Bnr k04-gt28
Old 02-01-2011, 06:07 PM
  #876
JBThrasher22's Avatar
Ahem videos now please lol
Old 02-01-2011, 06:17 PM
  #877
Resident Post Whore/Troll
07SSYellow's Avatar
im hoping that when i do mine i wont have as many problems lol my car only has 5k miles on it
Old 02-01-2011, 07:21 PM
  #878
07SSYellow's Avatar
Damn lol mine has never seen snow.or salt either...we shall see I guess
Old 02-01-2011, 08:41 PM
  #879
FF_ace's Avatar
Originally Posted by BYT*SS*TURBO
I think we're done with the tuning, looks really solid! 46.7 MAF peak and 36.1 VE. Those were the highest Ive seen. 4.49 60-100 was the best yet also. Im curious to see what this will put down on a dyno now!
awesome stuff now i can have my comp/hp tuners back lol jk im glad everything got worked out
Old 02-02-2011, 12:54 AM
  #880
FF_ace's Avatar
ok so i met up with tyler tonight to video tape some runs for you guys and damn this thing pulls hard tyler just needs to keep this thing straight lol torque steer like no other. we did a couple pulls heres a link to the 0-130 we did
2011-02-01_21-38-25_307.mp4 video by ff_ace - Photobucket
the other video is taking sometime to upload so i will get that up later. but this thing pulls hard all the way to redline. he even let me drive it a couple times and i had the opportunity to run a STI and from what i saw he had at least a tune and exhaust. we took off from a dig boost was instant in 2nd from what i felt then i missed 3rd yes i know i fail at driving he was giving me **** about it the rest of the night. but its a great setup up and byt did a good job getting him dialed in. now its time to hit the dyno
Old 02-02-2011, 01:35 AM
  #881
turbo_chevy_cobalt's Avatar
YouTube - BNR turbo
Here is a video but it not to good from 60-100 still tuning a little for the 26psi.
Old 02-02-2011, 02:49 AM
  #882
hunter19707's Avatar
Can a k04 that needs rebuilt be used as a core exchange?
Old 02-02-2011, 10:20 AM
  #883
cubaniche's Avatar
Yes. As long as the housing and all its exterior parts are good. The internals all get tossed out anyways
Old 02-02-2011, 10:33 AM
  #884
Thanks!
Old 02-02-2011, 11:02 AM
  #885
tglems's Avatar
Originally Posted by HHRSSouth
So I took the turbo out this morning.
I found it easier to leave the oil drain tube in the block and unhooking it from the turbo and pulling the top turbo line off and bending it out of the way.
Then I pulled the turbo out through the top.
Though I'm pretty sure the 2871R housing is goign to be to big to back in the same route , lol.
Question though, what is everyone doing with the plug/sensor that is on the factory turbo?
Are you guys leaving it unhooked or re-routing the vacuum lines some how on the aftermarket turbo and re-using the plug/sensor?
Everything else I now how to route or hook up for the aftermarket turbo, but I don't remember reading anywhere or seeing a diagram showing what to do with the sensor/plug in the turbo itself.
I think we used it but I'll have to double check where and how. 1LowLS or FF_ace might remember off the top of their heads. Also, you'll have to bend the oil/coolant lines when you want to put the new turbo on. They fit with a little bit of manly touch (pure force) :-)
That was too much fun last night! It's like I own a new car all over again with how different it is now!
Old 02-02-2011, 11:52 AM
  #886
tglems's Avatar
I sure would appreciate a diagram or photo or something of how you guys routed that plug and sensor up.
Sure, here is a pic of the old and new turbo so you can see how we connected the vacuum lines across. However, make sure that you rotate the WG can 180degrees (which wasn't done in this pic). As for the plug/sensor, I'll have to wait until after work so that I can try to snap a pic of that.
Old 02-02-2011, 12:01 PM
  #887
BYT*SS*TURBO's Avatar
Glad you are happy with it man! We can work on the 1st and 2nd gear laying the power down better if you like over the weekend or anytime really. Tune def looks really strong now, dyno time
Old 02-02-2011, 12:45 PM
  #888
FF_ace's Avatar
Do not cap the open one
Old 02-02-2011, 12:51 PM
  #889
Turbo'dSS's Avatar
i sure would appreciate some dyno numbers. lol!!!
  #890
tglems's Avatar
Top port. Do not cap the side port or you won't be able to make boost which is never any fun
Old 02-02-2011, 12:52 PM
  #891
SKY888's Avatar
BTW, I forgot to mention that Brian (BNR) told me on the phone today that a Kappa Solstice put down 371whp with the 2871. I forgot to ask how much boost he was running or any of the other questions i should have asked as I was in a hurry.
Brian seems to think we should hit 400whp on our application.
here's the dyno of the kappa that made 371whp which was tuned by DDM
power went up fast.....but falls down quickly as well.......
That is on 93 octane, no meth/water, intercooler, high flow cat, exhaust and an intake
Old 02-02-2011, 12:54 PM
  #892
tglems's Avatar
Ugh, that is an ugly graph
Old 02-02-2011, 12:55 PM
  #893
Chevycobaltss3's Avatar
i have a k04 for sale if anyone needs one it has 2000 miles on it. No issues, no play.
Old 02-02-2011, 12:56 PM
  #894
FF_ace's Avatar
Your running e85 so yours will be better
Old 02-02-2011, 01:00 PM
  #895
tglems's Avatar
I have a good tuner so mine will be better j/k j/k I'm sure DDM does wonderful tuning
Old 02-02-2011, 01:23 PM
  #896
Stamina's Avatar
That dyno graph looks like they were tuning with peak numbers only in mind, and not "area under the curve". I'm willing to bet that can be improved a whole lot.
Either that, or we've got exhaust housing restriction issues we're bumping into on the GT2871. I wouldn't think that would be the case though, with the larger wheel and enlarged housing.
One thing that is nice is that you can definately see the RPM window where it spools up. I imagine that could shift based on timing and cam settings though too.
Old 02-02-2011, 01:27 PM
  #897
Or they are way overspinning or lacking fuel up top. It dies hard at 6k where the stock fuel pressure tables taper off.
200whp and 150wtq at redline... Thats far worse then a stock turbo car.
Old 02-02-2011, 01:33 PM
  #898
Stamina's Avatar
Mmmm.... good point.
Old 02-02-2011, 01:35 PM
  #899
SKY888's Avatar
At what psi was he running on the Kappa, maybe I missed it but I don't see bar/psi listed.
Stock intercooler? Aftermarket IC pipes? Hi flow cat or straight DP? What size exhaust?
Going to go out and get my LNF Mitsubishi K04 (I got last fall) and put it next to my LNF BW K04 and post up pics (in a new thread) some time later to give an idea what the differences are.
The car is still exiting through a 2.5" downpipe, looking forward to the next install with a 3" downpipe. Still has over 50whp improvement at 5K and 35whp improvement at 7K over the stock turbo through the 2.5" downpipe, definitely a better upgrade than the big wheel option. Boost pressure did not go down during the run and was a constant 26-27 during the run.
the only thing we changed between those runs is the turbo and added a BOV since the 2871 does not have an integrated bypass like the factory turbo.
That run was at 26-27psi
Old 02-02-2011, 01:41 PM
  #900
SKY888's Avatar
this is the stock turbo's graph an hour before they put the BNR turbo
Quick Reply: Bnr k04-gt28
