would a tune help me much?
Old Nov 8, 2009 | 03:38 PM
09blackonblack's Avatar
ok kind of a newb question but, would a tune from vince help me with a zzp mid length header/downpipe w hiflow cat, gmpp catback, and an injen cai? also how much power should i be putting out with all this?
Old Nov 8, 2009 | 04:29 PM
austinss's Avatar
What model is your cobalt?
1badBlueberrySC's Avatar
its in the LAP section so I'm going to assume 2.2.
And you can pick up some decent gains... maybe in the neighborhood of 5-10 whp and about the same torque.
But you'll notice a nice kick in the pants though!
Old Nov 8, 2009 | 10:19 PM
im going to try and get the most out of stock internals for now andtry the 2.4 le5 cams to see if that gives me anything unless they are the same
Old Nov 8, 2009 | 10:24 PM
elecblue06's Avatar
the cams from an LE5 i don't think will work..
but yea you can pic up some power with a tune
Old Nov 8, 2009 | 10:31 PM
i dont see why they wont the lap is basically a mini le5 both have vvt and cam sensors and sit on basically the same head. there just isnt any reason it should not work ive contacted maven about it to see what he has to say but im going to try it. anyone know where i can buy a used lap block cheap to do a build?
Old Nov 9, 2009 | 11:37 AM
Maven's Avatar
Cams should work just fine, LAP and LE5 use same exact head.
Old Nov 9, 2009 | 01:35 PM
elecblue06's Avatar
oh they do? oops my bad lol
Old Nov 9, 2009 | 06:32 PM
hey maven... will i gain anything by using the 2.4 cams? or are they the same?
Old Nov 11, 2009 | 03:05 PM
bump for an answer from maven
Old Nov 11, 2009 | 04:57 PM
Maven's Avatar
Yeah LAP cams are unique to the LAP, LE5 bits are different. Would they make a difference? Most likely. Worth the $200 to buy them and install them? Only if youre good at cam swaps and big time into experimenting.(imo)
Old Nov 12, 2009 | 12:28 PM
hmmm i can do a cam swap in a sbc im sure i can on a dohc 2.2 also
Old Nov 12, 2009 | 03:52 PM
Maven's Avatar
WAY different between SBC and ECO. In theory its easier because the cams are easier to access and to physically remove, but youve got 3 times as much chain to deal with and its much easier to mistime than an SBC and much harder to recheck your work. That being said with the proper skills and tools it only takes about hour to hour and a half to swap cams.
Old Nov 13, 2009 | 06:07 AM
woowoo16's Avatar
Okay , I don't own a cobalt i just come here because i like to read about different cars but generally when you add air flowing mods such as intake, headers etc. your car wont adapt enough to it and is already running lean. so with a turn you can richen it back up and get the hp that the mods should be giving you.
Old Nov 14, 2009 | 05:18 PM
maven, on the $200 is that for new or used cams? im still debating on whether to do it or not... sounds like a fairly easy gain in hp maybe not very much but hp isnt cheap. and would be worth it if you can gain a SOP gain imo...
also maven can you get me the part numbers for the cams please?
Last edited by 09blackonblack; Nov 14, 2009 at 05:18 PM. Reason: Automerged Doublepost
Old Nov 14, 2009 | 10:48 PM
Maven's Avatar
$200 is new from dealer. id have to look em up next week
Old Nov 19, 2009 | 11:57 AM
07Maliboo's Avatar
not to beat a dead thread here, but does anyone know what type of gains we (lap) can get from the le5 cams? has anyone actually done this yet?
Old Nov 20, 2009 | 06:30 PM
when maven gets me the part numbers i plan on doing it and getting a tune... just to see what we can expect
Old Nov 22, 2009 | 02:49 PM
maven: so would you say the 2.4 cams are a direct fit and bolt on for the 2.2? if so the lnf exhaust cam will work in the 2.4 so shouldnt i see some pretty big gains by putting the le5 intake cam and the lnf exhaust cam in my lap? that is what i have been reading... and taking in out of context.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
