View Poll Results: wait or slap it on
put it on
12
70.59%
don't put it on
29.41%
Voters: 17. You may not vote on this poll
gonna install a 2.8in pulley
Old Nov 5, 2009 | 06:15 PM
Dragonsfire12345's Avatar
Well like the title says I'll have my 2.8in pulley in today... should be arriving any minute now... wait I think I hear someone knocking........... nvm...... its just the wind
As most of yall might remember my h.e. took a crap on me and I'm running with just the stock lsj h.e. and dual pass. Do you think i will be fine running the 2.8 til I get a new h.e. or should I wait and get a new h.e. before I put it on.
oh and I will be hitting up the dyno on saturday with zdeuce 4 as well can't wait
Old Nov 5, 2009 | 06:21 PM
BlackJackSS's Avatar
im runnin a 2.8 right now with no h/e
getting one asap tho!
Old Nov 5, 2009 | 06:40 PM
kburgess04's Avatar
you guys on 60's?
Old Nov 5, 2009 | 07:22 PM
WickedSS2005's Avatar
You can do a 2.8 on 42's but I do prefer it to be on 60's.
A 2.8 will not create a HUGE amount of heat, you can get away with the stock h/e. It's always better to have cooling, but you can do it
Old Nov 5, 2009 | 07:30 PM
alright sounds good, yeah I'll be getting another h.e. sometime in the future.
Old Nov 5, 2009 | 08:33 PM
mtbrent's Avatar
Remember Dragonsfire12345 is a 2.4. The 2.8 and 42's is not going to work very well with the LE5. Might be ok on a 2.9 or 3.0, especially being in TX. But I can tell ya up here in the north where it gets cold, 60's are needed for 3.0 or smaller on the 2.4 with m62.
And Dragonsfire12345, I'd wait til you get the heat exchanger to put on the 2.8, unless you have meth. Good luck on the dyno btw!
Old Nov 5, 2009 | 08:36 PM
rico's Avatar
bro wait. u gonna heat soak like a motther effer lol
Old Nov 5, 2009 | 08:37 PM
I got 60's
Old Nov 6, 2009 | 07:13 PM
and its getting pretty cool
Old Nov 8, 2009 | 01:53 AM
Jn2's Avatar
Jn2
If it's on the dyno. 1 h/e should be fine for a pull. Multie pulls will make loads of heat. And I votedto put the 2.8 on. Mine arrived on Wednesday. Installed same day. Trust me. 2.8 is awesome I get 15psi is 70* weather.
Old Nov 8, 2009 | 02:09 AM
Cobaltsky05's Avatar
damn that's what I am talking about for boost gain! what internals are you running in your 2.2 though?
Old Nov 8, 2009 | 02:43 AM
Jn2's Avatar
Jn2
All stock internals. Stock rods, pistons, clutch, etc etc. My clutch slips if I go wot in a rpm less than 4k...but man is it worth it.
Old Nov 8, 2009 | 04:29 AM
So we went to the dyno today, I made 226whp, and 198wtq. I had guessed 230whp, so my butt dyno was pretty close. Thats with the stock pulley, and not the 2.8in. so....... after we were done with the dyno, we all went to a friends house. Had some jello shots, and other very good drinks lol.... then me and a friend came to our senses and decided to put the 2.8 on. So we did, and now I'm at 14psi and it is alot of fun!!!!
Old Nov 8, 2009 | 12:54 PM
Jn2's Avatar
Jn2
198trq? Not good. Not good at all. Good hp though. I need to go dyno mine again. But Ima wait till I get a new clutch
Old Nov 8, 2009 | 03:14 PM
mtbrent's Avatar
For stock pulley thats pretty normal for a 2.4.
Old Nov 8, 2009 | 03:24 PM
glen229's Avatar
listen if your going over 12psi you need other things, your not going to see any gains
i had a 2.7 on my car meth / fm / dp
zzp's 78lb vavlesprings and the zzp fuel pressure regulator are a must, check out there site for more info
Old Nov 8, 2009 | 04:45 PM
this is the result of not having cooling mods with your 2.8. you lose power every pull on the dyno lol
Old Nov 8, 2009 | 05:33 PM
rico's Avatar
just got my 2.7 out the mail joe
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
