Bnr k04-gt28
Old 01-20-2011, 11:12 AM
  #676
BYT*SS*TURBO's Avatar
Yea, Ive seen over 35VE on Tyler's car and about 38MAF Lbs. The high Maf is also when the boost is climbing above where we desire so that will come down slightly.
Old 01-20-2011, 11:18 AM
  #677
HHRSSouth's Avatar
Originally Posted by Iam Broke
I've never seen greater than 31.5 VE lb/min on the stock K04 no matter what psi it pushes. One of the other tuners can add their experiences.
Skewing the MAF airflow or correction for ethanol blends will increase the MAF lb/min in error.
I was just basing it off of one of the Kappa guys saying he was making 35 lbs/min over on there forums. Yes he was using ethanol, so that might explain it.
So then the GT2860 is a an upgrade of 3-4 lbs/min, any idea what that would translate into whp? If people are making 340's with one of the hptuner tuners on the K04 (Term is making 360), what are we possibly looking at with the GT2860 with one fo there tunes?
Old 01-20-2011, 11:28 AM
  #678
cubaniche's Avatar
Well will soon know. As far as I know, Im the only one that is interested in the 2860. My tax money should be deposited next week at which time I will be ordering the BNR Stg1. Hopefully hes got one ready to go and ships right away. Then, BYT will be tuning me for it.
If anyone gets all that done on the 2860 before me then speak up! We want results
Old 01-20-2011, 11:34 AM
  #679
HHRSSouth's Avatar
As far as you know
Old 01-20-2011, 11:39 AM
  #680
Tundraboarder666's Avatar
LOL Tyler, you make me laugh. You gotta listen to Steve, he's a car guru.
  #681
cubaniche's Avatar
As far as you know
Awesome man! So you want one too? Or is one on the way already? lol
Everyone seems to be wantng the Stg2 for a lot more power. Im content with the 2860. Im sure BYT or Term can get good reliable power out of it.
Old 01-20-2011, 11:57 AM
  #682
Iam Broke's Avatar
snip...
I've logged over 41 lb/min MAF on E60 (stock turbo) with the fueling offset fudge factor. It's a lie, ask for VE lb/min airflow numbers to compare, takes the fuel trim fudge factor out of it.
Old 01-20-2011, 12:06 PM
  #683
HHRSSouth's Avatar
I only live 1hr from BNR, so I will be driving down and picking mine up and then take my old one back for the core charge at a later date. I will talk with BNR while I'm down there and tell him what exactly I want and which turbo he thinks will suit my needs.
If your having your turbo remote tuned by BYT or Term, you will still have yours tuned before me. I'm gonna have Vince tune the turbo initially (so I can drive around locally), then I will be taking a trip to PA to visit family and stop in to see BYT for 1 day to tune further. I'm gonna have BYT slap on a Trifecta/HPT tune on for 93 Octane, probably some time in February.
I won't make it to the dyno I used for my Dual Trifecta tune till March at least to compare.
Old 01-20-2011, 12:08 PM
  #684
Im hosting another Dyno Meet end of Feb or beginning of March. Check out the thread in the BYT section and see if you will be around at that time
Old 01-20-2011, 12:17 PM
  #685
cubaniche's Avatar
Sounds good man. Let us know which one you choose.
Im gonna have to wait for a dyno day in my area to go dyno. Or, I may drop the 80 bucks it costs to dyno at my preferred shop if no dyno day comes up.
Old 01-20-2011, 01:11 PM
  #686
Matt M's Avatar
It's important to note that the VE airflow calculation is based on a stock motor's VE map. Some mods that increase airflow will throw this calculation off, such as exhaust mods. Even a better IC will increase airflow more than the VE airflow calculation will predict.
Old 01-20-2011, 01:17 PM
  #687
Iam Broke's Avatar
Duly noted, thanks Matt. I thought VE airflow was calculated via the pressure drop across the throttle body.
Old 01-20-2011, 01:40 PM
  #688
Matt M's Avatar
Originally Posted by drewbroo
Mike was seeing 35lb/min VE on his 2871 and making 422WHP, so I imagine thats pretty good at 38-39
422 whp at 35 lbs/min? Does this car run on nitromethane? Or did you mean 322whp?
Old 01-20-2011, 01:41 PM
  #689
Matt M's Avatar
It could be, but it would still be affected by exhaust mods.
Old 01-20-2011, 01:47 PM
  #690
FF_ace's Avatar
thats no typo he ment 422 he had the synapse turbo kit and he running 91 with methanol injection @ 26-27psi i believe
Old 01-20-2011, 03:55 PM
  #691
pbass's Avatar
Yeah, I wanna hear about the 2860 too.
Old 01-20-2011, 07:16 PM
  #692
Matt M's Avatar
Ok, then the HP was right, but the MAF reading was much lower than actual. It was probably set up that way to tune for the meth. I don't know what turbo he is running on that kit, but 26-27 psi on an S252 turbo is around 44 lbs/min.
Old 01-20-2011, 11:16 PM
  #693
drewbroo's Avatar
Its a stage III (GT2871R)
I am speaking of the VE Airflow, not at the MAF.
If my VE Airflow is reading 30lb/min, my MAF is at 38.71 lb/min
His VE was at 35-37, so I imagine at the MAF it was much higher.
this is my log as an example
Old 01-20-2011, 11:24 PM
  #694
Matt M's Avatar
Got it. Makes more sense then.
Old 01-21-2011, 09:28 AM
  #695
Terminator2's Avatar
Originally Posted by BYT*SS*TURBO
If it senses an underboost condition it will still increase to the 95% anyway. Just had this talk with Vince yesterday about why I asked for 75% MAX WGDC and still saw 95% at times..On the Subaru's and some other cars you can literally set the MAX point and it will never go over it, I thought this would work the same but Vince tells me otherwise.
I guess it has to do with the torque based controls. Desired boost (desired torque)>Set WG DC max.
Old 01-21-2011, 09:39 AM
  #696
We got it pretty squared away boost wise now. So time to start working on making some power with it
Old 01-21-2011, 10:07 AM
  #697
FF_ace's Avatar
Well he will have my hp tuners all weekend since I'm going out of town should have it done by then
Old 01-21-2011, 10:15 AM
  #698
Thanks for loaning it, def makes life easy!! We usually get a few done quickly a night now!
Old 01-21-2011, 11:07 AM
  #699
FF_ace's Avatar
ya no problem i really cant do much data logging on my car until i get the timing chain fixed and i will do that when i install my ported head which should be done here soon. i have to get my boost under control as well im seeing it spike to 30
Old 01-21-2011, 11:41 AM
  #700
With a combo tune right? Def takes some logging back and forth as you saw. I think yours is Terms first combo? I could be wrong there but its a bit different then HP alone. He knows very well how the DAL and MAL tables work so he'll get it!
Quick Reply: Bnr k04-gt28
