Electrical: Cruise Control LED how to
Old Feb 9, 2007 | 05:29 AM
T Dawg's Avatar
Found the camera, so here we go. Sorry for the quality.
Tools and materials needed:
#1 Phillips screw driver
Small standard screw driver
Small LED of your color preference.(check original for size)Mine said 3.6volt.
Soldering iron
Something to desolder with (I got a sqeeze bulb type desoldering iron from radio shack, works great)
Dremel or file if you can't find a small enough LED
First remove the switch assembly by inserting small, flat object(I used my key )
Next, disconnect the harness
Now we revove the two screws, I didn't the first time and cracked the plastic a little. Woops.
Then gently pry the cover open, this is where not removing the screws sucks
After you pull it all apart desolder the LED (note the direction of the LED) if you connect it backwards, it won't light up.
Insert new LED and solder
I had to "customize my LED because I couldn't find a blue that was small enough and didn't want another color. Anyways you can see I dremeled the top flat so it doesn't hit the button. The pics don't show it, but I also took part of the LEDs "lip" Off the bottom. Everything must fit nice or the switch feels all wrong when you push it.
Another pic I didn't take is the LED getting a coat of dark blue sharpie ink. Haven't tried it since the sharpie, but during the day, the LED looked fine, but night time it is super bright, so once I got to work, I colored it. We shall see how it works.
Any ways, put everything back together, took a little finess, and reinstall.
Old Feb 9, 2007 | 12:45 PM
HackAbuse's Avatar
Noice!
Old Feb 9, 2007 | 12:48 PM
mkulrey13's Avatar
did you use 3mm? 3mm seems it woul fit no problem as there really small.
Old Feb 9, 2007 | 01:00 PM
T Dawg's Avatar
only found 5mm in blue at radio shack
Old Mar 5, 2007 | 10:59 PM
06_SS_S/C's Avatar
Cool mod, I just did mine tonight, put in a red 3mm led. Fit perfect, no problems. Thanks for the write up!
Image is blurry, but you get the drift.
Old Mar 5, 2007 | 11:02 PM
05REDROCKET's Avatar
Sweet ass I'm so doing this!
I hate that orange light!!!
Old Mar 5, 2007 | 11:56 PM
06_SS_S/C's Avatar
Be careful, I burnt my finger when I was soldering. I always do...
Old Mar 6, 2007 | 12:11 AM
thanks for the warning
where did you get the 3mil red led
Last edited by 05REDROCKET; Mar 6, 2007 at 12:11 AM. Reason: Automerged Doublepost
Old Mar 6, 2007 | 12:23 AM
06_SS_S/C's Avatar
Radio shack...2 LEDs for $1.29 I think it was.
Old Mar 6, 2007 | 01:48 AM
Omega_5's Avatar
Nice mod...
I'm thinking about switching all of my interior lighting to red (to match the accents).
Do you guys use radio shack quite a bit?
I've found that my local electronics wholesale depot is alot cheaper... as in <.35 cents per LED (<.25 if I buy more than 100) for the super-bright style.
Old Mar 6, 2007 | 02:43 AM
06_SS_S/C's Avatar
Radio shack is a ripoff, but when I just need 1 or 2 of something small, I will go there. Anything in bulk I will order online.
Old Dec 25, 2007 | 12:59 AM
JonyyB's Avatar
Site Founder
swwet, I'm doing this!
Old Dec 25, 2007 | 01:08 AM
Dragonsfire12345's Avatar
looks like fun!!! I'll give it a try
Old Dec 25, 2007 | 02:10 AM
elecblue06's Avatar
if i can find someone that knows how to solder i'm gonna redo all my leds in my stereo and steering wheel, and this really helps thanks alot... especially cuz i wanted to know how to take that part out to paint it
Old Dec 25, 2007 | 11:43 PM
RedEcotecSS's Avatar
^soldering is easy bro. basically just melting metal and using it as glue.
Old Dec 25, 2007 | 11:44 PM
hatrickstu's Avatar
cool mod man!
Old Apr 20, 2010 | 10:40 AM
zerosk8ter83's Avatar
I know this post is very ancient but heres how i did mine and it came out very cool(sorry only pik i had)
Old Jul 9, 2010 | 09:02 PM
trey ss's Avatar
can u do this with all the lights on the steering controls?
Old Jul 13, 2010 | 09:46 PM
Chilipado's Avatar
yes you can
Old Aug 6, 2010 | 12:37 AM
jhop16's Avatar
how do u do this to the newer cobalts? i cant seem to get my 2 panals off my steering wheel... unless i just aint pulling on them hard enough, i just dont wanna break them
Old Aug 6, 2010 | 01:24 AM
yank those hoe's out lol jk man i have no idea i have a older model
Old Aug 26, 2010 | 06:11 PM
deuce's Avatar
the new wheels have a screw holding the bracket in, you have to take off the horn cover to get the screw.... but i cant for the life of me remember how it was done....
found the how to: https://www.cobaltss.net/forums/how-guide-43/how-remove-bezels-steering-wheel-84011/
Old May 20, 2011 | 10:43 AM
irishredheadpa's Avatar
Can't wait to change my lights that are all burnt out
Old Jul 2, 2011 | 03:56 PM
JaredMeyers's Avatar
i have the other style of steering wheel does it work the same?
im guessing its the same just making sure tho.
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Sep 26, 2015 06:44 PM
Coballin13
Sep 25, 2015 08:43 AM
