Bnr k04-gt28
#1278
What kind of gains were you expecting from the upgrade? So the only real upgrades over K04 would be a better powerband & higher efficient peak boost range? Thanks for testing and posting results though, very much appreciated. I was going to go this route, but I'm going to hold off now. This isn't a "flame" <--- whatever that is, just curious. Thanks
No worries No one with a 2871 has posted anything so I do not know thier results. Member BPASS started a thread about him putting down the same numbers as well so thats two 2860 that didnt make what expected. We were hoping for 340-370. It just holds the power and doesnt fall on its face like the K04.
#1279
What I cant explain is that usually, on the LNF, whatever your flowing at the MAF represents closely the WHP you should be making. When I was on the K04 flowing 31 at the MAF I made 291whp. Im now flowing 37 so, theoretically it should be closer to 350whp....oh well. GO figure.
If I can get my flo back then I will put that in a fund towards the EFR from ZZP.
On a side note, my supertech 78lb valve spring kit is on its way lol
#1280
Yeah, I may see about trying to get my money back LOL It just doesnt live up to the advertised potential plus Ive had a nightmare of a time tuning it...better said, Nick has had a nightmare of a time tuning it
I mean if that's what you dynoed ^ I would probably purchase one and run with it but it looks like it's a tad lower then expected
#1281
A 2860 was never supposed to get anywhere near these numbers I'm not sure where you got this from? All a 2860 was supposed to do was basically max out at around 350ish but effectively hold it and have a nicer powerband than the stock k04. It is basically a more efficient k04+ than anything else.
Now a 2871 was supposedly around the 380 - 400 range. Maybe that is what you are thinking about?
#1282
not to say that you're lieing by any means just it's weird that you didn't gain really anything.. esp since you should gain 15 whp like you did just from switching to e85..
#1283
somethings not adding up man .. if you're flowing 6 lbs more .. that should be a healthy gain in WHP
Shoot I can post a print screen of the log on the dyno too
#1284
Well guys. This upgrade seems to not be worth it
I just dynod on a DYNOCOM. Running the E blend and about 19* of WOT timing at 22psi I only made 305whp LOL
Im given to understand that the DYNOCOM is sorta like the mustang dyno and reads low. Even if that was true and you add the 15% or so its still only about 345whp which is not worth the $1000 pricetag of the 2860. Ive heard of similar experiences with this turbo and even the 2871 not making what it should. The TQ and power is held throughout the powerband unlike the k04 wich seems to peak and fall off. Still, dont know if that is worth the price. Needless to say, I am very dissapointed and bummed out. The car feels great on the street. It def doesnt feel like a 300whp car but thats what the dyno is saying. Oh well.
Comments, flames and suggestions welcomed LOL
Another buddy of mine with a tuned SS/TC at 22psi, 93, and only running bout 14* WOT timing made max 310whp by comparison. We dynod one right after the other. Same conditions, same dyno same temps.
#1286
Term- I know how much you made lol Didnt yours just peak at that HP and then fall off? This one at least keeps the power available to redline.
I dont think there is any MAF skew since we are using the new fueling window changes to run the blend without skewing the MAF.
#1287
You Live and you Learn
You got some gains out of the upgrade! Run somebody with a K04 with about the same hp/tq and I bet you'll like it more! I'm stock for now, i'm in FL if you want a morale booster, hit me up haha!
#1288
#1289
I really don't get why you all keep calling this a 2860 when its a hybrid.... a real GT2860RS (disco potato) is good for a solid 350WHP. I made 334WHP360ftlbs on my built 1.8L Miata with the GT2860RS @ 25PSI and 9:1 CR. (Also had RC650 CC Injectors, and the kit was built by bell engineering)
#1294
Ive done that. I pulled on my friends TF tuned 22psi by about 2 cars, but the gain was in the top end. I hang with my friends FZ6 no prob, and Im behind my other friends zx6r by about four cars lol Not bad if Im hanging with bikes. Still doesnt explain why the car feels different on the road yet only put down 305whp. Maybe its the sustained torque Im feeling...??
#1295
#1296
just run lower boost and put some higher comp pistons in there and call it a day. And also its machined to be like a 2860, but it is not a Garret GT2860RS dual ball bearing oil and water cooled turbo. (Which you can buy brand new for 1200.00, no core involved.)
#1300
If you look at the compressor maps, this turbo does not like that. Its honestly a downgrade, sorry to say but it is. Ive tuned a couple of these and both have dyno'd with HUGE disappointments. I was hoping to see a 340-350whp pull on PBass' car but wow was that session upsetting. 17pulls and 0 change from 6-7k. Choking massively! To put it in perspective, car made the same whp at 16psi and then 22 because of the choking up top.
