belt slipping???
Old Nov 17, 2009 | 07:56 PM
09blackonblack's Avatar
belt slipping???
ok its done it three times now but driving my car on bumps it will make a screeching noise and the headlights dim and the heater shuts off like my car died but it will go back to normal. it doesnt make any sense.... any ideas of whats going on or why?
Old Nov 17, 2009 | 07:58 PM
ff_drift_lol's Avatar
look out for those bumps
Old Nov 19, 2009 | 07:57 AM
Coblasts's Avatar
Sounds like a tensioner is going bad which would be an easy fix or something is coming loose
Did you take a look to see if anything is loose by trying to wiggle everything the belt rides on.
Also could be a sign of the generator going out.
Old Nov 19, 2009 | 08:09 AM
Fast Black SS's Avatar
Genarator? You mean altanator
Old Nov 19, 2009 | 08:13 AM
Coblasts's Avatar
Originally Posted by Fast Black SS
Generator? You mean alternator
I didn't want to spell it wrong like you so I used generator,.
Spell checked yours in the quote.lol
Old Nov 19, 2009 | 08:17 AM
Yea but he would get what you would be saying more than generator
Old Nov 19, 2009 | 03:57 PM
generator is the new terminology for alternator. actually, it's the proper term and there's no 6v generators on modern cars so I'm sure there's no confusion.
anyway, bad tensioner sounds about right although I would use a belt tension meter to make sure. not sure of the factory specs off hand. a loose and pulsating belt will lose grip on the alternator creating an uneven contact patch on the pulley. this could be why it seems like the power is fluctuating. hope I am helpful.
Old Nov 22, 2009 | 10:12 AM
it hasnt done it anymore just now its being weird in another way... my rpms fluctuate about 200 rpms with the pedal in one spot held steady and when i rev the engine it makes a faint whine like a supercharger only i KNOW there isnt one and it comes from the passenger side. i do know i need output shaft seals now. and my warranty wont cover it... apparently that is normal for it to leak
Old Nov 22, 2009 | 07:03 PM
not that I've ever heard! could also be a half shaft bearing but only if you hear it when moving. if it's happening when you're standing still it can't be an output shaft. weird man, I wish I could get my hands on it to check it out.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
Iceberg
Sep 28, 2015 01:31 PM
grampss
Sep 27, 2015 08:51 PM
