Bnr k04-gt28
Old 01-29-2011, 09:48 AM
  #826
Terminator2's Avatar
Originally Posted by BYT*SS*TURBO
I was at a meet where a TF car with the rich Lambda and 14* peak timing actually put down more whp. So it's all relative
That car is what we call a ringer. I bet if you leaned it out a little and added another couple degrees of timing to that particular car it would have made even more power.
Old 01-29-2011, 09:58 AM
  #827
BYT*SS*TURBO's Avatar
Prolly true!
Old 01-29-2011, 04:21 PM
  #828
elecblue06's Avatar
i think i know the car he's talking about .. and that was tried and actually made less power.. if we're thinking of the same car.. the car has ALOT of data logging done with it with scanxl's real time logger.
Old 01-29-2011, 05:19 PM
  #829
hunter19707's Avatar
If I go with the 2860, would it be beneficial to buy the Forge BPV with the green spring to replace the stock BPV? Or should the stock be fine.
Old 01-29-2011, 10:08 PM
  #830
Yea kyle, John's car.
Old 01-29-2011, 10:38 PM
  #831
elecblue06's Avatar
yea i can safely say his car is making as much as it can in its current form.. john is meticulous about trying things out .. i'm 99% sure he tried running a leaner mixture and more timing and it made less power basically anytime the temp changes like 10-15 degrees he does a new log just to check everything out
i'm sure it's possible to pull a few more out .. but john is very thorough
  #832
Ion
Ion's Avatar
I didn't realize he makes the RX kits. Had I known that, I'd have bought my turbo off him for the 6. I ended up with a Precision SC6262. 450bhp, here I come.
Old 01-30-2011, 09:59 AM
  #833
Yea, I remember him saying he and Vince tried .88 and then 17-18* and the car made less. Im not sure what Vince does different but I have to agree with Term just because MY personal experience on the dyno even with my own car showed me the samething. But I do understand how much John went thru with his tune so I know its the best it could possibly be as well.
Old 01-30-2011, 11:06 AM
  #834
elecblue06's Avatar
yea just goes to show every car is different weird **** happens lol
Old 01-30-2011, 11:16 AM
  #835
pbass's Avatar
I'm planning on a 2860. From all the discussion, it looks like the Forge can get sticky at ambient temps below 40°F (we get that a lot in my area). I don't know when someone will come up with a solution, maybe some kind of slippery coating or something, but 'til they come up with it, I think I'll be better off keeping it stock.
Old 01-30-2011, 02:03 PM
  #836
turbo_chevy_cobalt's Avatar
Originally Posted by elecblue06
where the fak are the videos bishes lol
i will get a video from 60-100 or higher for u tonight when i log. or a dig.
Old 01-30-2011, 06:54 PM
  #837
Wangspeed's Avatar
Something is wrong then. Mine has never stuck. I've mentioned it countless times now, green spring, lube lightly with Mobil 1 axle grease. Not a single surge event.
Old 01-30-2011, 10:00 PM
  #838
pbass's Avatar
Just reading the forums and being cautious.
Old 01-30-2011, 10:03 PM
  #839
My buddy with the MS3 said his Forge BPV did that and you had to oil it occasionally. I did with mine as a precaution, havent had an issue tho!
Old 01-30-2011, 10:25 PM
  #840
Full spool by about 3500 RPM. I saw a 3300 in one pull but never again.
saw a peak of 46 Maf Lbs and over 35 VE
Old 01-30-2011, 10:33 PM
  #841
PrincessTurbo's Avatar
speak in dumb **** terms .
what do you think its making or capable of making ?
Are you running hpt on windows 7 or vista ?
Old 01-30-2011, 10:36 PM
  #842
win7 lol.
Who knows on the power. The E Blending skews the readings a bit and the dyno never does what you expect it to do lol. Best thing is to just go run it! Preferably somewhere he has run the car before.
Old 01-30-2011, 11:56 PM
  #843
elecblue06's Avatar
wewt lol good .. sorry i'm a dick lol just excited to see what this thang is doing
Old 01-31-2011, 06:35 AM
  #844
pbass's Avatar
Kewl. Maybe I'll get one after I get everything I need.
Old 01-31-2011, 09:22 AM
  #845
The most detailed dyno tune I ever did started with stock timing, 21 psi and 0.84 PE Lambda, Car made 272 whp 334 wtrq. I then kept eveything the same except 0.86 lambda it went to 282 whp 338 wrtq, I then went to 0.88 lambda it went to 292 whp 342 wrtq. I then went to 0.89 lambda and it made 298 whp 345 wrtq. Then I tried 0.90 lambda it made the same power so I kept it at 0.89 lambda. I then added timing 1* at a time. It stopped making more power at 15-16* up top. Car ended up at 314 whp 360 wrtq.
Old 01-31-2011, 09:25 AM
  #846
I honestly found the samething with my own car at the first dyno session ever. I changed nothing but PE for the first couple pulls and gained at least 10whp a .1 of Lambda. I usually see peak power on most cars with 17-18* up top, over that without Meth or E hasn't showed a gain FOR ME. Just my observation.
This next time I go tho I will be trying the latest tune with .86 in the heavy spike/torque area and then trailing to .88 up top.
Old 01-31-2011, 07:03 PM
  #847
cubaniche's Avatar
Awww man. Thats cool. I hope he has one ready for me when I order. Did you pick yours up then?
Old 01-31-2011, 07:06 PM
  #848
Originally Posted by HHRSSouth
Quick FYI,
I talked with Brian at BNR, (5) K04-2860's have been sold already. So apparently people have them out there and either haven't put them on or are staying hush hush about it.
They need to speak up and let us know how it's going. I'm close to pullin' the trigger on this as well.
Old 02-01-2011, 08:20 AM
  #849
will upload later tonight.
Old 02-01-2011, 08:38 AM
  #850
pbass's Avatar
Quick FYI,
He means the first batch of 5 is spoken for. I put my order in early. Right now there's a delay at the machine shop, but I always have plenty of time to wait for the Right Stuff.
Quick Reply: Bnr k04-gt28
