Cobalt Parts Interchangeability
Old May 7, 2007 | 08:28 AM
YellowLT's Avatar
Here a List of all The SS Parts that fit on the Base LS LT Models
Suspension:
FE 3,5 Shocks
FE 3,5 Struts
FE 3,5 Springs
FE 3,5 Front Sway bar
FE 3,5 Control Arms
Wheel hubs
Strut tower mounts
Rear axle
FE 5 Steering rack
Engine:
Exhaust Manifold
Downpipe
Exhaust
Intake Manifold (Will Physically fit but TB will not bolt up)
#32 Injectors Fit Leak free, Tuning is needed.
Pistons
Rods
Valve Springs
Supercharger and Throttle Body with Intake Manifold (tunning needed)
Drive Belt
Interior:
All of It
Exterior
Front Fascia
Rear Fascia
Rocker Panels
Deck Lid w or w/o Wing
Rims (07 only if you have factory alloys wheels.)
Headlights (SS are slightly tinted. I believe 07 has no orange reflector over DRL)
If you have anything else, I'll be glad to add it.
Old May 7, 2007 | 08:30 AM
mkulrey13's Avatar
you forgot rims. all 07's use 5x110 besides the base base model
Old May 7, 2007 | 08:34 AM
YellowLT's Avatar
Fixed
Old May 7, 2007 | 08:38 AM
Coblt ss super's Avatar
this should be stickyied
Old May 7, 2007 | 09:30 AM
YellowLT's Avatar
It'd be my First... Yay sticky Virgin
Old May 7, 2007 | 09:48 AM
WickedSS2005's Avatar
That sounds gross. Nice idea for a thread tho
Old May 7, 2007 | 09:49 AM
yeah it does
Old May 7, 2007 | 10:01 AM
YellowLT's Avatar
yeah it does
In review, I need a shower now.
Old May 7, 2007 | 12:29 PM
tonio5555's Avatar
Great info. Thanks.
Sticky?
Old May 7, 2007 | 01:15 PM
yellow_cobalt's Avatar
wouldnt it be cars with alloy wheels are swappable? i have a 07 ls, with steel wheels, and have the 4x100 so ls trim and up is not correct to say. the 1lt also comes standard with the 4-lug
Old May 7, 2007 | 01:17 PM
YellowLT's Avatar
Thanks I'll fix it.
Old May 8, 2007 | 01:22 PM
Halfcent's Avatar
I'm old school
I'll sticky ya. But you have to keep it current.
Here's stuff:
Change your title to something describing the WHOLE car and not just the engine. For instance SS parts the fit Base / LS / LT models.
ALL the suspensions are completely interchangeable. The FE1, 3, and 5. And all of their components, including but not limited to:
Wheel hubs
Strut tower mounts
Rear axle
The steering knuckles are no different between the models.
Engine stuff:
Intake manifold will physically fit the engine, but the L61 throttle body wont fit the manifold.
Cams are incorrect. The LSJ cams have a position sensor on the exhaust cam that extends out of the head. However, the grind of the LSJ cams and L61 cams prior to 2007 were exactly the same with different timing. GMPP adjustable timing gears on L61 cams can do anything LSJ cam can.
There is obviously much more engine stuff, and that would be a thread all it's own. I think you should stick to bolt on stuff.
Exterior stuff:
Use the correct names. They are called Facias, not bumpers. Bumpers are on trucks. Facias are molded plastic covers over impact reinforcements, which is what most cars have.
Also, it's called a Deck Lid. The trunk is the empty space under it.
Old May 9, 2007 | 09:37 PM
kwest's Avatar
So i have a 06 ss/sc. my buddy has a 07 ls coupe. i got a aftermarket exhaust, so will my stock ss/sc exhaust fit on his 07 ls??? or would there be any point in doing that?? would you think the sound or power would change any??
Old May 10, 2007 | 12:39 AM
Halfcent's Avatar
I'm old school
All exhausts are completely interchangeable. And the SS exhaust is slightly larger then the base ones, so there would be some gain.
Old May 16, 2007 | 02:19 PM
TPRMcfly's Avatar
question, so can i get the 5 lug wheel hub for my 06 ls? and get ss/sc rims?
Old May 16, 2007 | 04:48 PM
YellowLT's Avatar
Yes you would need to swap all the wheel hubs and convert the rear brakes to disc from drums
Old May 23, 2007 | 01:35 PM
Delta2.2's Avatar
what are expected HP gains from a ss/sc header and downpipe on a 2.2 from 06?
Old May 23, 2007 | 09:18 PM
Halfcent's Avatar
I'm old school
Not enough to really notice a power difference, just a few more HP. You would probably notice a sound difference however.
Old Jun 19, 2007 | 03:27 PM
Black07LS's Avatar
Will an 05 SS/SC shifter assembly work in a 07 LS?
Old Jun 19, 2007 | 05:20 PM
YellowLT's Avatar
Not too sure, but i believe No because of the Reverse Lockout. I know that the B&M shifter for the 2.0S/c doesn't work on the 2.2 or 2.4. I'll check into it but you better off going to After Market anyway.
montecarloman's Avatar
As I recall the shifter design is different. The SS/SC has a lift lock to shift it into reverse, all others dont. it might physically fit but it wont be right by the way YellowLT got a correction for ya
The FE5 front swaybar uses 2 bolts per mount to secure the swaybar to the sub frame. The FE1 and FE3 bars use a slot in the rear on the mount and a single bolt per mount in the front. The good news is the FE5 mounts slide into the original slots and the only modification you need to make is to cut about 3/8 of an inch off the bottom of the bushing to get it to fit.
Old Jun 19, 2007 | 05:32 PM
elecblue06's Avatar
you should be able to use the shifter.. you just have to remove the thing for reverse lockout (usually just a bar or something of that nature)... multiple people have used shifters for the RL and just removed the reverse lockout...some people have used shifters without reverse LO they just say it is weird...
Old Jun 19, 2007 | 05:35 PM
Psykostevo's Avatar
In '07 they switched the DRLs from the Turnlamps to the regular headlights. Correct they do not have orange lenses, only orange bulbs.
Old Jul 1, 2007 | 03:58 PM
YelloEye's Avatar
What would be required to change this over to say an '06? as in switch it from the turnlamps to the headlights? Is it just a stand alone box, wiring change, or is that in the ECU?
Old Jul 1, 2007 | 07:56 PM
tonio5555's Avatar
You could either buy 2007 SS/SC headlight housings and just do a straight up swap, or do what I plan on doing and "bake" your headlights pull them apart, take out the orange lens and replace the clear bulb with an amber or stealth bulb.
