JBP VVT LE5 Camshafts
Hey LE5 guys,
Mike is in the middle of installing the camshafts! Please note that this is the official thread for all questions... we'll be posting results and first impression shortly.
Thanks!
Thanks!
Originally Posted by JBP
Hey LE5 guys,
Thanks!
Thanks!
What's the rev limit on the stage one cams without your valve springs?
What would be the new rev limit with a set of your valve springs?
Are the stock rockers strong enough for revs in excess of 7500rpms?
Thanks
Thanks
Thanks
Depending on the spring chosen, Bates, JBP or Ferrea. The Redline ranges from 7200-9000RPM.
The stock rockers are strong, seeing as no reasonably priced alternative is available (yet), we'll have to do with them.
The rev limiter remains the same (stock) on our Stage 1 Triflows with stock valve springs.
Do you think these might work?
http://www.jeselonline.com/index.php?categoryid=29&
Originally Posted by g5mike
I got two new rockers,Ill have them in the morning,and Ill put the cams on tommorro afternoon,sorry for the inconviece to everyone
It makes me want to pull my valve cover and check my rockers.
I think you've got us all paranoid now!
What was that noise?!?!
ahah G5Mike, you shouldn't worry about our inconvenience, you should worry about your ability, or lack therof to drive you car sooner! haha GET'ER DONE! and lets see some results!
P.S. take your time, and makes sure the job gets done right! good luck
Mike you have Stage2 cams in your sig. Are you testing stage 1 or 2s?
I have a question for JBP, do your testers normally do the tunes for your camshafts?
I see that G5Mike is going to be gathering his own method of tuning for your camshafts. Wouldn't your cams see better gains if the manufacturers themselves were to do the tuning for the cams?
Sounds a little odd that the tester would have to gather their own tune. Not meant to be harsh in anyway, just wondering.
Originally Posted by campo165
man, i didnt even know 4 cylinders HAD rockers..i thought the cam hit the top of the springs...hmpf.
Other engines run the overhead cam against a rocker. One end of the rocker pivots on a hydraulic pivot point, the other on the end pushes down on the valve. That hydraulic pivot is like a hydraulic lifter, preventing the need for adjustments.
BTW, these designs can be found on any engine configuration. Older 4-cylinders didn't have overhead cams (well, except for exotic cars) so this isn't just a 4-cylinder thing.
-J-
So you give us a range of revs (7900-9000) but which company will do what? Im curious because I want to know if the 2.4L can do an 8K limit with new springs and retainers. Will the valves need to be replaced? Will the engine hold up to it? I have asked these quesitons again and again and yet no one will give me a good decisive answer. Yes I can change the springs and retainers and be good to 8K or NO I will have to do more work than that and an explanation of what would be wonderful answers.
Hey LE5 guys,
Thanks!
Thanks!
thx
WopOnTour
Originally Posted by WopOnTour
What is the lift of these cams (@lobe)
thx
WopOnTour
thx
WopOnTour
At any rate, we'll post full lift and dur specifications @ 0.050" after some time of the official release on the website product page.
Also, we are to sell the special tools on the website in which to do camshaft and spring installs for our customers who purchase cams and springs from us. We will also offer a tool RENTAL service for end-customers who just wish to borrow a tool (and not permanently keep one) Along with detailed installation instructions... This is something that most manufacturers don't offer....
Oooh, now I am interested. I was considering Ferrea because of the good things I have heard. I am only shooting for 8K and in the process am changing out springs and retainers for the ferrea ones. Next will be the cam shafts and valves for durability and stability. If I wait a while for the cams and valves, I will be fine on stock internals correct? My main worries are the rockers, and the engines capability to handle those rpms stock (8K, no higher). I do have an intake if that makes any difference in considerations. How difficult is the install of the springs?
Thank god for HPtuners, as we now have a way of "curing" a MIL...
I see this as a WIN-WIN for your company, with no monetary investment on your part (if you already have HP Tuners) just the actual tuning time.
By doing the baseline then a good tune you show even more horsepower and driveability, which makes Mike happy, everyone spends lots of money buying cams, there's no more unemployment, the polar caps stop melting, the ozone is repaired, everyone adopts all homeless kittens and puppies...See don't you feel better already!
