Serious Car Problems!! Help me!!
Old Nov 15, 2009 | 03:26 PM
Coblt ss super's Avatar
My car when in any gear and im cruising with it at any speed, and i let off the gas and it coasts down and you hear the motor start to rev down and slow the car down the motor makes a vibration noise, i come to find out its coming from the head. now another thing i have my o2 and maf and map senors all throwing codes! WTF!?!?! Help me
Old Nov 15, 2009 | 05:46 PM
Coblasts's Avatar
What are the codes ?
Old Nov 16, 2009 | 02:56 PM
um i dont remember hold on let me get them
These codes
P0036 - HO2S Heater Control Circuit Sensor 2 ECM, PCM
P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency ECM, PCM
P0138 - HO2S Circuit High Voltage Sensor 2 ECM, PCM
P0140 - HO2S Circuit Insufficient Activity Sensor 2 ECM, PCM
P0141 - HO2S Heater Performance Sensor 2 ECM, PCM
P0300 - Engine Misfire Detected ECM, PCM
Last edited by Coblt ss super; Nov 16, 2009 at 02:56 PM. Reason: Automerged Doublepost
Old Nov 16, 2009 | 04:46 PM
Coblasts's Avatar
Check the emissin fuse,and reseat it they are all fed from it ,might be something pulling down the voltage(bad sensor).Or the fuse is loose.
Also check all the relays.
Looks like you might of had a voltage problem and a loose fuse or connection might cause all of those.
You could check the wiring for the O2 sensors to make sure they are not shorting together(melted on the exhaust.
A high voltage code generally would be from a power feed shorting to a signal wire(Ex the O2 sensor heater wire melting to the signal wire that goes back to the pcm..)
The above codes would lead me to think its wires melted or pinched together for the O2 sensor
first.
Second would be in the bundle somewhere where it might rub through after leaving the pcm and going to either the maf or O2 because they are both on the emiss circut (fuse is in the box under the hood.)
Old Nov 17, 2009 | 05:07 PM
ok imma try and check them out and see what happens, i hope thats all it is, then i have to figure out why it vibrates from the motor and then y it idles funny
Old Nov 20, 2009 | 12:01 AM
Found out one of my problems, the pcm rubbed against my intake and put a hole in it.
Old Nov 20, 2009 | 11:24 AM
insylem's Avatar
I take it you have a K&N Intake?
I say that because I Just put one in my car
not too long ago and noticed that the heat sink
on my PCM was bumping against my intake line.
Fortuantly I noticed, and wraped some Tape arround
it to cusion it.
Might want to let K&N know, I believe their warranty
covers damage to the car caused by their equipment.
In this case its the intake that was damaged.
Something ealse to check.
YOur brake lines on your anti lock brake controler. Make sure
your intake is not rideing on them. I had to cusion mine with
chaff guard.
I'm also suprised it did NOT throw P0171 System Too Lean
Old Nov 20, 2009 | 12:28 PM
it to cusion it.
chaff guard.
No i have a fujita intake and my car is running rich as it is and maybe thats why it is not throwing that code. I am going to take my intake out one of these days and cusion it and fill the holes somehow and see how it runs after that.
vjoel2011
Oct 2, 2015 12:11 PM
Dope_SS
Sep 13, 2015 05:24 PM
Wind
Sep 11, 2015 06:57 PM
ATOMbomb
Sep 11, 2015 10:48 AM
jthwjde
Sep 7, 2015 09:24 AM
