2.85" Pulley Help
Old Jun 22, 2007 | 12:01 AM
Scythe_Snake's Avatar
2.85" Pulley Help
Hey Guys,
I just got a pulley in from Nate (which, by the way is EXCELLENT and I encourage everyone to buy form him), and me and my friend (pinoypapi198369) were trying to put it on tonight (in the dark, yeah we know, not the smartest move, should have waited for the mornign but we were both so excited and wanted it on).
Me and pinoypapi198369 went to my place to unbolt the Stage 2 pulley and put it on. We had light, in my garage, and so we went to work, popped the hood and were trying to loosen the stage 2 blue-bolts with the tool that came with it. We noticed the pully kept moving as we tried to unscrew the bolts. Then....we heard a *snap* and low and behold the piece (end) snapped off, and fell down somewhere. Then we tried to get a piece that would fit similarly, and it fell off (it later turned up as he was backing out of the drive way). So, in the first step we had probelms and I couldn't find a "How-To" on how to replace the stage 2 pulley with a smaller one. I ahd printed peices and bits that gave the basics on how to take the pulley off.
Can you all help us. We have this brand new, sexy, polished pulley with new screws in a package that is begging to be mated to the Eaton M62 sitting in his engine bay. Can you guys tells us what we need to do in relation to getting the pulley off and getting the new one on?
Old Jun 22, 2007 | 12:40 AM
pinoypapi198369's Avatar
yea anything would be great!
Old Jun 22, 2007 | 12:45 AM
M-Dub's Avatar
I don't know if I am understanding you... a 15mm wrench is needed to loosen the tensioner. I used a very small ratchet with the GM bit on the end... I left the belt tight untill I had atleast broken loose all the bolts, then I loosened the tensioner, pulled the belt off to the side, and got the rest of the bolts out, and then just reversed the process and put on my SHINEY 2.85 Pulley from Nate, and then once again, used the 15mm wrench to loosen the tensioner,( pushing towards firewall) and I was done, took me about 20 minutes!
Old Jun 22, 2007 | 12:55 AM
on the tensioner do u push forward and then pull the belt off? i guess thats the part where we got confused, sorry for the stupid questions but we were confused.
Old Jun 22, 2007 | 01:00 AM
M-Dub's Avatar
Leave the belt on untill you have the bolts loose, you will have to hold the pulley still to do it. Then Push the tensioner towards the firewall of the car (towards the rear!), Once you do that, the belt will loosen up enough to just pull it off!
Old Jun 22, 2007 | 01:04 AM
Our main problem was when we were trying to break the bolts loose. The piece in the stage 2 kit broke as we were trying to break the bolts. The pulley also kept moving as we tried to unbolt them. Can we only use the stage 2 piece, or is there another size we could use to unbolt the pulley?
Old Jun 22, 2007 | 01:06 AM
M-Dub's Avatar
Nope that bit is specialized to it, there should have been two of them in the box, one for like a screwdriver, and the other made to go on a 1/4" ratchet! While you still have the belt on, hold on to it as hard as you can, that is how I did it! You just have to do what you can to keep it from spinning on you!
Old Jun 22, 2007 | 01:13 AM
Okay...thanks M-Dub. If you could, give another overview of lwhat we're to do, in the order you did it in?
Old Jun 22, 2007 | 01:20 AM
yea i still have the screw driver piece hopefully i can just use that we'll mess with it again sometime soon
Old Jun 22, 2007 | 01:28 AM
M-Dub's Avatar
1.) While belt is still on pulley, loosen the four (4) blue bolts from the snout of the S/C, do not remove them yet.
2.) Use the 15mm open ended wrench, put it on the little notch on top of the tensioner, and push it back towards the rear of the vehicle.
3.) Slide belt off of the S/C pulley, and lay it aside, I did not take it all the way off!
4.) Hold on to the pulley, and continue removing the bolts from the S/C the rest of the way, and slide the old pulley off.
