Bnr k04-gt28
#601
You could probably hack off a section of you original pipes couplers as they are like a foot long to begin with
#602
That's what we did
#610
With the dual tune and a wastegate spring higher then stock, it takes a few adjustments to get the boost under control. This last flash I sent should have it around the 22 mark like we want for now. Once we get the boost under control we'll work on the power portion. Its looking nice so far tho, Ill bet it makes a nice flat HP curve.
#611
Got it pretty close last night within 5 flashes, def looks like it pulls well. Still have some work to do getting the lower RPM boost to come on stronger now and the boost is looking flatter otherwise. Should have it pretty wrapped up on the gas tune today
The last log he def popped a CP off or something tho. The WG% was pinned the whole time he was WOT and its only making a few psi. Before it was holding 22+psi with only 60-70%.
#613
Yea, that was the first couple lol.. It doesn't do that anymore. I just said that
There isnt a table in HPT that allows you to directly input a set PSI amount. Everything is load based so it takes a lil to get that portion smoothed out.
If you decide to try and run the factory boost control on your car with a higher spring then stock, you will see it takes a few tries to get it to not spike. I told him to let out if it spikes and to let me know what it did. He likes to stay in that throttle tho LOL!
#614
What type of BYT tune is he using?
A regular HPT or a Trifecta/HPT tune?
Also is a MAF Relocate necessary for the 2871 or can we get by with just a BOV? I read back some pages and saw people talking about it. but never saw a post yet saying you definetly needed a MAF relocate to run a 2871.
#615
#616
To clear up a little confusion...FF_ace left last night before the last couple flashes. When he left we were still seeing 27psi, but now less.
As for the issue, thank god there was no boost leak, but if you do this install make SURE that you tighten the nuts on the wastegate actuator rod. Initially we had about three threads showing on the wastegate side of the bolt and after spraying soapy water all over my car all morning (looking for a boost leak) I finally got under it and found the problem. The rod had almost completely slipped out and the nut on the end was just barely hanging on (instead of 3 threads more like 20 threads showing). I tightened it all up and it is holding boost again just fine. About to do some more data logging now...and I swear, I'll try to be a little more gentle with the throttle, lol
As for when it gets into boost, etc, I've been concentrating on watching the spikes and rolling into it closer to 4krpm anyways, so I dont' have an answer yet. I'll get there, promise...maybe even take a video for you all ;-)
#618
So, car won't hold me that 15psi. I need to adjust the WG rod. Here are a couple pics of the WG rod and why it is a PITA
This is my view. I have the nuts loosened but it is difficult to get to. My arms are burnt to ****.
Here is a better pic where I held the camera up.
So which way am I supposed to pull that rod? I'm getting (I think) that I am supposed to to pull the rod further out of the wastegate. The only way I can really do this is by tightening the far side nut(invisible in these pictures). I just don't want to start torquing the **** out of it to pull it further and further toward the wastegate and then break it. I've broken too many things by doing that, and my new turbo is not about to be added to the list.
#619
Ok, its slightly different then what I was describing. You want that arm to be pulled back close to the wastegate can part, this makes sure the "door" is closed and the turbo will spool up as its supposed to.
The pics helped
The pics helped
#620
Is he still on 91 octane or an E-85 blend?
#621
Well in some areas E-85 is $2.55 a gallon vs $3.30-3.60 for premuim. Gas milage goes down 8-10% on E-47 but it is much cleaner burning with will help keep the valves cleaner (mainly exhaust). Power gains can be up to 30 whp depending on boost levels and previous gas quality.
#622
Something happened because it went from 22 to nothing and now it wont hold more then 15psi. The WG% is pegged immediately, there is def a leak.
But the car is on 91 right now while we get all the initial stuff smoothed out. Then he will be moving to the E blend for the actual tune on the car. Like Ive said above, it takes a bit of work to get the combo tune boosting the way you like since its set by load and not a PSI amount..
#623
#625
After work today I'll start ripping the car apart in earnest to find this boost leak. So far I really haven't, but the only place I can think it is would be the back of the FMIC where I can't see since I've checked everything else. Wish me luck.
Edit: Please god of turbos, let me be stupid and let it be a leak at a coupler that I somehow missed earlier...
