ALERT**Dipstick popping out? Here is solution!
Old Dec 1, 2006 | 04:38 PM
SS_SC_Cobalt's Avatar
PIP3983 - can be accessed through the service department.
Engine-Engine Mechanical (07 - Poor, Performance, Power, 13 - Check Engine Light Code, 14 - Leak, Foaming Condition, 20 - Loose, Broken, 21 - Fit, Appearance, Clearance, 26 - Alignment, 35 - DTC, 44 - Intermittent, 45 - Lamp On)
Subject: Oil Leak from Top of Dipstick - Replace Intake Manifold Gasket - keywords Accel Acceleration CEL Crank Crankcase Dip Engine Excessive Hard High MIL P0171 PCV Pressure Repeat SES Stick WOT
Models:
2005-2006 Chevrolet Cobalt SS
2004-2006 Saturn Ion Redline
with 2.0L Engine (VIN P - RPO LSJ)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
CONDITION/CONCERN:
On rare occasions, the engine oil dipstick may become unseated on hard acceleration, resulting in an engine oil leak. If the engine is operated long enough like this, a P0171 DTC could set due to the engine ingesting unmetered air.
This concern is the result of excessive crankcase pressure on hard acceleration. This crankcase pressure may be the result of an intake manifold gasket concern that allows supercharger boost pressure to bypass the intake manifold gasket where it seals around the PCV orifice, which is between the #2 and #3 intake runners.
RECOMMENDATION/INSTRUCTIONS:
If the SI diagnostics do not isolate a cause for this concern, replace the intake manifold gasket using part number 12597855, which contains an updated sealing surface around the PCV orifice. This part number, or any future part number, is designed to address this concern.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old Dec 1, 2006 | 04:43 PM
joeworkstoohard's Avatar
i know that i hate it when my dipstick pops out on its own
Old Dec 1, 2006 | 04:44 PM
BlackyK's Avatar
Didn't you just use a ziptie to keep ur stick under control? I think your idea is better than GM's.
Old Dec 1, 2006 | 04:45 PM
JohnnySasakiMGS's Avatar
tee hee
Old Dec 1, 2006 | 04:57 PM
yes but that is a band aid this is a fix
plus I am removing the IC soon for the dual pass anyhow so having the new gasket is a given!
Old Dec 1, 2006 | 07:13 PM
eastcoastz's Avatar
This problem only started after the dealer removed my intake manifold for a repair. They must have screwed up my gasket somehow.
Old Dec 1, 2006 | 07:19 PM
mugencivicsi's Avatar
Duct Tape.......
it fixes everything....
Old Dec 1, 2006 | 07:26 PM
eastcoastz's Avatar
Too bad that updated PN will not register on any of the GM parts web sites.
Old Dec 1, 2006 | 07:27 PM
p7x's Avatar
p7x
gasket.....my whoe intake manifold was replaced b/c of this.
Old Dec 1, 2006 | 07:28 PM
eastcoastz's Avatar
SS SC Cobalt, I'm not sure, but I don't think you have to remove the manifold to replace the intercooler end plate.
Old Dec 1, 2006 | 07:41 PM
Cobalt_Supercharged's Avatar
Glad to hear that it is the manifold gasket and not broken ringlands or bad PCVs.
You have to remove the manifold to remove and reverse the flow of the cores. They are directional. plus it is extremely difficult to reach all the bolts due to the oil filter placement. Look here. https://www.cobaltss.net/forums/advanced-performance-modifications-130/dual-pass-intercooler-38126/
Old Dec 1, 2006 | 07:44 PM
yes you do!
the cores are unable to be removed in car...
Old Dec 1, 2006 | 07:45 PM
p7x's Avatar
p7x
not bad PCV but I think its a good idea to modify the PCV for extensive modding.
Old Dec 1, 2006 | 08:29 PM
well if an intake gasket fixes the issue why mod the pcv system?
I modded the pcv on the srt, but a lot dont and have few problems
Old Dec 1, 2006 | 08:49 PM
CrateEngineDepot's Avatar
Gaskets are on order and will be up on CED first part of next week.
Its nice to know GM is listening to us when we forward them some of our problems and are getting back to us with solutions.
Old Dec 1, 2006 | 09:26 PM
WOHOO!!! Snow covered GASKETS!!!!
Old Dec 1, 2006 | 09:42 PM
distillion's Avatar
this happened to me once, GM gave me bigger orings, now i have to almost twist the dipstick when i take it out, its in there pretty good.
Old Dec 1, 2006 | 09:46 PM
again a band aid not the "fix" lol
I'm on im me
Old Dec 1, 2006 | 11:59 PM
distillion's Avatar
how much would these gaskets run, i wanna put this sucker on for when its time for me to mod more and the blower has to come off
Old Dec 2, 2006 | 12:42 AM
c24na's Avatar
anybody know how much this new gasket costs??
Nate
Old Dec 2, 2006 | 03:41 PM
New Improved intake gasket
Here is a link to the new gasket on CED
Click here
Old Dec 4, 2006 | 09:16 AM
Click here
TOM~
Old Dec 5, 2006 | 10:56 AM
New Intake Gasket
In Stock
Click Here to order
Old May 22, 2007 | 08:06 PM
06black's Avatar
had to bring this back, needed the PIP info.
Old May 22, 2007 | 10:49 PM
c24na's Avatar
I bought the new gasket and installed it when i took off my s/c last month. I honestly could not tell the difference between the two, other then the part number. I hope it really did change. I sure couldn't see it
Nate
