Bnr k04-gt28
Old 01-14-2011, 06:36 PM
  #576
PrincessTurbo's Avatar
Originally Posted by Matt M
I always hear about Kappa's making less power with the same mods, but I have not found that to be true. We own both and have dyno'd them and many others and the difference just is not that much at all. We are talking less than 5whp difference. Maybe 3.
So frankly we both don't know wtf we are talking about ...
Old 01-14-2011, 08:04 PM
  #577
FF_ace's Avatar
Originally Posted by 40rty
Making 360 efficiently? For how long? With a good powerband and without E-85? Also, you should know term that the sky's will always show lower HP results due to the higher drivetrain lost( in the case of the stock turbo). I'll be impressed when you do 360 at a dyno on stock turbo without E-85 and on pump. I can imagine if you think your squeezing that much power from a stock turbo, the numbers you'll be pulling from this upgrade will be AMAZING. Your such a Floridian, I can tell! Flamboyant cocky about ONE time case with so many variables, but still cling to that one car. How many 360hp SS/TC are out there? FF ace and who else? I know of 350whp on pump 91 here in Cali.
All in all, thanks though for being one of the many tuners in this community.
O-town peeps, gotta Love them.
first off dude you need to get your info right. term has tuned a couple other cobalts that are pushing around the same numbers as me drewbroo is one of them also BYT has 09whiteSS something that has just a lil higher numbers than i do. My tune ive had on my car for awhile now and i havnt had any problems what so ever other than the stock clutch slipping. whos pushing 350whp on cali pump 91? im calling BS or a very happy dyno because i know that cat **** for gas you have out there wont cut it we have the same in az that was the big reason why im running a e85 mix as well as methanol injection. so you need to cool your jets.
Old 01-14-2011, 08:13 PM
  #578
09BlueBaltSS's Avatar
Maybe the SMOG increases octane?
Old 01-14-2011, 09:36 PM
  #579
40rty's Avatar
Look, Whatever you guys do is great and overall if your happy with what you have then awesome. Im just the kinda guy that like everything on a car to be unique and dont exploit/preach that only certain tunes are best. I guess in your situation where its more economical for you, you did that mix and got some nice numbers. Now did anyone want to answer the questions that I asked Term? Lets take your car then, how long does your car make that power for? Does it do it efficiently with the stock turbo? is that at Redline? I'm not trying to push this on cause really what does it matter, I'm just asking what i asked Term is all.
Now, once you guys get this new stage 1 or 2 then we'll really see some numbers and efficiency ranges on the turbo that will be more in line with what I like.
Originally Posted by 09bluebaltss
maybe the smog increases octane?
yep,
Old 01-14-2011, 09:49 PM
  #580
BYT*SS*TURBO's Avatar
Travel to the dyno thread and look at the graph...easy to figure out all of your questions.
Old 01-14-2011, 10:23 PM
  #581
tglems's Avatar
Update on the car...
Went out and drove it around a little. Everything is installed. Tuning will happen shortly. Beware that you will have to do something about the charge pipes because the stock turbo has a 3" tip on it for where the hot side charge piping connects that the Stage II does not. This means your CP will be about 3" short. I'll upload a pic later to show...
Old 01-14-2011, 10:24 PM
  #582
FF_ace's Avatar
yep,
check terminator2 signature he has a link to my dyno graph. and my car holds over 300whp all the way to redline which is 7k
Old 01-14-2011, 10:29 PM
  #583
So come on is it spooling like normal or what and what else . Need more info now!!!! lol
Old 01-14-2011, 10:37 PM
  #584
You cant put a bigger turbo on and just go WOT'ing around right away :p
Old 01-14-2011, 10:56 PM
  #585
HHRSSouth's Avatar
Sure you can, BOOM!
Old 01-15-2011, 07:53 AM
  #586
turbo_chevy_cobalt's Avatar
Update on my half is that i like this turbo. Spools a little faster then my other 2871 and still holds 26psi till redline. Still tuned for old setup.
