My car just shut down on me!!!!!
Old Nov 27, 2007 | 05:44 PM
2fastSS's Avatar
Ok so i was coming home from work found out i was on E... go home change do all that when my girl called and asked if i could come get her cuz shes not feeling to well, so i drive down the road to a exxon gas station... Now i usually always put in my car shell 93 but this was closest so i put 10 dollars in...
Pick her up, on the drive home had this woman blaring her music while me and my girl were just talking... So i put my music up all the way and light turns green and i rev up to i say 5-6 grand it comes back to idle and it just goes to about 100-200 rpms and it shuts off on me!!!!!
Now i tried to restart it but it took a few minutes and then went right back to normal...This was right in the middle of an intersection disrupting traffic and all
NEWAY HELP ME OUT, WHATS WRONG WITH MY CAR
Old Nov 27, 2007 | 06:15 PM
SSdan's Avatar
Piston #4 or more = gone.
Old Nov 27, 2007 | 06:19 PM
Jimmys2007CobaltSS/C's Avatar
i knoe how that feels my car shutdown on me at 20mph and its still in the shop and its an 1hour 10 mins from home as well...
Old Nov 27, 2007 | 06:21 PM
ItalianJoe1's Avatar
bad crank position sensor??
Old Nov 27, 2007 | 06:23 PM
devon9832's Avatar
My never shuts down but she seems like she wants to. It'll go all the way somewhere around 400rpm but then revive itsself. Is something wrong? should i have it checked
Old Nov 27, 2007 | 06:24 PM
SSdan's Avatar
It's most likely the crank sensor, not the piston. Just said that as a joke.
It's happened to me twice, almost a third today but the car didn't shut off for some odd reason.
Old Nov 27, 2007 | 06:30 PM
Omega_5's Avatar
... Mine shut off due to a faulty fuel pump connector, just a few weeks after I picked it up.
Died, waited, fired back up about 15 minutes later.... might be worth checking if all else fails.
Old Nov 28, 2007 | 11:02 AM
layman06SS's Avatar
mine did this samething to me only i was on the interstate getting of when i down shifted to third to slow down it just died. tried to start it several times would start. Let it sit for about 15min. and it started ran fine. I wander if the crank sensor over heats or miss reads. mine also sometimes will drop down to 400rpm and putter for a split second then run fine.
Old Nov 28, 2007 | 11:11 AM
Navarch's Avatar
Sometimes when I pull up to a light and stop, the RPM's dip down, revive, dip down, revive and does this for 10 -15 seconds and then levels off and idles normally. Any suggections as to what it might be??
Old Nov 28, 2007 | 12:18 PM
quadracer0387's Avatar
^^^ i think most people have that problem including myself... i could never figure it out
Old Nov 28, 2007 | 05:28 PM
Crappy factory tune. Stage tune usually fixes that.
Old Dec 6, 2007 | 06:05 PM
Boosted07SSSC's Avatar
Hmm have to keep this in mind
Old Dec 21, 2007 | 12:21 AM
silverSS's Avatar
might want to watch what problems you post about a car your trying to sell.
durh
Old Dec 21, 2007 | 12:25 AM
Raven SS's Avatar
lol...why is ur online thing red? invisable..hmmm
Old Dec 22, 2007 | 01:43 PM
MBMCustoms's Avatar
Mine shut off on me after getting my custom 3in exhaust. i accelerated hard and the car shut off on me. i was stalled out at an intersection and had to push it to a gas station and wait about 5 minutes before it would start back up. i took it in to my dealer and they fixed it in a few hours and said I had a faulty connection from my stock pcm. it was all covered under waranty. if your car is under waranty go get it checked out.
Old Dec 22, 2007 | 01:53 PM
The Punisher's Avatar
durh
LMAO
Old Dec 22, 2007 | 01:57 PM
DoubleLP's Avatar
durh
HAHAHAHAHA
Old Dec 22, 2007 | 02:43 PM
JustMiller25's Avatar
I was making a right on red and saw an suv coming, it seemed to be cruising slow enough for my to jump out in front of (I was in a hurry) so i jumped out and the car died off. It never did tht before and I paniced bc I just jumped out in front of an oncoming car. Luckily the guy noticed my lights shut off (it was at night) and he swervered around me, giving me time to turn the car back on. It was normal after tht! My buddy said it mighta been bc we were messing with the headlights and the car had a surge or something,l but he said its happened before in his mustang and he has yet to figure it out.
Old Dec 22, 2007 | 03:56 PM
2fastSS's Avatar
durh
you think i need to hide **** to sell my car??? Shows how honest of a person you are, im not affraid to tell people that the car is normal just like everyone elses stage 2 problems.... But the car runs perfect, it is normal for a stage 2 tune to have idling issues and that was the case here....
Old Dec 22, 2007 | 04:23 PM
rallyracer's Avatar
Same thing happened to me yesterday.
Old Feb 28, 2008 | 08:22 PM
Ragnarok69's Avatar
ive had the same problem was told "Crank Positioning Sensor"
Old Mar 28, 2008 | 03:45 PM
valentino0214's Avatar
if u have a cai on ur car put the stock 1 back on and take the battery cable off of it for about 5 mins and then start her up and she should run fine... i was in 3rd gear wen i had my cai on and it just started to break up and died on the turpike... and started back up took a couple seconds... put i got home and changed it back to stock intake and runs awsome again
Old Mar 31, 2008 | 05:35 PM
Ragnarok69's Avatar
still running the car completely stock no kits, stock air box, original
Old Mar 31, 2008 | 06:25 PM
deff ur pistions
Old Aug 27, 2008 | 08:32 PM
goins213's Avatar
I had the same issue with my '06 SS/SC. I took it to the dealer cause it died like 4 times on the way to the store. They "shocked the ECU" and said if it happens again to bring it back up to them. It's been about a year now and NO problems since then.
