What are your winter IAT2's?
Old Nov 17, 2009 | 08:15 PM
Gene Culley's Avatar
Hello All,
I installed the SC setup on my 2009 LAP engine back in the summer. I have done the IAT2 conversion, to be able to see the IAT2 temps, and I'd like to know what you are experiencing for IAT2's in the winter months. I'm talking PA, MD, VA, you know.. NE people where it is cold, lol. I'm sorry if this has been covered before. I've read a lot here and haven't seen it.
Thanks, Gene.
Old Nov 19, 2009 | 08:46 PM
Talking
Does anyone have any feedback for me?
Old Nov 19, 2009 | 08:48 PM
chris88z24's Avatar
i have no idea what mine are in the cold weather.
Old Nov 19, 2009 | 08:51 PM
VeNoM0713's Avatar
i see maybe at the most 8 degrees warmer than ambient temp lol.. actually i was logging yesterday and the ambient temp was 54 and my IAT2's were 53 lol so i was cooler than ambient.. although my opinion doesnt count because i converted to turbo lol.
Old Nov 19, 2009 | 08:55 PM
SS33's Avatar
I normally see ~20 above ambient while cruising. Sometimes lower, on really cold days I've been able to cruise around at about 10 above ambient
I am running dual pass/option B and a cobra HE
while stationary it will climb (to ~120), but falls right back after you get moving again
If you park your car, then get back in before everything cools back to ambient it will read really high (~150s) when first starting, but again, once moving it comes back to where it should be
Old Nov 20, 2009 | 04:21 AM
SSfamilywagon's Avatar
I'm in Az but the nights here have been pretty cold, mid 40's low 50's. Iat1 shows about 60ish and I can usually get iat 2 about 10 degrees higher(70-75) crusin around.
At stops it gets to about 100-110 but goes down fast when driving. Just like SS33 said, if i just let it idle for along time iat2 will climb to 140-145.
On hard pulls(2nd-4th gear) starting from 70iat2, it'll get to 90-95ish. Only goes past 100 iat2 if i do 3 of those pulls back to back.
All in all i'm only seeing average 20 above iat1 in winter and now boosting about 16psi, 30-35 above iat1 in summer and boosting about 14.5. I'm running rich as hell now that its winter. Like almost 10 flat afr
Old Nov 20, 2009 | 04:28 AM
ff_drift_lol's Avatar
I am s/c and meth injected so I couldn't help you, but I am about 101-105 normal driving, when I get on it I hit maybe 145 max. stock pulley.
nothing to worry about until you hit 199F after a 3rd gear pull on a hot sunny day and realize your ic pump is shot!
Old Nov 20, 2009 | 05:28 AM
Projekt's Avatar
23 degrees today.
lawls
Old Nov 20, 2009 | 07:08 PM
Talking
Thank you. There is some helpful information here.
Old Dec 23, 2009 | 09:04 PM
2pointWhoa's Avatar
I was sitting in dead stop traffic today for about an hour, it was around 35 degrees outside and I showed 125-129 never above 129 and that was at a standstill it took almost 30 minutes to get to 110 degrees. I have a 2.79" pulley, CX big HE running inline with the stock HE which I moved in front of the A/C condensor so its not sandwiched in between the condensor and radiator and I put a switch on my fans so they can be turned on by the pcm or by the switch (which I didnt use at all today.) At cruise I see around 60-68 IAT2 and Wot never went above 100 degrees all the way to the top of 3rd gear.
after the move of the stock HE
another shot
all done!
Old Dec 23, 2009 | 09:23 PM
BeermanSSSC's Avatar
I'm seeing between 54-104 in Buffalo. Weathers been 19-30ish.
But then again my intercooler pump works only some of the time. Hammer mod.
Old Dec 24, 2009 | 11:39 AM
Schaeffer's Avatar
well last night when i left work it was 14degrees out and my iat2s were 21degrees by the time i got home after a ten minute drive they were 25degrees
Old Dec 24, 2009 | 12:22 PM
shroogis's Avatar
This was more fall temperatures, but now if it's like 20 degrees IAT2 will be be like 30* cruising...usually 10-30 above ambient
Old Dec 27, 2009 | 07:26 PM
Talking
Thank you for the input. Good info here.
Old Dec 27, 2009 | 07:51 PM
06cobalt racer's Avatar
yeah about 15 above
06MetallicBalt
Jul 20, 2025 08:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
Macgyver2484
Sep 23, 2015 11:36 PM
tamadrummer
Wheels and Tires
Sep 11, 2015 02:47 PM