Old 01-15-2011, 09:20 AM
  #587
Terminator2's Avatar
My car made 342 whp 378 wrtq on a dynojet and 362 whp 393 wtrq on a dynocom no E-85 no meth and 24 psi. It holds power pretty well until 6500 RPMs. FF-aces car made more than mine but he has E-85/91 octane and a small meth nozzle. RYRIDESMOTOX's car I tuned is close to 350 whp on 91 octane out in Cali (310 whp 370 wtrq on a mustang dyno)
Old 01-15-2011, 09:39 AM
  #588
drewbroo's Avatar
i just need to dyno mine.....
Old 01-15-2011, 09:42 AM
  #589
cobaltltblue's Avatar
Waiting on ##'s
Old 01-15-2011, 10:35 AM
  #590
elecblue06's Avatar
so you have inflated dynos out there thats nothing new :P
the only number that actually sounds normal is the mustang dyno numbers
the fact that the dynocom read 20 whp higher and 17 wtrq higher then the DYNOJET should make you throw it out right away
just busting chops btw i know you're a good tuner but inflated numbers are just that.. for all you know the kappa could be putting down 400 whp on your dynojet or whatever
Old 01-15-2011, 10:44 AM
  #591
All relative. Dynojets read ~13% higher than a properly calibrated mustang dyno but most dynojets read within 1% of each other because there is no operator error like mustang dynos and dynocoms. My car did make only 242 whp stock on that dynocom. Never got a chance to dyno stock on the dynojet but it would have likely made 228-230 whp stock. IMHO the best way to try to compare numbers is for everyone to use dynojet numbers and the same correction factor, using STD, SAE, or Uncorrected does not matter if everyone is using the same one.
Old 01-15-2011, 10:49 AM
  #592
elecblue06's Avatar
this is true.. least then numbers could be looked at relatively / objectively
242 stock makes sense however. like you said operator error could've made your second dyno higher
thats one thing that sucks.. when there is operator error
Old 01-15-2011, 12:41 PM
  #593
bamaboy22's Avatar
Guys seriously let's quit all the back and forth arguing and use this thread for what it's here for BNR.
Old 01-15-2011, 01:32 PM
  #594
Matt M's Avatar
Dynojet numbers can be affected just as easily as Mustang numbers. Calibrations and weather station parameters can be way off. A michigan Grand Prix club dyno'd at Baker Engineering on their Dynojet and several people had numbers 5 to 7% lower than they had recently tested on VT Engines Dynojet. More importantly, though is that stating a peak dyno number really only means that the car put that amount of power to the roller at one instance in time, for a fraction of a second in some cases. I recently saw someone post that they dyno'd xx amount of power, but the clutch was slipping so it should be higher. Well this is not necessarily true. In fact, a slipping clutch often makes the peak HP number higher. Much the same way that spinning your tires can give you a higher mph in your 1/4 mile run, a slipping clutch allows your motor to reach a higher RPM and stay there while the drivetrain catches up. While power numbers early in the graph will be lower, the peak power is often higher. This is due to the stored energy of the motor because it is already spinning at a high RPM. There are many other ways that dyno numbers can be inflated as well without technically being "inaccurate." That type of stuff rarely gets disscussed, however.
Old 01-15-2011, 01:37 PM
  #595
SOHC24powa's Avatar
^word
Old 01-15-2011, 04:15 PM
  #596
tglems's Avatar
Looks like tuning should start in earnest today...it will only be interrupted for the Packer game party we'll be having...but even then only minimally!
Old 01-15-2011, 05:20 PM
  #597
40rty's Avatar
I'm waiting on my computer for your results man.
Old 01-15-2011, 05:28 PM
  #598
beast10007's Avatar
keep us up to date man I would like to know what boost you are running and if it holds
Old 01-15-2011, 05:31 PM
  #599
40rty's Avatar
Sup,
RYRIDEMOTOX's car is who I was talking about making 350 on pump. See I didn't know that you tuned his using pump. That's what I like to see and I know him personally. Just not a fan of the whole E85/91 and Meth, that doesn't even sound cost effective.
Old 01-15-2011, 07:04 PM
  #600
HHRSSouth's Avatar
Any pics yet of how you solved the 3" space from the UICP to the Turbo?
Quick Reply: Bnr k04-gt28
