--||The Official Headlight and Taillight Thread||--
Old 02-07-2010, 09:21 AM
AWD > FWD
TommyP's Avatar
The old headlight and tail light thread was going out of date, and all the pictures are missing, so it's time for a new one. If anybody has a problem with me using a picture of their car as an example let me know and I'll take it down.
First of all, all cobalt head lights fit all cobalts and g5s
1st generation projectors
These use H1 bulbs for both the high and low beams
2nd Generation Projectors
These use H7 bulbs for the low beams and H1 bulbs for the high beams
3rd Generation Projectors
These use H1 bulbs for the high and low beams
4th Generation Projectors
These use H7 bulbs for both the high and low beams.
Blacked out stockers
Stock headlight bulbs are 9007
On the stock lights, the 05-06s have amber turn signal reflectors. On the 07+, they're chrome. Also, if you have an 05-06, your parking lights are your DRLs. If you have an 07+ your headlights are your DRLs. So if you put hids in an 07+, pull the DRL fuse to avoid problems. To repeat myself because some of you out there on .net don't read through all of this, if you have an 05-06 Cobalt, your parking lights are your Daytime Running Lights. If you have an 07-10, your low beams are your daytime running lights. The type of headlight you have does not matter
If you get LED turn signal bulbs, a resistor such as these will be required. Switchback Leds are awesome too. They are white when driving, then switch to amber for the turn signals
I got mine on 3bspec.com. They are two types of them. Type 1 has it set up so when you turn your turn signals on, they flash between white and amber. Type two turns off the white and just flashes amber, then turns the white back on when you shut off the turn signal. Here's two videos as examples
Type 1
Type 2
Type 1 can be found on 3bspec.com here
Type 2 can be found on v-leds.com here
Both can be found on vleds but remember that 3bspec is one of our supporting vendors. You will need to buy these load resistors to keep them from hyperflashing.
The best head lights possible though, are retrofits. These are OEM projectors that are fitted in from BMWs, Acuras, G35s, etc. Currently, we have 2 vendors that sell retrofits, Streetracinazian, and buyhids.com. Both sell complete retrofit sets, and buyhids also sells do it yourself kits. They both feature the Morimoto Mini H1 projector, which is a fantastic projector. This is definitely the way to go on a good lighting setup.
If you are buying a retrofit kit, I HIGHLY recommend spending the extra money on the Morimoto HID kit, instead of the generic cheaper one. The Morimoto kit is designed to work with the Mini H1 projectors which both vendors use, and are of a far superior, nearly OEM quality. 95% of the issues with retrofits are due to either incorrect user installation, or not buying the Morimoto hid kit.
Our fog lights use H11 Bulbs
2 door coupe led tails
These come in a variety of black/red/chrome mixes
These come in red too
4 door sedan tails
^^ These come in chrome too
To help clear up confusion that often pops up around here, the sedan tail lights are not the same as the G5 coupe tail lights, and are not interchangeable.
All of these lights can be found from various supporting members. eBay will be the cheapest place for all of these lights, but our vendors are the most reliable. The quality for these lights is the same no matter where you go, they all come from the same respective factory, as in all the 1st gens are made in the same spot, etc.
Vendors such as:
Modern Performance
PFYC
3Bspec
Cobalt-Addiction
Turbo Tech Racing
ZZP
all sell at least some of these lights. If any other vendors sell them let me know and I'll add them to the list, these are just the ones I know off the top of my head. all of these lights can easily be found on ebay
Here are some helpful how to's
How to paint your headlights
How to paint head lights with CLEAR corners (Missing pics)
LED 3rd Brake light
Method 1
Method 2
3rd brake light relocation retrofit
How to Tint Your lights
How to replace a burnt out halo
How to wire halos
3rd Gen anti glare mod(pictures are missing, but hopefully you'll get the idea)
How to swap to CCFL halos
How to remove + tint Sedan tails
How to make retrofit headlights
"Ultimate High Beam Mod"
How to remove your headlights
"Skyline Tail light mod"
How to change fog light bulbs
How-To: Replace a Burnt Out Halo Electrical How-To: Replace a Burnt Out Halo - Cobalt SS Network
Let me know if I missed something. Also, if anyone has a request for pics of certain lights on a certain color car, post it and I'll do my best to find one.
