custom intake mod
Old Nov 10, 2009 | 10:59 AM
Speedy McD's Avatar
Question custom intake mod
i want to change the pipe from the stock airbox (want maf sensor to stay) to the throttle body. Who has done this? Where can I get the parts? I searched "how to's" and other threads and can't find anyone who has done this.
Old Nov 23, 2009 | 10:02 AM
Rubberdude88's Avatar
Why don't you just buy the K&N Cold Air Kit or the Injen Kit. Everything that is required is supplied and the results are amazing both in performance and looks. I run the K&N 69-4515TS Typhoon on my 2009 2.2 and love it. It sounds mean when I am on the gas hard and sounds awesome throught the 3500 to 6000 rpm range. I don't think just changing the stock plastic flex tube will give you any further benefits over stock. Still sucking the same hot air.
Old Nov 24, 2009 | 12:31 PM
Speedy McD's Avatar
I tried the K&N, it won't fit my car. Talked to the tech support and we could not get it to work. The heat shield was rubbing on the frame and engine.
Old Nov 24, 2009 | 12:40 PM
08two.two's Avatar
Do you have pics of it rubbing? The heat shield on my Typhoon is no where close to rubbing the engine.
Old Nov 24, 2009 | 04:50 PM
Speedy McD's Avatar
I don't have them anymore. I deleted after I sent it back to K&N. I tried to bend the heat shieldand I got a new one and brackets from K&N tech support. Nothing worked. I have found out that a few other '09's with auto have had the same issue. After looking a little more I think I will order a injen.
Old Nov 24, 2009 | 05:17 PM
08two.two's Avatar
Hmm strange, I don't know why an auto tranny would make a difference, I have an auto on my 08, it can't be too much difference. Oh well, hope the Injen intake works out for you.
Old Nov 24, 2009 | 09:47 PM
Mine also was originally rubbing (squeaking). It was the heat shield rubbing against the frame under the headlamp assembly. I just cut a piece of rubber 1" x 1" and placed it between the two and the squeaking stopped. No problem on the engine side. Sorry to hear it didn't work out for you... all the best with your next choice.
Old May 12, 2010 | 04:00 PM
untamedsilverLS's Avatar
i have an 09 ls XFE and just made my own intake with autozone piping. i kept my stock airbox and put in a k&n filter. it gave me alittle power looks good under the hood and it lets me pray down my engine bay without worry about water on an open filter.
Old May 13, 2010 | 12:36 AM
cobalt523's Avatar
mine fit good just had to sqeeze it in, mine squeeked too and put rubber between it like u did but the vibrations cut the rubber inhalf so every few weeks i gotta put a new rubber on thats what she said
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 15, 2015 05:11 PM
Sep 26, 2015 06:44 PM
OrangeCoba
Sep 25, 2015 06:06 PM
