Electrical: Spinner's LC1 Installation Guide with Pics! (no 56k)
Old 01-04-2007, 06:37 PM
Spinner's Avatar
Since there were no good guides on how to do this, and since I was tackling it blind, I made a small guide to help people with installing a wideband on our cars. Complete with pictures.
So, before we begin:
Time required: 1-2 hours
Tools Required
Soldering Iron
(4) Round terminal ends
Electrical Tape
(Optional) Shrink Wrap
Zip ties (At least 6)
Ramps, a jack and jackstands, or ab]B lift.
A buddy (recommended)
10mm Socket
Small cutters
Large Flat screwdriver to remove fuse panel
Fuse Puller (from your fuse box under your hood)
Step One: The wiring
Lay out your LC1 wideband, it should have seven wires coming out of it. The brown/yellow wires are your wideband outputs, we will not need those for now. Put them aside. What we're focusing on first are the Blue, white, green, and black wires. My iron is a small butane soldering iron, and an easy button. Gotta have an easy button.
Take the blue, white, and green wires and slide a round terminal over the end of the wire. Solder the terminal to the wire with a soldering iron. Once soldered, set them aside, they should looks like below.
Now, take the black wire, solder the positive end of your LED light to the black wire. Once cooled, either heatshrink, or electrical tape off this connection so no metal is showing. Now, solder the black end of your LED to one of the ends on your push-button switch. Again, shrinkwrap or tape this connection. Finally, you put a round terminal end on the only open end of the switch. It should look like below.
Note: If you wanted the led/switch to be visible, you'd have to set them in the panel you wanted them to be in before soldering. Since they aren't used as part of the wideband's regular function (only calibration) I chose to have them hidden inside my panel with the rest of the wiring.
Great, you've now got all four grounds with terminals on them. Time to move on to the sensor itself.
Find the O2 plug in your exhaust, it should look something like this. Remove the plug, and screw in your sensor. Tighten it enough to crush the crush washers, it doesnt need to be hercules tight.
Attach sensor to LC1 module, and zip-tie LC1 module into place. This is the location I used. It sits ~1" above the frame, so there is no chance of damaging the wiring or the module.
And a better view of the mounting. I used 3 zip-ties to make sure it wasnt moving anywhere.
Now, take your wiring coming from the LC1 harness, and snake it behind the hard lines shown here. There is plenty of space. I highlighted where the wires are in the picture.
Once you get this far, just let the wiring hang. We need to go inside the car before we can go any farther. Open your door, and look behind your pedals. Behind the clutch, you will see a large rubber grommet plug, with some wiring coming out of it. Pull on an edge of the grommet (this may take some force) and pull the grommet into your car. Cut a small notch in the grommet plug for your wiring (not shown in pics)
Okay, now return to being beneath your car. If you have a buddy, have him stay inside the car, so he can grab the wires you're about to snake through the hole you just created by moving that grommet. Snake the wires into the car. The hole is next to the steering shaft, that makes it easy to find.
Now have your buddy pull the wires through, or do it yourself, enough to remove all the slack on the wires so there's nothing loose in your engine bay.
Once the majority of the slack is removed, zip-tie the wiring to the hard lines in the engine bay so there is no chance of them getting stuck to the steering shaft
Great! The underhood part of this installation is OVER! Its all gravy now.
Open your drivers door, and to the right of your pedals is a fuse panel. Use a big flathead screwdriver to remove the plastic screw in the rear, and remove the panel. Behind it is a fusebox, and two 10mm nuts. Use your 10mm socket to remove the two nuts.
Now, once nuts are removed, place blue wire terminal end over top stud. Put nut on, and tighten. Now place the white, green, and black wires over the bottom stud, and tighten the nut. It should now look like this.
Now, remove the 15a fuse shown in the picture below with the fuse puller from your main fuse box. (It's a small white piece) Cut the hard end off of your red wire with some cutters, and strip the wire so you have some loose wire strands showing. place the strands over the lower hole where the fuse pushes in; and use the fuse holder to push the fuse in over the wire. This should hold the wire into place. Now you have a switched power source.
Final Step
Hit your easy button. "That was easy!"
