Appearance: how to change fog lamp bulbs.
Old Oct 4, 2005 | 12:56 AM
cobaltsslvr's Avatar
1. If you can put the car on a lift it makes it much easier.
2. The lamps are accessable by prying open the plastic panels on each side. Try to push or position your wheels front facing outward on the current side you are working on. There are approx 3-4 screws on each side, the passenger side having 1 or 2 more, and 2 "pull tab fasteners" (tm) on each side that need to be removed for access. It may look like you need to remove the entire wheel well for access but it is not necessary. Just keep unscrewing and unfastening until you can pull the panels apart to access the foglamps. try not to bend them to much or you might break them but don't be too concerned they are pretty durable.
3. Just like any other bulb, turn to release from the housing. Use a flat screwdriver or other flat thing to release the tab holding the h11 in. MAKE SURE NOT TO TOUCH THE GLASS ON THE BULBS OR THE OIL FROM YOUR FINGERS WILL BURN THROUGH THE GLASS!!! Reinsert the bulb and turn the opposite way to fasten it back in.
4. Repeat step 2 in reverse.
5. Enjoy fog lamps!
Old Jan 18, 2006 | 02:45 AM
GotBoost?'s Avatar
thanks
Old Jan 18, 2006 | 07:25 AM
WickedSS2005's Avatar
Couldn't you just reach through the opening left by removing the headlight? I can see this being a possibility because, well, I spent a good 3 hours trying to take off, install, and re-install the wheel well and screws for my intake, not looking to do it again.
Old Jan 18, 2006 | 09:05 AM
Dark-Fx's Avatar
Actually, the problem with touching the bulbs is that the oil will reflect the light internally, and cause a hot spot on the glass, which will more then likely cause the glass at that spot to melt and crack.
The oil itself won't burn the glass up.
Old Jan 18, 2006 | 09:46 AM
R33P3R007's Avatar
360 L337 User
Do they make the H11 in hyperbright or whatever they call them?
Old Feb 18, 2006 | 02:07 PM
05REDROCKET's Avatar
WICKEDSS2005
Yes you can i just did very easy just take note the position of the light socket when the bulb is tight and when you un screw it. makes it easier to screw back in.
Old Sep 22, 2009 | 04:56 PM
samijo0703's Avatar
sub'd i need to change my left fog lamp.. ugh doesn't look like any fun.
Old Sep 27, 2009 | 11:56 AM
supercharged414's Avatar
not to be a dick, but i find it much easier to remove the headlights and the headlight brackets. Its a total of 4 or 6 bolts and you have infinitely more space to work in.
Old Oct 10, 2009 | 05:22 AM
thedude411's Avatar
agreed its wayyyy easier to take the headlights out and then reach down. takes like 1 minute to do... minus u usually have to re-aim them after...
Old Oct 10, 2009 | 06:35 AM
06SS ALL DAY's Avatar
wow dood. either way the ******* bulb gets burnt out by the oil from the finger. To the OP good write up dood. and perfect disclaimer. no need to change anything
Old Oct 10, 2009 | 11:53 AM
samijo0703's Avatar
well from personal experience next time (for the driver side) i think i'm going thru the wheel well... air horn gets in the way. (thank god for little hands)
however the headlight has plenty of room for those people with big hands. lol
Old Oct 13, 2009 | 08:58 PM
boomhauers_07G5's Avatar
if no body minds me askin but i put a gt bumper on my g5, the question i would like to know is how easy is it to remove the whole fixture and re-install? damn i feel like a noob.... lol
turbochargedss2012
Sep 20, 2023 12:17 PM
importkiller
Sep 30, 2015 07:18 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
roth
Sep 26, 2015 12:16 PM
