StevesBlack06 LSJ build (round 2)
Old Nov 15, 2009 | 10:59 PM
StevesBlack06's Avatar
UPDATE: ITS ALIVE AGAIN!!! The fix seems to have worked!!!
as some of you may recall i blew up my engine a while back due to a sheared rod bolt. i sent a rod through the block and destructed a lot of other stuff in the process. i bought a new block and decided i wanted to build this bitch bullet proof. i got my engine back wednesday and me and bykryder83 (ryan) have been wrenchin on it every evening after work to get her put back together. i still need a few things to get it fully assembled but the mods are:
Bottom End:
Darton Sleeved 2.0 Saab Block
Diamond 10.5:1 CR pistons
Lightened, balanced, and knife edged crank
Balanced LSJ rods
ARP rod bolts
ARP Head Studs
GM Main studs
Balance Shaft Deletes
Celvit Main and Rod Bearings
AC delete (still lookin into this, for now the compressor is just free spinning)
Top End:
Ported head
Jbody Stage 2 Triflow cams
Jbody Solid Lifters
Supertech 78lb Valve springs/retainers
Supertech Valves .05 Oversized
5 angle valve job
Cometic .45 MLS gasket
Bates valve seats and seals
Ngk bkr7e
ZZP valve cover breather
Intake:
Ported M62 running a zzp 2.8" pulley
Ported Intake manifold
ZZP Phenolic intake manifold gasket
LS4 TB
OTTP 3" intake
Exhaust:
ZZP Midlength header and downpipe combo. (1.75 primaries, 3" collector and 3"downpipe)
P.S. Just sold the JBP header...
Fuel Delivery:
Siemens 80 lb/hr Injectors
E85
Cooling Modifications:
Italian Joe Dual pass endplate
Vulcan Turbo Driver side aluminum coolant tank
Vulcan Turbo Passenger side Flow through Coolant tank
CXR Frontmount heat exchanger
Suspension and Mount Modifications:
K sport Coilovers
JBody Strut Tower Brace
Bwoody Solid upper mount
Poly inserts for trans (for now)
im sure im forgetting a bunch of **** and ill add it when it all comes to mind. i plan on switching to a TVS/Turbo kit sooner or later but i wanna throw it back together with the m62 and see what it will do. its been down for so long im gonna enjoy it for a while before i put it away again for the winter. ill upload some pics of some progress shortly. tell me what you think CSS!
Old Nov 15, 2009 | 11:03 PM
Mr_Slobalt's Avatar
sub'd for update
Old Nov 15, 2009 | 11:04 PM
Darkmanx's Avatar
i know you need a meth kit and i have one for sale.
Old Nov 15, 2009 | 11:11 PM
drew1991sf's Avatar
wat about clutch?
Old Nov 15, 2009 | 11:21 PM
Originally Posted by drew1991sf
wat about clutch?
exedy hyper single
elite_Cyborg's Avatar
take that header off
Old Nov 15, 2009 | 11:24 PM
meh... ive kicked it around but it seems to finikey for my liking. why are you getting rid of yours if you dont mind me asking?
no thanks. i recieved one of the good ones. smooth bends great welds. ran it last build and it sounded mean as hell and performed well.
Last edited by StevesBlack06; Nov 15, 2009 at 11:24 PM. Reason: Automerged Doublepost
Old Nov 15, 2009 | 11:25 PM
WickedSS2005's Avatar
Lookin good Steve.
Didn't know you had JBP cams and header tho... Not my fav but if you say it looks good and all I'll have to check in in person. Still didn't get an email of your mods, but this works lol
Old Nov 15, 2009 | 11:27 PM
Darkmanx's Avatar
because e-85 and meth are rated at the same octaine lv so its either one or the other and i chose e-85 .
Old Nov 15, 2009 | 11:28 PM
Not with E85
Old Nov 15, 2009 | 11:29 PM
Darkmanx's Avatar
Originally Posted by WickedSS2005
Not with E85
read my statement above, i didnt see that he was on e.
Old Nov 15, 2009 | 11:32 PM
thanks for the clarification. and tom, i ran both the header and cams last year and they did very well. my only gripe was the cams werent balanced worth a crap when i got them. it didnt cost much to have them balanced but im glad i did.
Old Nov 16, 2009 | 08:25 AM
damien's Avatar
Ah, so that's what the whole subframe looks like when it's pulled out. Looks like you also took off the impact beam to roll it out the front?
Hope it works out for you this time around.
Old Nov 16, 2009 | 09:28 AM
383_Stroker's Avatar
Glad to see you're about to get her up and running! Keep us updated!
How's that "secret" mod coming along?
Old Nov 16, 2009 | 09:29 AM
stenguyen1's Avatar
that looks freakin sweet good luck with the finish results.
Old Nov 16, 2009 | 09:31 AM
rico's Avatar
loooks good. subd
Old Nov 16, 2009 | 11:27 AM
Check post times dude lol
Old Nov 16, 2009 | 06:19 PM
funny that you ask... its failing haha! i dont think its gonna fit. im sure as hell gonna try but i think theres to much **** is in the way fml.
and thanks to everyone for the comments. any input would be appreciated. i have no idea when ill get her in the dyno but as soon as i get everything from ottp ill have it out for break in. hopefully i can get it broken in and tear it up a little before it gets shitty out.
Old Nov 17, 2009 | 03:55 PM
OneCOLDBIZL272's Avatar
Way to copy me steve.... J/k nice build brotha....mines still faster hahaha j/k again it's will be a close call I might have to swing out by you on a week end to check that beast out
Old Nov 17, 2009 | 05:29 PM
ha come on out man! we will run em!
Old Nov 17, 2009 | 09:22 PM
Jrhdpaintball's Avatar
nice man i like the set up.... how much did that bottem end set up run you... with the sleeves installed and the arp bolts, if you dont mind me asking... im considering sleeving mine, but dont know how much vs. is it worth it
Old Nov 20, 2009 | 06:59 AM
Speedytec's Avatar
That 10.5 CR will be interesting with the cams and E85...
Old Nov 20, 2009 | 11:47 AM
spike's Avatar
cool now i hav someone to pwn soon....lol
Old Nov 20, 2009 | 01:35 PM
drew1991sf's Avatar
is there a reason u didnt go with the zzp 2.3l stroker kit? wouldnt it be the same price?
Old Nov 20, 2009 | 05:36 PM
bykryder83's Avatar
we started these builds almost a yr ago the zzp stroker wasnt out yet but this seemed to be the best set up for him so we built a 2.0 beast sc... spike ill run ya anytime when we bouth get our cars runnin lol 2.2 turbo ftw
