Collection of various problems with the 2005 Cobalt SS
Old Sep 14, 2005 | 08:15 PM
denny's Avatar
Collection of various problems with the 2005 Cobalt SS.
Taken from the input of 15 www.Cobaltss.net Members.
Build Date: 02/05
Mileage: 2500 Miles
- passenger door panel leather too short (hardly even noticeable so I don’t really care)
- the occasional clunk that comes from somewhere underneath my car which I have no idea where it comes from
__________________________________________________ _________
Build Date: 3/05
Mileage: 4500 Miles
- Rear passenger seat making a little noise, that’s it.
- Service - Oil change & tire rotation (Ft to Bk).
Mileage: 3158 Miles
- Passenger leather coming up on door handle.. driver side handle clicks..
Mileage: 10381 Miles
- I haven't had a single problem yet with my car. Knock on wood.
Mileage:
4500 Miles
- passenger door leather
- e-brake light flashes occasionally
__________________________________________________ __________
Build Date: 4/05
Mileage: ????
-so far i have had to replace my front windshield(my fault, actually my stereo's fault, the mirror fell off about 3 or 4 time so the last time i put it back on i used 5 minute epoxy, and it took a big chunk out of my windshield b/c it fell off again) but the cloth is cut to short on my passenger side door, and my steering feels really loose, got an appointment for that.
Mileage: 5400 Miles
- Leather fitment on passenger door
Build Date: 5/05
Mileage: 2209 KM
-Passenger door leather insert
-Bolt cuts into intake plastic
Mileage:
3300 Miles
- brake pedal switch
- transmission grinds when put into reverse from neutral (a majority of the time) putting it into 1st prior to neutral removes grinding; drivers window seal "wavy" ; squeaky noise from rear passenger side seat
- bolt cuts into intake plastic
- possible wire durability issues (conduit rubs against metal tubing)
- E-brake light pops on occasionally ; paint defect in rear bumper ;
Mileage: 6000 Miles
- Passenger door leather insert cut too short
- It makes a noise when I'm on a bumpy road
Mileage: 8,600 Miles
-Paint defects on the hood - repainted
-Foam jammed sunshade - removed piece of foam
-Rattle in glove box
-Driver door handle clicks sometimes when pulled
-Only hitting 5-6psi in first gear - going to dealer soon with this problem
Build Date: 6/05
Mileage: 4012 Miles
-Sunshade stuck due to that stupid piece of foam put in a bad place. I ripped it off, been fine ever since.
-Parking brake light comes on here and there for a sec. Common problem, doesn't bother me, not concerned.
-The car in general makes several odd noises here and there. HVAC system is certainly noisy with the hisses it makes. I think the backseats rattle over bumps right where the metal latch is to hold them in place rather than fold down. Other than, there's just some small odd noises it makes in general. Music alliveates all! The cobalt has a very quiet interiour, so I expect to hear more.
Mileage: ????
- Door panel leather too short. ----fixed at dealer.
- Vacuum hose was rubbing SC bypass.
- Fuel cap tether brock.----fixed at dealer.
Mileage: 4450 Miles
- After warm up car idle is rough. Engine light. Will have dealer look at it.
dealer reset system and still getting check engine light. Code is P0171. Only get light during hard driving. Made appointment with dealer.
Build Date: 7/05
Mileage: 290 Miles
-Rear passenger quarter panel has small imperfections in the clear coat.
-Side airbag wire in door was installed over the lift motor so that the wire was severed when the window was opened and shut a few times. Resulted in "service airbag" (fixed under warranty)
-Passenger side automatic window is slightly weaker than driver side.
Thank you to all that posted on my thread.
Turbo Johnny
Feb 21, 2019 09:41 AM
How to Guide
57
Oct 15, 2015 11:56 AM
Dope_SS
Sep 13, 2015 05:24 PM
Wind
Sep 11, 2015 06:57 PM
jthwjde
Sep 7, 2015 09:24 AM
