25psi Spike on GM Tune
I kind of have an off topic question.. Do you think having a GMS1 Trifecta or HPTuners will make your car less efficiant on the track (like autocross not drag) due to traction issues, losing control on turns ect ect? or do you think if you can maintain proper speed and know what your doing it will be even quicker?
Continue..
Continue..
It only spikes 25psi after I clear the code: P2096 Post Catalytic Fuel Trim Bank 1 System Too Lean. And then it pulls like a raped ape at 25 psi, then I try a minute or so later, and it holds 20psi like it should....
Is this the ECU not being about to compensate for the first WOT after I clear the code (Kinda like learn down?)
Yeah the ECU knows somethings up, then you clear the code and it forgets and then compensates to prevent overspinning the turbo. Your pretty much ******* with your ECU and the turbo is paying the price lol
Yea, that's what I'm thinking. I just hope the Hahn DP fixes this problem.
I dynod mine with full boltons and the stage kit... dyno was a little gay but i got 286whp and 297tq
#37
