Bnr k04-gt28
#1826
Something helped the idle and smoothing out of the engine, all I did was what I said previously. I can only attribute it to the change in the intake I made, since I have no MAF in the intake tube, all other connections and tune are the same.
The 3" bend in the CAI intake before it goes to the turbo is a HUGE upgrade for a HHR SS all by itself. Not to mention making the 3" circumference the same from the fender well hole to the pipe itself.
#1827
I went from the stock HHR SS BOX CAI set up to a true 3" CAI (behind headlight) to a true 3" fender well CAI and my result were opposite.
The true 3" CAI had better idle quality, a smoother engine and more responsive.
I wonder if its because I basically cut it into a SRI then ran 3" tubing for the CAI portion?
A cold air SRI maybe, who knows, it feels great and runs great so I'm keeping it.
Let us know how that SRI works out for you I'm sure there are a multitude of people awaiting results (if BYT doesn;t beat you to it)
#1828
Weird if you ask me
#1829
The BYT Sri is going on the 4 Door, I am trying to squeeze as much power out of it while keeping it as stock looking as possible. The K&N SRI had the same effect on my car as it did on your car. I had to use the stock ab elbow for a little bit because the CIA elbow kept collapsing. Thin Silicone FTL. The ZZP AB mod is on the 4 door right now.
That bend alone is a huge upgrade over the stock piece on a HHR SS as our stock piece has a pancake in that area.
#1830
blink blink.. so would you say your head/ cams should be be able to provide a 25 whp gain or not? this is all i'm asking.. i'm not saying anything about advertised gains of the turbo.. just your head.. yes or no.. just answer it bluntly you guys have never answered what your head/cams will do on a car will full bolt ons have you ? thats all i'm saying .. if it makes X whp on a stock turbo car.. with a bigger turbo.. it should make at least X whp thats it .. you're not really making a point here.. that i'm seeing at least.. I know you guys know your **** but all the 75 whp guestimation was for the fact it's put down 50-60 more down then the stock k04 currently.. and they think theres room left for more..
#1833
Matt.... and all the haters look. 393WHP - 75WHP = 318WHP
PBASS's car: Stock KO4 Injen CAI, Injen hotside, Dejon coldside, Treadstone TR8 IC, Catless DP, GMS1, tune 311.4WHP on 93OCT
393WHP-311WHP=82WHP gain over a car with basically the same supporting mods. I don't know what else you need other than me taking the turbo off the car and re-dynoing it with the stock turbo on the same dyno.
#1834
well its not a ZZP Car so its always going to be sub par. I wonder why we have not seen ANYONE put down the numbers that ZZP claims for their stock K04 cars. (on a mustang dyno) Magic seems to just happen in their shop. Also NO ONE (other than ZZP of course) has been able to run 370+WHP of E70/E85. (mustang dyno) (without spray) Also its weird how your fuel systems don't max out where everyone elses do.
On the S252, I dyno'd 472, then drove straight to a Bullseye open house/dyno day and put down 509!
Do you still insist that our dyno gives out falsely high numbers?
#1835
also take a read here "E85 has an octane rating higher than that of regular gasoline's typical rating of 87, or premium gasoline's 91-93. This allows it to be used in higher-compression engines, which tend to produce more power per unit of displacement than their gasoline counterparts. The Renewable Fuels Foundation states in its Changes in Gasoline IV manual, "There is no requirement to post octane on an E85 dispenser. If a retailer chooses to post octane, they should be aware that the often cited 105 octane is incorrect. This number was derived by using ethanols blending octane value in gasoline. This is not the proper way to calculate the octane of E85. Ethanols true octane value should be used to calculate E85s octane value. This results in an octane range of 94-96 (R+M)/2. These calculations have been confirmed by actual-octane engine tests"
#1840
This bickering or who makes what, and how I use this blend or I trap this all goes where??? To making more sales?? To being top dog?? WHO CARES!!!!!! Tuners just do your thing and don't worry as to who doubts what you're doing.
REALLY ZZP, REALLY BYT, REALLY TERM2?? I take no sides, lets just let the thread continue about the BNR-2871r. There are other threads like ZZP's EFR turbo dicussion where "ZPP" you have reign. Whatever started or who compared what, GET BACK ON TRACK with furthering development in a "PROFESSIONAL" way.