If anyone has any questions feel free to post them!
Old 02-07-2010, 10:39 AM
Mindrot's Avatar
Add this: Ebay
Old 02-07-2010, 11:01 AM
Site Founder
JonyyB's Avatar
add something on trunk lid lights like:
https://www.cobaltss.net/forums/show...hlight=skyline
A vendor needs to make these for us, would sell like hotcakes
Also, vette lights, but we need a good step by step how to on this:
https://www.cobaltss.net/forums/show...1&postcount=44 (also not legal unless you add 1 reverse light in the bumper grill or get a g5 bumper)
Old 02-07-2010, 11:05 AM
DarkCobalt13's Avatar
I'd buy them!
Old 02-07-2010, 11:24 AM
AWD > FWD
TommyP's Avatar
^^^ x2! Those plus
these tails together tinted would sell like crazy!
Old 02-07-2010, 11:25 AM
iboost's Avatar
how bout retros?
Old 02-07-2010, 11:28 AM
AWD > FWD
TommyP's Avatar
I was kind of leaving those out since the possibilities with retros are endless, that's kind of why I put the how to in. I wanted to limit this to what can easily found and installed from vendors. Maybe I'll write a little about it though.
Old 02-07-2010, 11:29 AM
Site Founder
JonyyB's Avatar
factory style w black housing
Also, 05-06 headlights have the amber over the turn signals, 07+ Don’t
Old 02-07-2010, 01:26 PM
iboost's Avatar
Makes sense...good thread btw
Old 02-11-2010, 09:47 AM
06C0BALT's Avatar
Half-assed pic. I'll get a better one later. I have stock black housing lights with 6k HIDS
Old 02-11-2010, 10:53 AM
06G85's Avatar
I bought the smoked LED tails off ebay. They are GREAT! THe pictures on ebay of them they look dark red. They actually have a clear smoked look. LED's are BRIGHT! I got these from k2motor. I searched Cobalt smoked LED tail. The description underneath said it was a dark red lense, but they came like this.
Feel free to use my pictures anywhere!!!
Old 02-11-2010, 12:29 PM
06C0BALT's Avatar
^i forget do LS and SS fit the same tail lights?
Old 02-11-2010, 12:39 PM
Rissa's Avatar
Yes.
Old 02-11-2010, 12:52 PM
06C0BALT's Avatar
Thanks Rissa =)
Old 02-11-2010, 12:55 PM
Rissa's Avatar
No problemo.
Old 02-11-2010, 02:23 PM
tom.g's Avatar
Did you paint the bottom ridged portion of your headlight housing? I'd love to see an up clsoe pic of your housing if you have one.
Old 02-11-2010, 02:45 PM
06C0BALT's Avatar
close up on the car.
before they were installed.
Old 02-11-2010, 06:44 PM
tom.g's Avatar
Wicked thank you for those pics? How is the glare after painting that ridged portion black? I've been debating on painting that portion for the last week and I just can't make up my mind.
Old 02-11-2010, 06:46 PM
Rissa's Avatar
What ridged portion are you talking about?
Old 02-11-2010, 08:47 PM
06G85's Avatar
Rissa, I think tomg is talking about the inner bottom part of the headlight reflector. Like how mine are painted..
Old 02-11-2010, 10:37 PM
tom.g's Avatar
Exactly
If the ridged portion is un-painted it looks like so
Old 02-11-2010, 10:44 PM
I'm too JDM for you
BLAZIN07SS's Avatar
oh wow everyones headlights in this thread are black. what a surprise
you know what? BAM!!!!
Old 02-11-2010, 10:46 PM
Haz l33t wheelz.
ls1fbody's Avatar
Not bad... I don't know how i feel about the LED's though.
May i submit my headlights for the retrofit category?
Old 02-12-2010, 12:44 AM
thedude411's Avatar
retros by blownss06
e55's
they are brighter than photos represent
i tried to upload a close up of them but i just got wicked glare...
Old 02-12-2010, 01:40 AM
IdreamofYenko's Avatar
Awesome info in this thread.
Quick Reply: --||The Official Headlight and Taillight Thread||--
