PM
Caligula's Avatar
^ no. This stays. It only gets worse. Each week, theres more rust. Now the entire front 2 are covered.
Old Jul 29, 2009 | 03:39 PM
SKCobalt's Avatar
do you have any pictures of the rust on the rotors. I am assuming if it doesn't come off, the rust is located around the veins of the rotor on the outside where the brake pads do not touch?
Old Jul 29, 2009 | 03:44 PM
ItalianJoe1's Avatar
rust on the non-contact surfaces of the rotors is perfectly normal. You could remove them, wire-brush all the rust off, clean them well and paint them (the hub and the vanes), but it may not hold. Best bet is to get some zinc coated rotors when you replace them if it bothers you.
Caligula's Avatar
^ both..
Every part has got rust.
I'll try to get pictures of it today.
Old Jul 29, 2009 | 03:45 PM
wardzach2007's Avatar
brake parts cleaner?
Old Jul 29, 2009 | 03:48 PM
Caligula's Avatar
No idea. It always comes back.
Are thier roters out there I can buy that wont rust?
Old Jul 29, 2009 | 03:53 PM
JoshuaVnyrd1817's Avatar
how old are they? i get some on my rotors when i let it sit for like a week but soon as i drive it, its gone.
get some sealed/platted rotors when you change them.
Old Jul 29, 2009 | 04:08 PM
blackbolt89's Avatar
http://www.turbotechracing.com/produ...dcategory=5612
best i could do.
Old Jul 29, 2009 | 04:09 PM
brickerenator's Avatar
Mine usually goes away, but I've got rust on my calipers. WTF?
Old Jul 30, 2009 | 01:06 AM
stretch89's Avatar
Looks like u need to call the "RUST" dept and tell them u have a problem lol
Old Jul 30, 2009 | 01:24 AM
eurochevy's Avatar
ummm your rotors shouldn't really be rusting lol at least not constantly staying there even after you go and brake since water can put the rust on there too when u wash ur car
Old Jul 30, 2009 | 02:50 AM
If you are seeing rust on the contact surface, where the pad hits, before you drive the car, it's normal. If my car sits in the rain while i'm at work, there is light surface rust on the rotors when I get in it to drive to lunch. That thin layer comes off as soon as you touch the brakes the first time.
The rust on the rest of the rotor is more permanent since nothing cleans it, but as I said and others have provided links for, you can get new rotors with a zinc coating that will protect the rest of the rotor. Or, you can not worry about it, as long as the brakes work good, that's all that matters.
Old Jul 31, 2009 | 06:45 AM
hailcesar75's Avatar
x2 ^^^^^^^ unless your rotors are zinc plated then theyre gonna rust in the non contact areas. like near the center and at the edges. its normal. wish i wouldve known this before i bought the gmpp slotted/drilled rotors. theirs arent zinc plated
Old Aug 6, 2009 | 06:34 PM
Caligula's Avatar
Pictures added.
Old Aug 6, 2009 | 07:00 PM
Perfectly normal. I suggest, if it bothers you, you get some new rotors that are coated so they don't rust. Otherwise, you could take them off, wire-brush all the rust off, sand them down, paint them, and it should help.
Old Aug 6, 2009 | 08:24 PM
If its that big of a deal go pay 200 for new ones that are zinc platted. If not just wait till you have to buy new ones then make sure you opt for the zinc platting.
If your willing to, you can always get them blasted and PCed.
Old Aug 11, 2009 | 04:26 PM
Caligula's Avatar
I took the car to the shop today. It goes back Wedsday to get the rotors rust free, and painted.
100 bucks for all four.
He said its weird that only the front ones are so bad. While the back ones are not bad at all.
bigdeertz
Nov 17, 2016 09:41 AM
Oct 21, 2015 11:57 PM
Oct 20, 2015 09:56 PM
chris88z24
Sep 8, 2015 01:55 PM
