MAF sensor problems on dyno
Old Aug 10, 2009 | 07:44 PM
protorox's Avatar
Question MAF sensor problems on dyno
hi, i have a t3 turbo with all the essential turbo parts. i took it to get tuned today and we were having troubles running very very rich with the tune on my car. i think its a problem with the maf sensor. where should i put it. mine is set between the intercooler and the throttle body with 2.5 inch pipping. my question is where do i set the sensor and what sizr pipping so it doesnt bog out when you press the gass
Old Oct 21, 2009 | 02:40 PM
unijabnx2000's Avatar
you might want to try a draw thru setup, cuz sounds like your doing a blow thru and the richness could be caused by the maf leaking under pressure...
Old Nov 3, 2009 | 11:14 PM
Jn2's Avatar
Jn2
^^^ u are incorrect...the way he has it is right u want the MAF to work blow thru, not pull thru...
the MAF sensor needs to be in a 3" pipe...anything smaller will throw it the **** off, that is your problem...
wow am i late to this :p
tomj77
Oct 4, 2015 11:39 AM
maliki778
Oct 1, 2015 07:39 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