#1842
I know why they are down talking the product. These 2 vendors that are heavily envolved with this thread both have K04 turbocharger products. One a reworked K04 and the other in the design stage. If they both give in and give positive remarks, that means their turbo market will drop. Ofcourse they don't want that.
I don't get envolved when discussing other business's products. Everyone has to make money to pay bills and feed their families and I respect that.
That is truly not the case. I sell very little parts and I really don't go out and promote them or push them. If the 2860 would've made a 20-30whp gain there would be no issue. The fact that it made the same power with slightly added lag just didn't make it worth buying in my eyes. Other customers then went and dyno'd to find the same results. They were also unhappy. Whether Im a vendor making millions or just some random guy, if the part doesn't perform then it is what it is. Ive already said I think the 2871 is a good upgrade and that should be considered the stg1 upgrade. I just don't like the dip and after seeing it on a couple cars, I feel there is still some other issue.
I don't have anybody coming in your thread posting negative anything. Ive spent a lot of my time tuning these setups and trying to go above and beyond to make them work for the customers. Sorry it didn't work out but sometimes that happens with new things. You offered a good solution to a few people with trades for the 2871 and I agree that's a great offer and they will be much happier with the new setup.
I am offering a turbo solution myself but it's not a bolt-on or cheap solution. So I have no need to slam your product to promote my own, they aren't in the same category of upgrades.
#1843
#1844
Yeah I am serious. Go look up what the OCT equivalency of full E85 is. 94-96OCT. So 6 gallons of 96oct+6gallons of 91 Oct = 93.5oct. I am only running 18 degrees of timing up top. So you can't say that I am running ridiculous timing from the knock protection of E85. I think its a pretty fair comparo considering the fueling issues I am having with E47. If I had 93 Oct here I am pretty sure I would be close to the same number. At-least I am being honest with what I am working with.
also take a read here "E85 has an octane rating higher than that of regular gasoline's typical rating of 87, or premium gasoline's 91-93. This allows it to be used in higher-compression engines, which tend to produce more power per unit of displacement than their gasoline counterparts. The Renewable Fuels Foundation states in its Changes in Gasoline IV manual, "There is no requirement to post octane on an E85 dispenser. If a retailer chooses to post octane, they should be aware that the often cited 105 octane is incorrect. This number was derived by using ethanol’s blending octane value in gasoline. This is not the proper way to calculate the octane of E85. Ethanol’s true octane value should be used to calculate E85’s octane value. This results in an octane range of 94-96 (R+M)/2. These calculations have been confirmed by actual-octane engine tests"
On another note- I have never bashed the 2871 or said that you won't be able to make more power if you add boost, add timing, etc... I only said, "We need more data before I would accept the 75whp gain claim." After going in circles for a while, you point out that you could change a couple things and make more power. Well, gues what? If completed successfully, that would be more data! What we have now is more predictions, which is fine for discussion, but should never be stated as fact until actually achieved. Do you see what I'm saying?
#1845
Well I found the absolute fueling limit on E-47 and the BNR 2871. This is Drew's car at 28 psi in 3rd gear. The HPFP cannot give enough fuel even ramping up the pressure slowly in the midrange does not help. Running flat fuel pressure like stock makes the issue even worse than it already is and advancing the injection timing has no effect what so ever. The HPFP just cannot give enough fuel to support this much power on E-47.
[IMG] Uploaded with ImageShack.us[/IMG]
Not sure on the power level on this pull but I would guess comparing to the logs of the tune that made 393 whp 427 wrtq this is ~430-440 whp and 475 wrtq on that mustang dyno.
#1847
#1849
ok guy I dont want to get in this but come on do you think Matt would take all the time out to make up these numbers?
My car is on full E and I picked up 21hp. Matt never had a problem or anything....I am sure BYT and TERM have done a lot of tunning BUT I am sure together they have half of what Matt has. Matt wakes up everyday and tunes/works on cars. he loves it so much he stays after hours and works weekends. Also when and If Matt cant figure somthing out he has Ryan and Tim there to help. Come on Matts been doing this for years. just saying
#1850
