oil pressure gauge help please
ok so I have been trying to install an oil pressure gauge but cant seem to do it. I have locaed the oil galley plug under the manifold but have no idea on how to take it off. its doesn't seem reachable from the intake. Where is the stock oil on/off switch?? I know its under the manifold but I can't locate it either. Thoughts, help please.
You will need an allen wrench to remove the plug (I dont think it is a torx/star drive) There is 3 on the front of the block and 3 on the back of the block.
You will most likley need this fitting for the port if you dont have it already...
http://www.turbotechracing.com/produ...8&idcategory=0
Hope this helps.
Hope this helps.
Im planning to do this mod, what is the normal number for oil PSI on turbocharged cobalt?
Jason
I hope this link works but is this what you're talking about? 3 round flat heads with hex?
https://www.cobaltss.net/gallery/fil...3/100_2183.jpg
Jason
Last edited by HanzenRider; Nov 27, 2009 at 03:31 PM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