You are DONE! Connect your wideband outs to whatever you wish (I didnt, I juse use the digital out) if needed, and replace fuse panel with all wiring behind it. Replace grommet back into hole. If you run the wires out of the grommet hole and under the carpeting behind the pedals, they will be invisible in your interior. Follow the LC1 calibration instructions, and start monitoring!
Old 01-04-2007, 06:47 PM
This is a great how to, so it's moved to the how to section.
Old 01-04-2007, 07:11 PM
Doc
Doc's Avatar
Awesome
Old 01-04-2007, 08:26 PM
CHARGDSS's Avatar
Is it ok to leave the wideband sensor in all the time and just use the analog output to act as the stock sensor?
<-----A/F Wideband noob
Old 01-04-2007, 08:31 PM
intense_SS's Avatar
great post!!!!very usefull
Old 01-04-2007, 08:33 PM
Spinner's Avatar
There is no need to remove the WB. The bosch 5wire comes oem on several vehicles.
Old 01-04-2007, 11:19 PM
CobaltPerformanceParts's Avatar
Very Nice!
Old 03-23-2007, 05:00 PM
Boost Fr33k's Avatar
i just got the AEM wideband gauge. it says that the wires black is for ground and white for analog output and blue for serial output. is the wires you hooked up for ground the same?? im a little new to widebands
Old 03-26-2007, 09:11 AM
NGalaxyTimmyo's Avatar
What fuse did you use? I'd go out and look, but my car is currently at my girlfriends house, up on jackstands, waiting for me to finish what I've been doing all weekend.
Old 03-26-2007, 09:20 AM
CTCOBALTSSS's Avatar
Nicely done. I have to do this soon so thank you.
Old 04-13-2007, 09:41 AM
SKDR112888's Avatar
is the 02 bung already there or does that need to be added by ashop?
Old 04-13-2007, 09:50 AM
ItalianJoe1's Avatar
Nice, will be doing this to my car soon! I don't know about just sticking the wire under a fuse. I know it works, but its a little ghetto for my taste. Great write-up though!!
Old 04-13-2007, 10:50 AM
CHARGDSS's Avatar
needs to be added
Old 04-13-2007, 02:23 PM
SKDR112888's Avatar
how much will a shop charge?
Old 04-13-2007, 02:39 PM
Doc
Doc's Avatar
$15, maybe a little more for welding a bung...
I used a 'add a fuse' instead, they run $10.
Old 04-13-2007, 05:59 PM
MikeyMo84's Avatar
sorry for the lame question but wat the *** is a wideband lol
Old 04-19-2007, 12:18 AM
MikeyMo84's Avatar
yeah thanks that cleared everything up
Old 07-19-2007, 09:41 AM
R&C_rallySS's Avatar
^ Going to be installing my wideband this weekend, or at least I hope. Any tips and those pics no longer are up or something. *sob*
Old 07-19-2007, 11:15 AM
RedEcotecSS's Avatar
Old 07-19-2007, 12:50 PM
SoloZ/SS's Avatar
Thats what I think everytime I see some one do a how to and it has something electrical and everybody does the same thing. People you can by a thing called a spade terminal and it will go into the extra terminals in your fuse box and it will be a much better contact and maybe even safer.
Old 08-25-2007, 05:40 PM
pjk91's Avatar
The pictures are not working. Do you have a link for the pictures?
Also, were there any settings you needed to change in logworks from default? Believe it or not, my laptop doesn't have a serial jack. It's pretty new. So I will have to borrow a friends to get logworks up an drunning to change any settings?
Old 10-31-2007, 11:48 AM
RuSSo-29's Avatar
I NEED PICS! lol I've had my wideband sitting my the cobalt in the back seat since I bought it, and I really wanna install the damn thing. Any mods know what happened to the pics?
Old 11-20-2007, 04:54 AM
widebody_balt_ss's Avatar
i would also love to have the pictures...
Old 11-20-2007, 09:14 AM
Doc
Doc's Avatar
Its actually easier than it seems. I have it installed, maybe I can take some pics of the finished product.
Old 07-30-2008, 01:33 AM
Dead Zen's Avatar
tagged for later. pics would be superb.
Quick Reply: Electrical: Spinner's LC1 Installation Guide with Pics! (no 56k)
