Bnr k04-gt28
Old 03-26-2011, 04:12 PM
  #1226
turbo_chevy_cobalt's Avatar
Originally Posted by elecblue06
i'm pretty sure id did already
when i get my car fixed i will dyno it on 91 at 28 psi and then 50/50 at 28 psi. not sure about 100% e85 yet. but i might have to do a 60/40 meth/water or 70/30 if needed to help with more fuel.
Old 03-26-2011, 09:03 PM
  #1227
beast10007's Avatar
that would be nice of u to share with everyone.
Old 03-27-2011, 10:04 AM
  #1228
Supercharged Guy's Avatar
I see no numbers yet...
I wanna make my decision on getting this turbo but I need numbers first..
Old 03-27-2011, 10:21 AM
  #1229
Chevycobaltss3's Avatar
I know u want numbers bro but put it like this. On a meth tune and 26lbs i can see 450 coming easily.......... The turbo produces a good amout of air and spool time is decent. To get to the power goal it just means tuning to a extent. Advancing timing. Going a litttle leaner with the meth ect.
Old 03-27-2011, 05:48 PM
  #1230
well got the car fixed damn injector o-ring seal. so i will see about dynoing when i get paid.
Old 03-27-2011, 06:05 PM
  #1231
drewbroo's Avatar
Mike let me know when you dyno. I want to see what the sedan is putting down now on full E.
Old 03-27-2011, 09:39 PM
  #1232
BYT*SS*TURBO's Avatar
I saw 47maf lbs on the stock turbo yesterday on my own car.. You think it had 470whp I know the answer and its not even close lol..
Lets see the graph.
Old 03-27-2011, 10:04 PM
  #1233
FF_ace's Avatar
Lets see the graph.
What did you put down on full e?
Old 03-27-2011, 11:17 PM
  #1234
09BlueBaltSS's Avatar
Lets see the graph.
But aren't you skewed about 30% for full E? That would take u right back down to 36lbs/min
Old 03-28-2011, 10:19 AM
  #1235
i will let u know. maybe one day i can do 100% e.
Old 03-29-2011, 01:46 PM
  #1236
Bump for #'s
Old 04-02-2011, 01:33 PM
  #1237
JacBlackSS/TC's Avatar
hopefully everything works out for me i will have a 2871r next week just waiting for atp to get back to the shop with some info
Old 04-03-2011, 10:06 PM
  #1238
Welll that's good.
I'm just hoping that somebody post some numbers, any really lol
I wanna make my decision but can't untill numbers
Old 04-05-2011, 12:48 PM
  #1239
Bump..
I know somebody has the bnr2871 and has numbers...
Please please
Old 04-05-2011, 01:18 PM
  #1240
drewbroo's Avatar
yeah why is everyone so secretive about the BNR numbers? Are they not that good?
Old 04-05-2011, 01:30 PM
  #1241
Well, I am going tonight to tune a 2860 car on the dyno. It's the dyno I always goto as well so I can overlay my old gas tune 22psi graph on the stock turbo vs the 2860 car.
He called me saying something about the coolant lines is different? I haven't installed one of these and the shop I use did the install. Anyone know anything about this?
Old 04-05-2011, 01:36 PM
  #1242
cubaniche's Avatar
I dont think anyone is being secretive lol The only one that straight out said hes not posting was HHRSouth. Why the others havent posted, I have no clue.
Ive been having an isolated issue on my side of things that has kept me from getting the car fully tuned and running right hence no dyno numbers. Ive done countless boost leak tests, Ive replace my o2 and fiddled with the MAF. The prob is low level knock at part throttle. WOT performance is outstanding though. Right when we get it tuned and running with zero KR in the low RPM where its occuring it randomly shows up and comes back later on.
Nick(BYT) has been awesome during this whole time and hes kept at it and at it and at it, poor guy lol
Im almost convinced I have a defective 2860
Old 04-05-2011, 01:39 PM
  #1243
Im still wondering if its a leak between the turbo and manifold or the compressor cover. Only things left. You're welcome to try my spare MAF out for the hell of it!
Sending back an update now btw too
Old 04-05-2011, 01:47 PM
  #1244
cubaniche's Avatar
Yeah the coolant lines have to be modded a bit to make it fit. No biggie. I just had to bend them slightly to make them fit the new orientation on the GT28 center
housing.
Let me know how it goes!
Old 04-05-2011, 01:54 PM
  #1245
cubaniche's Avatar
Yeah, Stamina has a spare MAF that Im going to try out I guess. Although when a MAF goes bad, it just stops working no? Wouldnt a leak in those areas you mentioned have shown up in during my plethora of boost leak tests? lol Im wondering if maybe somehow my breather lines got messed up during the install. Would that cause the symptoms we are seeing too?
Old 04-05-2011, 02:03 PM
  #1246
No. You are testing the charge piping, not the manifold or compressor cover seal.
Edit: They txt'd me back, they figured it out already. Thanks for the info tho!
Old 04-05-2011, 02:17 PM
  #1247
cubaniche's Avatar
Yeah, the K04 has the coolant lines both on one side whereas the gt28 center housing is like most other turbos with the coolant connections on opposite ends.
Ive been doing the boost leak tests from the turbo inlet. I thought that pressurized the turbo too....???
Old 04-05-2011, 02:19 PM
  #1248
Just the compressor cover, so that's good. That doesn't handle the turbo to manifold seal tho. Does it have a exhaust leak sound at all?
Old 04-05-2011, 02:23 PM
  #1249
tglems's Avatar
If nobody posts their numbers by June then I'll get some and post. I'm finishing my Ph.D. and am supposed to defend in May so I am literally working all day every day. I haven't had a chance to even think about a dyno. I should have done it when I had a little more time when I first got the kit.
Old 04-05-2011, 02:31 PM
  #1250
cubaniche's Avatar
If it does I cant hear it lol I figure Id hear some kind of pulsating but it just sounds normal to me. It could be that the seal in the turbo to mani(that metal ring that kinda looks like the one on the DP right?) could be bad...??? they are cheap, maybe I go by new ones for both turbo and DP and see what happens. I dread having o take the turbo out again lol
Ph.D? Yeah, that'll keep you busy! lol Good luck sir!
Quick Reply: Bnr k04-gt28
