Bnr k04-gt28
#501
As slow as you guys are getting around to installing I'll have my turbo off in 2 weeks, drive down to BNR to get a turbo and re-install, only problem I'm having is deciding on stage 1 or 2.
Having the UICP fabricated to work with the stage 2 turbo plus a bov flange is no big deal, just afraid of lag city with the stage 2.
But damn it would be sweet to be sitting at 375-400 whp.
#504
#506
#509
Let us know if you do the install FF_ace
I know this has been touched on before but is it easier to try and remove the turbo through the top of the engine bay? When I did my pistons it was easy cause the valve cover whas out of the way and so was everything else. Wondering if that is still necessary to swap the turbo out too.
#511
You damn well better be . We have like 20 people with money burning a whole in there pockets
It's the middle of January I wouldn't want to be installing that in my garage 0 degrees.
I bet it would make hella power tho this cold
Seriously tax time is right around the corner.. I can't wait for the results.....
#512
#516
just so u know i almost maxed out on my fuel up top with 91 and meth. with the twinscroll it feels almost like the stock turbo. all i can say is over boosting lol.
#517
really you have the fuel maxed out on your 2871? what size nozzel do you have on your meth injection? did you have vince up your fuel pressure? with my e85/91 mix im doing fine but vince did up my fuel to 2800psi and i have the meth injection kicking on at 7psi with a 3gph nozzel
#518
#519
#520
I have FF aces old dejon kit and let me tell u it is definitely easier thru the bottom. Also FF ace I believe I told you the spool up problem with the dejon kit was the manifold. Anyway my new manifold comes in tomorrow. Also meth is going on. I will have to get a video for u to see ur old setup on a run. If I am right about the manifold like I'm pretty sure I am, this car is going to be sick with this kit. /thread jack
#522
#523
#524
Both. Im using the trifecta/hp tuners combo.
#525
spool up is fsater!!!! it almost feels like stock. just need to tune it. it like 27 psi right now so i taking it real easy. still pulls real good when tglems gets his on u will see. i will be finally doing the two tune thing soon.
