How can I mod it so its always amber DRL, never headlights?
Old Nov 19, 2009 | 01:56 PM
Eric_7810's Avatar
Is there a way to ground out that sensor on the dash to just simply trick it into thinking its always daytime?
I want to make the AUTO position basically be strictly amber DRL. Help a noob!
Old Nov 19, 2009 | 10:54 PM
chitala383's Avatar
if u turn ur fogs on during the day ur headlights will turn off but ur corner lenses and fogs will be on. thats all i can think of. i dunno man
Old Nov 19, 2009 | 11:01 PM
ls1fbody's Avatar
Haz l33t wheelz.
why dont you just turn the headlights off?
Old Nov 19, 2009 | 11:11 PM
flyg5's Avatar
this is what i did: if your like me and dont drive at night and dont use the high beams....i just pulled the highbeam fuses out and when i need them i will just put them on. now you will have to turn your hi beams to the on position for this mod to work. if that isnt what your looking for then you could just pull the low beams but i would just recomend getting HID kit for your low beam and pulling the highbeams for the look that you want.
when i drive and comute around town i have my high beams on at all times (fuses pulled of course) and when it gets dark i just shut them off and resume with my low beams on. and i like the look of just the amber signals on and no driving lights on.
Old Nov 19, 2009 | 11:14 PM
importkiller's Avatar
just pull the drl fuse and then when you want ambers and fogs as drl then turn them on.
Old Nov 20, 2009 | 04:17 AM
Nighthawk243's Avatar
You would need to do quite a bit of rewiring to make your DRL's into the 05/06 style.
If you want DRL's disabled though, yank the fuse in the engine compartment fuse box.
Old Nov 20, 2009 | 11:10 AM
Eric_7810's Avatar
OK well my car is 05.... Amber only during the day, then headlights when it gets dark....
The way it switches into headlights is what I want to disable. I want DRL's to strictly be the double lit ambers. ideas?
I thought it'd be as simple as modding that dash "eye" thing?
Old Nov 20, 2009 | 07:01 PM
Oh, the Autolights system. Yeah, you'll need to find a way to fool the car into thinking that it is daylight out. You would need to either come up with something that shines light on it all the time, or find a way to remove the sensor and bypass it by adding a resistor.
More info: https://www.cobaltss.net/forums/electronics-audio-video-49/canadian-auto-headlights-bypass-solution-154636/
Old Nov 20, 2009 | 11:51 PM
insylem's Avatar
Ya do that...
Hey Mine is 06 and Yellow also,
I dono how yours is but mine has
Auto Off (Monontary Postion)
Auto (Detent)
Parking Lights (Detent)
Headlights (Detent)
If you switch to the parking lights, it wont matter, day or night, you will
only have your yellow (amber?) ones on
-Jonathan
Old Nov 21, 2009 | 03:03 PM
SeVeReDiStOrTiOn's Avatar
The sensor on the dash is just a variable resistor...replace it with a fixed value resistor equal to the daytime value.
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
Sep 26, 2015 06:44 PM
