Catless Downpipe
Old Nov 17, 2009 | 11:43 AM
08turbaltscott's Avatar
Catless Downpipe
Hey guys, sorry if this question has already been asked but i have a 08 cobalt tc. My performance mods are injen cold air and GM stage 1. I want to get a catless dp but i dont wanna see the check engine light. If i get the catless dp will i throw a code? and what are some suggestions on a good dp?? thanks for the help
Old Nov 17, 2009 | 11:46 AM
Shez's Avatar
Get a Hahn or a ZZP. They have an o2 bung so you won't throw any codes or check engine lights. I have a Hahn catless turbo back and I haven't thrown any codes at all and I'm still on a stock tune.
Old Nov 17, 2009 | 12:04 PM
thanks for the advise. anyone else know anything about this?? if it wont throw a code than im buying right now. I just wanted to do a little research first...
Old Nov 17, 2009 | 12:11 PM
BYT*SS*TURBO's Avatar
You will still throw a code. I get the 2237 - O2 pumping circuit code.
Old Nov 17, 2009 | 12:21 PM
ok what about the dp w/high flow cat? will i still see power gains? will it throw a code?
Old Nov 17, 2009 | 12:28 PM
Angel's Avatar
You wont throw a code with the Hahn Dp
Old Nov 17, 2009 | 12:29 PM
If its catless, you will. Catted should be fine.
Catless cars - give it 5-10000 miles, you will get a cel.
Old Nov 17, 2009 | 12:31 PM
agent007kimball's Avatar
I say get the high flow cat....in addition to not having the noxious fumes, you will actually be able to pass emmisions when the time comes. The power difference will be practically nothing.
People seem to forget that in this day and age cars are designed from the start to work with catalytic converters. Back in the day of the 70's muscle cars with carbed big blocks it made big gains to just gut out the cat...as tech gets better and better it does less and less for performance to do that....in many cases it actually reduces performance in modern cars to do that.
Old Nov 17, 2009 | 12:55 PM
Terminator2's Avatar
I get that code occasionally too.
Old Nov 17, 2009 | 12:57 PM
D4u2s0t's Avatar
If you don't want a code (for whatever reason, not like it does anything. can easily have it turned off) then just leave it stock. If you go catless, or a hi flow cat, you WILL eventually get an engine light. Having a bung for the sensor means nothing.
Old Nov 17, 2009 | 01:05 PM
Iam Broke's Avatar
Ditto! Took about a month for it to pop, I just disabled it.
Old Nov 17, 2009 | 02:16 PM
Sweetsandman's Avatar
Never thrown a code with my catless...been about 5k miles with the ZZP with the extended O2 bung.
Old Nov 17, 2009 | 02:18 PM
Watch you RPD on the wideband screen next time you do a WOT. It took awhile for mine to happen too. I have the same DP, more mileage. It JUST started happening to mine, Im at about 10K on the downpipe.
Old Nov 17, 2009 | 02:30 PM
Mine didn't throw an actual code on the dash. The RPD showed no data for the Wideband, I check with HPT and there was a code pending. I reset it, RPD showed the data again.
Old Nov 17, 2009 | 07:08 PM
New Creation's Avatar
I have a catless DP from Synapse for almost a year. No codes - No problems.
Old Nov 17, 2009 | 08:36 PM
RYRO14's Avatar
I got the CIA catless and have yet to throw a code
Old Nov 17, 2009 | 08:37 PM
Angel's Avatar
Hahns new dp will not throw a code base on there bung design.
Old Nov 17, 2009 | 08:40 PM
HB_SS/TC's Avatar
Get one with the o2 sensor location like this and you'll get no codes
Old Nov 17, 2009 | 08:45 PM
BartSS's Avatar
I got a catless dp and jus went ahead and deleted the code from the system via hp tuners
Old Nov 17, 2009 | 10:35 PM
Thanks alot guys.
Old Nov 19, 2009 | 08:23 AM
smanbb4l's Avatar
Synapse catless dp for me and no codes! (2,000 miles so far)
Old Nov 19, 2009 | 10:50 AM
tom.g's Avatar
I too am looking at getting a catless DP and eveywhere I read so far says if you get the ZZP, CIA or Hahn Catless DP because of the angle of the O2 sensor bung you will not get a CEL, are you saying this is not true? If someone where to get the High-Flow catted down pipe from one of the vendors I mentioned above are they at less risk of throwing a CEL? Also if someone without HP Tuners software or Superchips got a CEL code for this how could they go about reseting it - would taking it to the dealership work?
Old Nov 19, 2009 | 11:09 AM
Josh@ottp's Avatar
We also have a catless down pipe for the LNF now. It comes with the angled o2 sensor bung, so you won't throw a code. I'll get a picture up shortly.
Old Nov 19, 2009 | 11:12 AM
I have the ZZP with the angled bung. I get the 2237 O2 Pumping Circuit code. Finally showed up after 10k+ miles. I had read about it on HPT and hadn't seen it myself until JUST recently.
Old Nov 19, 2009 | 11:21 AM
RYRO14's Avatar
If you have a Trifecta Tune, can HP tuners cancel out codes on it?
