TVS 1.37 w/ 2.7 question
Old Nov 15, 2009 | 07:35 PM
harryresh's Avatar
i bought the TVS 1.372 SC and will be running a 2.7 pulley. I will be running about 25 lbs boost. I was wondering if running meth is a need for this, in other words will my engine run too hot with this amount of boost?
Old Nov 15, 2009 | 07:45 PM
blackbolt89's Avatar
ummmmm.
im no expert on blowers but i think you should DEFINATELY BE ON METH with the TVS on any pulley under 3"
i could be wrong.
Old Nov 15, 2009 | 07:46 PM
Darkmanx's Avatar
you wont be at 25 pounds of boost...
to take avantage of the tvs some form of high octaine is required , either e-85 or meth injection. cooling mods are never a bad decision. if you want a have a complete ais meth kit for sale with a ottp throttle body spacer about 2 months old.
Old Nov 15, 2009 | 08:20 PM
WickedSS2005's Avatar
Run corn juice or use methanol on premium fossil fuel
Old Nov 16, 2009 | 12:46 AM
harryresh's Avatar
so you guys are saying i NEED meth? i believe ive heard other cars (not cobalts) running this boost w/out it? hey wicked, could i get your phone so i can get ahold of you easier for a tune? thanks
how much for your kit and why wouldnt i be at 25 lbs?
Old Nov 16, 2009 | 12:47 AM
Darkmanx's Avatar
we are saying you need some form of cooling. heat exchanger, dualpass , obtb , meth , e-85 whatever you want but it would be in your best interest to try to run as much cooling mods as possible along with e-85 or meth to get full results.
Old Nov 16, 2009 | 12:49 AM
harryresh's Avatar
i have the dual pass, large FM, and the Stu mod.
Old Nov 16, 2009 | 12:53 AM
Sizzle06's Avatar
Depending on what kind of power your looking to make,you might want to get bigger injectors.On the 2.9" pulley i made 340whp without meth.
Old Nov 16, 2009 | 12:55 AM
harryresh's Avatar
im running 80lb injectors and forged aluminum pistons with this. i thought meth wasnt a power adder. i thought it just makes it cooler
StreetDreamz's Avatar
You won't make that much boost. Unless you are on a stock header. Which if you are, expect like 10 degrees of timing maybe even on meth or corn.
Old Nov 16, 2009 | 12:57 AM
Darkmanx's Avatar
meth is rated at 105 octaine , is a power adder depending on your meth mix. the more meth you run the more power you can make if you run more water the cooler it will be yada yada
Old Nov 16, 2009 | 01:00 AM
harryresh's Avatar
ok. i gotcha.
i have a header, piped out downpipe, and a cat-back
Old Nov 16, 2009 | 01:10 AM
Yeah I would expect maybe 23ish, unless you are pegging her to 7500rpm or so. Minimally you need to run like 105 octane or higher, 7gph meth nozzle with pro controller and pump at 100psi, or E85, which requires a complete fuel system overhaul pretty much. A dual pass endplate and dual pass heat exchanger would help your cause too. Even though the Harrop is super efficient, it still makes heat and the less you have the better off you are.
Old Nov 16, 2009 | 01:20 AM
harryresh's Avatar
what about a vacuum line controlled @ 250psi? lol
Old Nov 16, 2009 | 01:23 AM
Darkmanx's Avatar
the pump are rated at 250psi. they arnt using that, you can turn the pump up and down
Old Nov 16, 2009 | 01:42 AM
harryresh's Avatar
thanks guys. FYI i have some GMR cams and other performance parts for sale if you want them. check out my FS thread
https://www.cobaltss.net/forums/parts-66/m62-gmr-cams-pulleys-60s-stock-parts-195621/
Old Nov 16, 2009 | 01:51 AM
Bear in mind that the higher the psi the pump is putting out at, the larger the nozzle effectively becomes. A 5gph nozzle at 100psi flows 5gph. At 200 it flows more like 7. A 5gph nozzle spraying at 250psi is going to bog your motor down severely as well as waste methanol.
Old Nov 16, 2009 | 08:48 AM
harryresh's Avatar
will running meth through my SC be a destructive?
Old Nov 16, 2009 | 09:18 AM
Not that I or really anyone else has experienced.
Old Nov 16, 2009 | 09:22 AM
harryresh's Avatar
what gauge would be best to see if im spraying too much or not enough meth for cooling? pyrometer? or intake temp gauge?
Old Nov 16, 2009 | 09:33 AM
lsjwannabe's Avatar
aeroforce ( or hpt) and a egt would be ideal
brandon04
Oct 21, 2015 07:04 AM
Builttss
Oct 4, 2015 10:21 AM
SSLOW06
Oct 1, 2015 07:21 PM
Extremespeed
Sep 29, 2015 04:34 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