5.) Put your new "SHINEY" pulley on the snout and tighten the bolts up as much as you can without the belt being on.
6.) Use your 15mm wrench, and push the tensioner back towards the rear of the car again, and slide the belt back over the pulley!
7.) Make sure belt is lined up correctly, take care to insure that it is not misaligned and is on track to the crank pulley as well! (you will be able to tell if it isn't!)
8.) Tighten the bolts back up with the supplied GM bit, take care not to over tighten as your new pulley is alluminum!
9.) Now test drive and enjoy, then go home yell, cuss and scream while you drink beer (or Rootbeer if under 21 of course)!
Old Jun 22, 2007 | 01:32 AM
Thank you so much M-Dub! +rep for being as helpful as you have been!
Old Jun 22, 2007 | 01:35 AM
lol, i'll mail you a 24 case of ur choice lol
Old Jun 22, 2007 | 01:38 AM
M-Dub's Avatar
Not a problem... just returning the favors I recieved when I was doing the same thing a few months ago! Glad I could help, refer to my picture so you can see the little notch I am referring to for the 15mm wrench, it is what is circled in yellow!
I think I deserve a "HOW TO" on that one!!!
Old Jun 22, 2007 | 01:45 AM
How To
Actually, that woudl really, REALLY help. Pictures and a step by step thing, We'd use it,a nd it woudl be VERY helpful. There isn't one yet.
Old Jun 22, 2007 | 10:46 AM
RedEcotecSS's Avatar
i'd definately use it. i've been looking for a how-to on a pulley swap from a stage 2 pulley forever....
Old Jun 22, 2007 | 04:33 PM
syP's Avatar
syP
so you ended up getting the bolts out?
Old Jun 25, 2007 | 12:25 AM
i still haven't been able to get bolts out, they're way too tight. I'm thinking about taking the super charger out and using a drill to get those freakin bolts out. what do u guys think? or maybe a better suggestion to get them out.
Old Jun 25, 2007 | 12:29 AM
M-Dub's Avatar
GO back to the dealer and have them break them loose! I know my dealer would help out with that!!
Old Jun 25, 2007 | 11:59 PM
ok, i'll stop at the dealer tomorrow when i get my tires rotated!!! Thanks
Old Jul 9, 2007 | 03:51 PM
if it dont break loose, do like i did and cut the damn pulley out. lol
Old Jul 9, 2007 | 06:01 PM
sscobaltscZ06's Avatar
I just went out and tried to get my stage 2 bolts off to put our 2.85 on and they wont budge either! Dealer obvioulsy used loctite on them. Im afraid if I try any harder its gonna strip that special head on the bolt or bust the special socket. Im using a 18" breaker bar and they still wont budge.
Old Jul 9, 2007 | 06:13 PM
syP's Avatar
syP
scythe.. did you end up getting them out??
all i did is i went to sears and got the bolt out.... hammered it on.. and used the wrench to get it off.
im in the naperville area, im sure i can help you out if you still need it.
Old Jul 9, 2007 | 06:22 PM
Originally Posted by sscobaltscZ06
I just went out and tried to get my stage 2 bolts off to put our 2.85 on and they wont budge either! Dealer obvioulsy used loctite on them. Im afraid if I try any harder its gonna strip that special head on the bolt. im using a 18" breaker bar and they still wont budge.
did u get any of them out?
Old Jul 9, 2007 | 06:27 PM
Nope not yet, they will not budge. Im at the end of the 18" bar and the pulley isnt moving at all either. Nowhere in the instructions for stage 2 does it tell the tech to use loctite but they did (probably the red stuff that needs heat and an impact to remove), but since they are only torqued to 15 ft/lbs they should turn out very easily.
Note: I just torched each bolt and tried to break each one free after heating the hell out of it with torque wrench set at 125 ft/lbs and no click, still no breaky loose.
Old Jul 9, 2007 | 08:37 PM
saunders1986's Avatar
god... i hope mine goes better than this lol
