2008 Cobalt SS Brembo brakes - Min. 17" Wheels
Old 09-04-2009 | 01:26 AM
  #126
Force's Avatar
Originally Posted by Routs
So, anyone find any really decently priced wheels to use for winter with the Brembos???
Originally Posted by TMRRedline
Personally, Im just going to use a set of 18in wheels from a SC and use spacers if needed for the winter. Its the winter, I dont drive the car hard so using spaces is not an issue for me. And you can find SC wheels cheap
The SS/SC wheels won't fit without insanely big spacers due to their design. You need to find 17" SS/NA wheels, they fit with no spacers. Look up MARIN007's gallery to see pics.
Old 09-04-2009 | 07:12 PM
  #127
Routs's Avatar
The problem is that the SS/NA wheels are getting as hard to find as the SS/TC wheels...
Old 09-04-2009 | 07:39 PM
  #128
Black08SSTC's Avatar
i have a beautiful set with brand new tires
Old 09-11-2009 | 02:50 PM
  #129
Routs's Avatar
I just heard from a very reliable source that MB Wheels will be coming out with a new wheel that will fit the SS T/C's (they've had this design for a while but they are going to be doing a 5x110). The wheel looks like this:
I've already preordered a set of them for my car (I got a great deal). They actually look like really nice wheels. It's almost a shame that they will be going on for winter!
Old 09-12-2009 | 11:22 PM
  #130
jerrodmann's Avatar
price for them?^^^
Old 09-13-2009 | 02:16 AM
  #131
Routs's Avatar
Canada
Originally Posted by jerrodmann
price for them?^^^
I know a guy so I'm getting them for less than $140 Canadian each (his cost). I'm not sure what they retail for normally. You US guys should get it at much less than we can.
Old 09-15-2009 | 12:18 PM
  #132
novaracer_2000's Avatar
Has anyone tried the 17 inch G6 steel wheel?
Old 09-15-2009 | 12:41 PM
  #133
Force's Avatar
No steelies fit, period, unless one has somehow been custom-designed since last winter. If you want a set of winter wheels for the SS/TC, you're going alloy.
Old 09-15-2009 | 02:38 PM
  #134
Routs's Avatar
People have actually said that the GM steelies off of the G6, Malibu, Astra do work. Never tried it myself because I couldn't find any locally.
Old 09-25-2009 | 01:49 PM
  #135
thebeast's Avatar
is anyone here selling there brmebo brakes. im looking for them. i figured i might get lucky and find someone who upgraded them and is willing to sell them. thanks
Old 09-26-2009 | 12:11 PM
  #136
NickD's Avatar
I found these rims and was wondering if you know if they work with the factory lugs or if I will indeed need to buy a set of lugs for these.
Old 10-08-2009 | 01:50 PM
  #137
Routs's Avatar
Sorry man, I haven't checked this post for a while. I just picked up the rims and tires yesterday and they are being mounted together in the next few days. I'll post pictures and let you know if the stock lugs work or not.
Old 10-08-2009 | 04:00 PM
  #138
NickD's Avatar
Thanks I actually got my rims in a couple of days ago. I am not getting tired mounted on them till the end of this month though. I was going to do a quick test fitment this weekend to check clearances and what-not as well as the lugs.
Old 10-08-2009 | 07:15 PM
  #139
mongorat427's Avatar
Check the wheels and tires section. There's some reasonably priced 18s that fit no problem. As far as 17s go, I don't know of any offhand that don't require the 3mm spacer.
Who sells the spacers ?
Old 10-08-2009 | 10:50 PM
  #140
thebeast's Avatar
i have a 2006 pontiac g6 heavily modded and i have the brembo brakes getting ready to put them on. they do fit the 17 in rims. you just need a 5mm spacer.
heres pictures of the calipers i had them powdercoated red
im just waiting on my spacers to come in and the install will be done
Old 10-09-2009 | 11:54 AM
  #141
Routs's Avatar
I got the wheels back yesterday from the shop and they will not fit. You definitely need a spacer of some kind to make them work. To say I'm pissed is an understatement. I'm currently deciding if I should go the spacer route or return everything. I just hate to have everything demounted and then a new set remounted when they come in...
As far as the original question goes, you need aftermarket lug nuts for it to work. The hole is too smal for the factory lug nuts to fit in the hole.
Old 10-09-2009 | 12:11 PM
  #142
NickD's Avatar
Okay, thanks for the info. I don't mind getting spacers for this set up as opposed to returning everything and starting my search over again for wheels. Do you know roughly what size spacers will be needed? If not, I'll probably do a test fit myself this weekend. How do you determine the spacer size?
Old 10-18-2009 | 12:41 PM
  #143
NickD's Avatar
So I test fitted the MB Wheel Seven X rims yesterday and they do indeed interfere with the calipers. I took a few pictures. It looks like at least a 5mm if not a 7mm spacer would be needed; click for a larger version:
Old 10-18-2009 | 03:44 PM
  #144
Force's Avatar
Everyone still looking for 17s should check out my wheels - BSA Model 264. Only needs a 3mm spacer... Then again, it might fit without them, I think it might JUST clear.
Old 10-18-2009 | 03:50 PM
  #145
berto's Avatar
im good never gonna drive on snow
Old 10-21-2009 | 07:41 AM
  #146
smipinstr's Avatar
I accept: Just a heads up to all considering upgrading to the new 2008 Cobalt SS Brembo brakes. According to the GM engineers, 17” is the smallest size wheel that will fit over these brakes.
Old 10-21-2009 | 09:04 AM
  #147
NickD's Avatar
So I checked out TireRack a couple days ago and called them yesterday evening. They had these in 17" listed for the 08/09 SS/TC:
Borbet LV5:
They guaranteed me that they will fit. I ordered them up with a set of snow rubber and it included hub-centric rings and the lugs. They won't ship for a few more weeks yet, so once I get them I'll test fit one and post my results.
Old 10-21-2009 | 09:20 AM
  #148
nice, where in Jersey are you??
Old 10-21-2009 | 09:35 AM
  #149
NickD's Avatar
Just northwest of Somerville right off RT78.
Old 10-21-2009 | 09:56 AM
  #150
cool im in 07506. Nice wheels, keep us posted on the fitment and take pics in a few weeks
