Bnr k04-gt28
#951
I will point this out though, the 2860 rated at 35 lbs/min) flows more air then the stock K04(32 lbs/min). With good tunes people are making 340 whp on the Delta platform, a few have even managed 350-360 whp with a stock K04 with bolt ons.
So in theory the 2860 should make more whp then the stock K04 and keep making power higher up in the rpm band where the K04 drops off.
We aren't talking huge whp gains, but there should be some there none the less and you should be able to maintain it higher in the rpm band.
but when you mentioned about a kappa making 370whp using 2871 BNR turbo, I then provided the dyno graph tuned by DDM.
and I provided statements by DDM talking about 2860 (320whp) and 2871 (370whp) on a kappa platform.
yeah, 2860 making 320whp on a kappa platform is very realistic.
Which I was talking about
Yeah, 2860 on a cobalt platform, will probably be around 340-360whp depending on the tune/dyno....and probably 2871 on a cobalt platform will probably be around 370-400whp, depending on the tune/dyno
#954
So does anyone know how this might compare to the "LNF Big Wheel Turbo" for the GXP and if it would work on the Cobalts? Looks like we may have some great options for turbo upgrades, can't wait for the dyno on the stage 1 and 2.
The Home of WERKSracing products!
#958
BNR turbo upgrade is a total replacement of both turbo and compressor wheels with either gt2860 or gt2871 garrett turbos.
#959
The ones that have replaced them was either out of necessity or because they were building their engine or just for plain old peace of mind, like me lol
Its certainly safer to push the engine further with forged internals
#960
On the contrary. This turbo will get us the power we want while still being efficient and not out of its efficiency range like pushing the K04 to the max. That combined with a good tune and you should be fine. Dont severely mess up an NLS while on the tune pushing that much power and you should be fine....if you even NLS at all.
#961
Also, I haven't NLS since I received my TF tune.
#968
yeah i want to do it sooo bad but id like a bigger intercooler, new clutch, new tires, 2nd interceptor, and get my rims powdercoated first. And im trying to figure out what im going to do about the core charge. lol!
#973
I'm running stock retainers with my ZZP valvesprings. You don't actually need to change the retainers to run ZZP springs unless you are running quite a bit more lift than the stok cams provide.
#974
Its just a suggestion to people. Alot of members have voiced their interest in your new cams anyways. If your going to open her up to work on the springs you may as well replace the retainers too. Some of us rather not go back in to replace something that may fail later on
#975
Thats great! Speaks well for your spring kit
